Project: Black Widow
Discussion in 'Project Logs' started by The Cleaner, 1 Aug 2003.
  1. Dad
    Dad You talkin to me?
    15 Apr 2003
    Looks like SVC is going to be selling them soon...
    Linkie
  2. Darkangel
    Darkangel What's a Dremel?
    18 Aug 2003
    i think u mean the other way round.. ur way would mean the plexi would make it stik out less :eyebrow:
    Its amasing what painting and changing a few parts has done for the whole of ur case its lookin good
  3. The Cleaner
    The Cleaner What's a Dremel?
    13 Jul 2003
    Clarification....
    With the plexi on the protrusion from the face of the plexi is approx 5.5mm.
    With the plexi off the protrusion from the metal face plate is approx 7.5mm.
    Sorry Darkangel if I wasn't explicit enough, and thanks for the positive feedback!
  4. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    thanx, luv the case btw
    damn, looks like it also wont fit, it was my biggest hope aswell, yet another fan controller that wont work, i dont wanna use a digidoc cuz they r ugly and expensive :p i might have to cone up with a way of setting the thing back into the pc front and still have it looking good
  5. FlashPanHunter
    FlashPanHunter What's a Dremel?
    22 Aug 2003
    I'm liking the project. I've got the 101 :brrr: and am trying to work up the courage to do more that cut a window my 200 dollar piece of alluminum. Nice call taking the plexi off the aero gate.
    Im also likin the fan, saw it before but wasn't sure how it would peform. Can it be turned 90 degrees on the heat sink? That might impove the perfomance taking in acount the back fan. Just a guess...
    So... where does it go from here? Lets get some pics!:clap:
  6. The Cleaner
    13 Jul 2003
    update...
    Heres a quick case pic with the newly modded aerogate fitted.
    More updates soon..
  7. Lsux0rz
    Lsux0rz What's a Dremel?
    3 Nov 2002
    hey when did u buy ur ATC 201? is ur front bezel attached directly to a flap on the top of the case, causing it to bend slightly outwards? this can only be seen looking vertically down from the top
  8. The Cleaner
    13 Jul 2003
    Lsux0rz,
    Just had a look at my case no sign of any bending of the front bezel. Bought it a month or so ago.
  9. Lsux0rz
    3 Nov 2002
  10. Lsux0rz
    3 Nov 2002
  11. The Cleaner
    13 Jul 2003
    Fun Update....
    Just trying to come up with some ideas for what to do next with the case.
    Came up with this concept drawing using paint shop, just a bit of fun.........or is it?
    :thumb:
  12. Lsux0rz
    3 Nov 2002
  13. Caged
    Caged What's a Dremel?
    5 Dec 2001
    Just a minor point, have you tried flipping the fan on the Aero 4 round 180 degrees, so the Coolermaster writing is the correct way up?
    Really minor point I know but I'm a sucker for detail :).
    Anyway, the case is looking great, love the sprayed Aerogate, the silver on that and the 4 push buttons are tied together now. Looks a lot better without the plexi.
  14. The Cleaner
    13 Jul 2003
    Lsux0rz,
    Sorry for the delay in replying. I've checked and my case is a slightly different design to yours, it doesn't have the screws going into the top of the case and the front bezel looks fine.
    Caged,
    Hadn't noticed the coolermaster logo on the fan being the wrong way round, I'll see what I can do.
    Small Update...
    I'am planning to change the setup of the aerogate so it only controls the four case fans and add some more chrome switches to switch off the fans completely. As for controlling the the cpu fan, I'am thinking of getting a Musketeer.
    Again, any comments with be welcome.
  15. FlashPanHunter
    22 Aug 2003
    I like the clean look. I think a nice aluminum faceplate for the floppy would make even nicer. Nice photoshoping too, that would be... a bit much:eeek:
  16. The Cleaner
    13 Jul 2003
    Update....
    Just bought a silver Musketeer. It didn't stay in one piece long...
    Out with the spray paint...
    Heres a few pics of the finished article.
    The next stage is to mount some more switches to switch off the case fans completely.
    More updates soon...
  17. FlashPanHunter
    22 Aug 2003
    Wow, that really is quite nice and sleek looking. I like.
  18. The Cleaner
    13 Jul 2003
    Update....
    Just recieved some switches from maplin, which I am going to use to switch off my case fans...
    I'am planning to fit this bank of switches next to the aerogate, so will need to have a bit of a bay re-shuffle.
    Now, where's that drill.......
  19. The Cleaner
    13 Jul 2003
    Update...
    My vandel switches have now been mounted on my 5.25 drive plate. Had to get a friend of mine to drill out the plate, my drill chuck wouldn't take a 19mm bit. Cheers Pete!!
    Here's a couple of shots.
    I'am currently working on the flip flop circuits so I can use these momentary to switch the case fans on and off.
    I the meantime, here's a pic of my new rig....
    More updates soon.
  20. FlashPanHunter
    22 Aug 2003
    Wow, nice set up. I really like the black and silver set up and I got thinking. Wouldn't it look nice if the blue backs to the guages were silver so they looked better in the light? I think that would be a great mod and look awesome. I love the silver switches and think that would improve the the face plate look. Some good progress :thumb:
    Looks back at pic, dang the key board is black and silver too. And the mouse! Oh man that would look sweet!
