Scratch Build – In Progress Project: Evolutionary
Discussion in 'Project Logs' started by Franklin, 29 Nov 2006.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    haha i dont think you understood what I was asking. What KIND of scroll saw blades are you using (specifications like, tpi, size, type of teeth, etc.) and WHERE did you get them? :D sorry if i worded that wrong before. Its always good to see progress, i cant wait to see how this one turns out
  2. Franklin
    Franklin Minimodder
    24 Oct 2004
    I don't have the package anymore THEkorean. I just bought some from a small store nearby my house. I'm gonna buy some new ones this afternoon, will have look at the package for you.
    I finished the acrylic ducts that will guide the air from the intakes on the sidepannels to the radiator.
    and the ducts placed in the frame
    I will mount two parts of these ducts onto the sidepanels.
    The left duct from the inside of the case and with the sidepanel on.
    Front picture from the left side.
    Also did some work on the mobo tray and the backside of the case. This part i mean.
    Coolermaster sended me a damaged mobotray for FREE. It only needs some small modifications. The back needs to be covered to match my black case.
    The backside of my case is starting to look much better.
    I think this will look great.
  3. ComputerKing
    8 Sep 2006
    WOW! That's very nice and clean! OMG, This is amazing, good job, I love that rear panel, Can't wait to see the next update, good job.
    Good luck.
  4. KaotiK
    KaotiK What's a Dremel?
    2 Jul 2007
    This is shaping up to be another Award-winning Project if you ask me :D
  5. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    I can't even imagine how many hours of work have gone into this project. Really fine work!
  6. Brett89
    Brett89 Minimodder
    15 Dec 2005
    :jawdrop: at that mobo tray cover/rear. that looks slick. Also, anything and everything to do with the fans/airflow on this case is amazing, keep it up!
  7. Cheapskate
    13 May 2007
    1/4" plexi for DUCTS! -this baby is going to weigh a ton!
    I can't figure out when it wasn't.:naughty: Even with the frame you were raising eyebrows.
  8. Franklin
    Franklin Minimodder
    24 Oct 2004
    Thanks guys, yes it is starting to shape up quite well. That's why I started working on the frontpanel. Just like I did with the powerbutton I will use mdf and aluminium. I used some brushed aluminium from AC Ryan.
    There is still some tape on the aluminium, because I have to file it a bit more. The DVD player, Aquaero and the front panel from the soundcard will be placed in the middle and that's also the spot where I will use the mdf.
  9. ComputerKing
    8 Sep 2006
    WOWOWO NICE! nice speakers! Kickass! I love this :D Well done. This so nice and great. Well done, Can't wait to see more.
    Good luck.
  10. Teyber
    Teyber ******
    18 Mar 2007
    yes i can't see the pics... (any of them)
  11. ComputerKing
    8 Sep 2006
    I can see them all!? LOL!
    Good luck to see them :(
  12. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    I can see yours CK - but still nothing from Franklin
  13. Franklin
    Franklin Minimodder
    24 Oct 2004
    Hmmm strange, some people can see it and others don't. I know my host is moving to another location this weekend, maybe that is the problem.
  14. ComputerKing
    8 Sep 2006
    No Problem Brother I will host it on me :D we help each other :D Good luck.
    Here you go ;)
  15. Teyber
    Teyber ******
    18 Mar 2007
    pics are back up franklin!
    Sweet update! did you use a band saw for c utting the black thing to cover the rear mobo tray?
    can't wait for next update
  16. Franklin
    Franklin Minimodder
    24 Oct 2004
    I used a scroll saw.
    Did not have much time to work on the case last weeks, but this week I can show you a small update. I had to solve the problem with the airducts in the top of the case. Needed to use acrylic because the ducts will to guide the air to the outakes on top of the case, but the acrylic is transparant, so when you have a close look through the openings of the outtakes, you would be able to see through. So there where the MeshX has to come in.
    Also had to fabricate some aluminium pieces to mount the harddiskbox.
    It's not finished yet, need to drill a hole to attach the springs to the mountingpoints. I'm working hard to close all the sides of the case. Hope I can show you a closed case in a few weeks.
  17. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Shocks?! Damn, this thing is gonna be bumpin'! :rock:
    Lookin' good man, this is one very unique case and I can't wait to see it with some side panels! :clap:
  18. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    Can't wait to see more of those hdd-shock-absorbers...I'm sure it'll look so cool!
  19. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
    damn u took my idea:idea:!!! o well ill still use it:thumb:
  20. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    ah.....looking great...........
    what size R/C model car do the shock/springs belong to?
    Alan
