Case Mod - In Progress Project: Cold lava~A custom WC'ing project -1st Oct- The cursed log part 2
Discussion in 'Project Logs' started by Bad_cancer, 17 Dec 2009.
  1. Nicksen
    Nicksen Danish Kid :D
    16 May 2010
    Cant your dad pay? He WAS the one that broke it? :D
  2. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    @Nicksen: That Wouldn't be very nice would it? seeing as I use all HIS tools :hehe:
    So after quite a while, I managed to pack in a sufficient amount of modding to make an update.
    Its getting crazy at my place, trying to get stuff finished for the move, but Im going at it as much as I can.
    So update time:
    Of reservoirs and peltiers
    It was time to get the reservoir finished so the first thing I did was to attach the thermostat's thermal probe to the res.
    To do this I drilled a hole and stuck it into the reservoir with this:
    Arctic silver thermal epoxy.
    This should keep it nice and sealed, without isolating it from the water temperature. :D
    Here it is in place hardening nicely:
    And a closeup.
    It will need some cleaning up, but nothing major. I've actually never used this stuff. So fingers crossed. :worried:
    The next part was the upper part of the res.
    I placed the peltier waterblock on the cover to have an idea of what it was going to be like.
    Some time later, as I mentioned before, my dad chucked a box on it and broke it, but after inspecting it, I realised that it wasn't so bad.
    So I cut out a piece of acrylic and stuck it underneath with clear epoxy. It seems to be holding quite well.
    So now I needed a cold plate for the peltiers. And I was trying to figure out the best wat to attach it to the cover, When i suddenly remembered that I had an extra peltier block top lying around (My friend had cut 2 of each type, when I only needed 2 for the GPUs.)
    It would be a perfect match. I took out the saw and chopped it up.
    After some cutting and some filing:
    Voila...Instant bracket. :D
    Next up I had to make a cold plate for the peltier coolers.
    So Using some copper i made this:
    (Don't mind the big groove in teh block...grinder mishap :worried:)
    Sticking it in the bracket proved easier than I had expected. I was going to screw it in place, but I discovered that the rtv silicone is more than enough to hold these two together
    I drilled some holes and countersunk them. Then i fitted some Inox screws in place and I stuck it to the res cover.
    Next up I drilled the holes for the Uv LEDS that are going to be on the cover too.
    3 Uv LEDs for the bling and 2 Orange LEDS to show me when the peltiers come on. :D
    Then I filed some grooves for the peltier cables to sit properly in the cover.
    I also lapped the surfaces, applied artic silver to the peltiers and put the blocks in place, whilst sealing the screw holes with rtv. (I was on a roll and I forgot to take pictures :s)
    Here you see the peltiers in place ready to be screwed... :worried:
    The springs were a little long, so I chopped them off and added some washers to keep things nice and tight.
    And here the finished assembly:
    Then I stuck the LEDS in place and let dry overnight.
    The next day I decided to give the system a little try:
    The test was fun. The peltiers definitely work. The plate gets real cold, but I was half expecting it to freeze over :eyebrow:
    But anyways...It seems my waterblock works, because After a few minutes I held my hand against the hot side of the waterblock and it was at ambient temperature.
    Sweetness :D
    Thats it for today guys.
    Thanks for watching and for those who voted for me :D
    (Although I don't find it fair to pit me against a Dreadnought mod, Bill AND Cheaps at the same time. Comeon how was I ever supposed to win? :p)
    matt... likes this.
  3. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Nice to see you are into this project again! Process is fantastic so far glad that the peltiers are working I really cant wait for some torture tests! :)
    I also like your pr0n references .....
    "Here you see the peltiers in place ready to be screwed..." LoL Mod on brother! :)
  4. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Good project , i will be folowing !:D
  5. Remmes
    Remmes Be One With Your Mod
    24 May 2010
    i don't think the thermal paste helps a single thing, other than that it looks good so far
  6. Bad_cancer
    7 Apr 2009
    Hah thanks. I read too many of cheaps' threads.... :worried:
    I wouldn't say the process is fantastic, but I am reasonably pleased so far :D
    And yes I can't wait either. I just glued the res together :rock:
    Thanks a lot!
    You mean the epoxy I used for the thermal probe?
    Hmm, do you mean that normal epoxy would have worked just as well?
    The thing is I had some, so I figured it would probably be better because it is made to stick heatsinks to ram chips. Anyway.....can't go wrong with it really can I?
    Thanks for the comments!
  7. Remmes
    24 May 2010
    what basicly happens with heatsinks on ram chips/cpu's is that you create a vacuum,
    what it hink is that the thermal paste doesn't help (like too much could work as an isolation)
    but i guess it isn't bad either.. :p
  8. Nicksen
    16 May 2010
    Amazing update. And I knew you couldn't ask your dad to pay. It was a joke :D
    Looking forward to see the res!
  9. The boy 4rm oz
    10 Apr 2008
    Putting too much thermal paste on will always create issues. The idea is to make the layer as thin as possible because the intention of the paste is to fill the microscopic gaps on the chip surface to make it a completely (or close to) flat surface for heat transfer. Too much paste will make the gap between chip and heatsink larger and therefore give worse performance.
  10. Bad_cancer
    7 Apr 2009
    Thanks for all the info about the paste guys.
    But The reason I put thermal epoxy is because the thermal probe on the circuit is just an exposed chip. Therefore to use it in water, I had to embed it in something, and everyone recommends embedding it in epoxy.
    So seeing as I had some arctic silver thermal epoxy, I used that to seal the chip. :D
    working slowly so far, but getting there....
    C ya for an update as soon as I can. :D
  11. yazka77
    yazka77 What's a Dremel?
    7 Feb 2010
    Looking good m8. Subscribed for the first time. 5 stars from me. :jawdrop:
  12. Nicksen
    16 May 2010
    I still haven't figured out how to subscribe?? XD
  13. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Great work on the peltier blocks and res, Bad_cancer :thumb:.
    I too cant wait to see some torture tests.
    If your signed in, its on the thread tools button at the top of the page^^.
  14. Nicksen
    16 May 2010
    Thanks :D
  15. Bad_cancer
    7 Apr 2009
    Hi everyone and thanks for the comments.
    Im back after a long stay in the hospital.
    I had a bad fall and broke my arm. I had surgery and now have a plate and screws in my radial bone. I also have a plaster on my right arm and a badly scrapped knee. So I can't walk properly and I can't use my right arm for anything. Its a pain because I have hardly any work left to do on cold lava :sigh:
    Anyways, I'll try to get to it as soon as possible. So stay tuned.
    Thanks and see you soon (should be 5 weeks)
  16. The boy 4rm oz
    10 Apr 2008
    Mate that really sucks about your arm, I hope it heals up well.
  17. Bad_cancer
    7 Apr 2009
    It seems to be healing well, but its still in a half plaster.
    It's not all bad news though because I just got married :thumb:
    But I had to get married in a plaster on the right arm :sigh:
    Ah well, could have been worse.. I'm just annoyed that I can't finish the project...
    There is so little to do :waah: :waah:
  18. The boy 4rm oz
    10 Apr 2008
    And congratulations on your Marriage :D :thumb:.
  19. AnG3L
    19 Mar 2009
    Oh man sorry to hear that, that sucks hope you heal quickly but congrats on your marriage!!!
    We need pictures!!!!!!!!!!!!!!
  20. Bad_cancer
    7 Apr 2009
    Pictures of the wedding or of the broken bone? :p
