Project: Black Widow
Discussion in 'Project Logs' started by The Cleaner, 1 Aug 2003.
  1. The Cleaner
    The Cleaner What's a Dremel?
    13 Jul 2003
    Flashpanhunter,
    I know what you mean about the blue dials, thing is they match quite well with the Aerogate when it's switched on. I'll have a closer look at the musketeer and see if it's feasable. I'll have to replace the led's with blue ones as well because it's the blue background that gives the dials their colour.
    Glad you like the rig :D
  2. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Sexeh, :eeek:
    About the flip flop circuit, how is it you'll ensure the fans always start on?
    Or is it just between 7v and 12v?
    Anyway, that silver/black theme all throughout is AWESOME. :rock:
  3. flacowboy
    flacowboy What's a Dremel?
    30 Aug 2003
    looing good love the silver and black
  4. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    Damn, thats coming out, quite nicely...
    though shouldnt it have red highlights, instead of bloo, you know, since black widows are black and red...
    :p
  5. bsodmike
    bsodmike Banned
    11 Oct 2002
    I had to post. Couldn't resist. Some nice work on the case there. Got the same case my self, quite unmodded as its for an ftpd server and I might have it tucked away in a cupboard soon, or somewhere in the corner of the room, all it needs is power an a cat5 cable....
    Keep up the good work, my only gripe is that those vadal switches are tough to press, I got one here but I opted for some other SPST switches with have a nicer bit of play and a 'clicky' sound thats metallic....
  6. Xarthan
    Xarthan What's a Dremel?
    14 Sep 2003
    :jawdrop: very nice setup, are you going to go with a top window?
  7. The Engineer
    The Engineer What's a Dremel?
    27 Sep 2003
    Awesome case, Mr Cleaner..... and nice setup too. I've seen the monitor picture and it's excellent..... although Katha says that apparently wooden flooring goes nicely with a modded compy. i'm saying nothing :naughty:
    a tip for "drilling" large accurate neat holes in thin steel / aluminium; use an end mill style milling cutter and NOT a drill - holding delicate metal in a vice tightly enough to use a 19mm drill is likely to warp/crush the workpiece, plus milling cutters don't "grab" and they give a nicer finish......
    Having seen the modded PC in real life i have to say it kicks huge amounts of ass.... :D
  8. KrazyIvan
    KrazyIvan What's a Dremel?
    18 Oct 2002
    Very nice. Looks very sleek and stylish without overdoing it. :clap:
  9. morpherex
    morpherex What's a Dremel?
    29 Oct 2003
    Looks nice, and not too flashy.
  10. ynema
    ynema What's a Dremel?
    27 Oct 2003
    Nice and Clean setup. I want some of those vandel switches they'd look pretty sleak on my setup.
    Keep up the good work.
  11. Sol Badguy
    Sol Badguy What's a Dremel?
    29 Oct 2003
    i really like your mod. its clean and sleek.
    one question: where u get all that money?
    haha iam just joking.
    i need a job :wallbash:
  12. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    very nice mod, i think if you removed the neon string from the graphics card and sprayed just the centre of the fan on the aero 4 - ie. the moving green bit either blue with clear nail polish on it to glow under the cathode, or with a bright white primer, that would look mreally cool, gonna do it to my aero 4 when i get the chance.
