Scratch Build – In Progress Project Flipmode - 1 jan 2012 - Flipmode finisht -
Discussion in 'Project Logs' started by Paslis, 13 Jun 2011.
  1. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Normano64. :D
    Thanks.
  2. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 16.
    The idea was to leave the house early this morning but i forgot that me my wife and my 2 kids had to go to meet these guys at my wifes work.
    After some dancing and singing and some presents i made it home in 1 piece. :D
    So i put on my working gear and drove to the shop to make the case feet.
    First i took 2 aluminium pipes and got started to make the standoffs.
    The diameter was too big so I had to reel them off and cut them on the right lenght.
    Then i made the plastic feet.
    Then ik took some black m8 countersunk hex bolts to mount the feet.
    This is how the case feet fit together.
    Then i mounted them on the case and this is how they look.
    This was it for today. :D
  3. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I dont know what to say....Stunning work !
  4. OmightyOne
    OmightyOne Minimodder
    7 Nov 2011
    excellent fabrication !
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Elegant!!! ... But acctually where do your wife works???
  6. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Brilliant work once again :).
  7. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks KoSoVaR.
    Thanks OmightyOne.
    Thanks quizz_kid and my wife works at a hospital.
    Thanks yassarikhan.
  8. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really neat and new ideas, fantastic work, what more can I say? Just mod on!!! :)
  9. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 17.
    The case feet gave me a bad feeling so then there is only one thing to do and thats make new ones.
    This morning i went early to the shop and started on the new case feet.
    Each feet is made out of 10 pieces of 1.5mm steel.
    First i spotwelded the pieces together.
    The i cut out the side pieces.
    Further with spotwelding.
    The spotwelding is done now its time to finish them.
    Now thats done lets do some sanding.
    Then i drilled and coutersunk the mounting holes.
    Now the feet are ready i cut the 2 side pieces and spotwelded all the pieces together.
    Some sanding again and then i mount the case feet on the case.
    This is how it looks.
    Im happy with the endresult so the case feet are finaly done. :D
    yassarikhan786 likes this.
  10. bugeye
    bugeye Sleep Deprived
    16 Aug 2011
    I really like that second go at the feet .... much better integration with the case , really looks like they are part of it rather than added on :)
  11. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Yeah those new feets are awesome!
  12. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks AnG3L. :D
    Thanks bugeye and yes they look like they are part of the case. :D
    Thanks TotalGaos.
  13. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Not to say that the first set of feet weren't well done (they were) but I'm glad you decided to change them. This new set look much better with the case :thumb: Excellent build.
  14. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Mosquito and your right the second set matches better with the design. :D
  15. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Looks awesome mate!
  16. MiniDoughnutNinja
    MiniDoughnutNinja What's a Dremel?
    29 Nov 2011
    The chassis looks amazing! :clap: Great design inside and out. Great job overall. Keep it up!
    The mobo tray design is simply brilliant. :jawdrop: Intelligent even, it provides for a great show of the main parts of the rig and utilizes space inside the case way more efficient than our standard cases.
    Excellent case design. I love the both exterior and interior so far. I wish I had one similar.:lol:
    If all 12 blowers were 120mm I would say that this one is the best case airflow wise I have ever seen. Are 92s the second set from the bottom? :confused:
  17. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Holy tungsten inert gas, Batman!
    Love it man. Your welding makes me drool on my keyboard (its okay, I wanted an excuse for a new one)
  18. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thanks Boscoe. :)
    Thank you MiniDoughnutNinja and your right about the angled mobo.The 92s are the ones beneeth the mobo. :)
    Thank you jeckulz and is your kb broken now ? :p
    Waynio likes this.
  19. bugbear974
    bugbear974 What's a Dremel?
    31 Jul 2011
    You are an artisit!
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    About time I subscribed to this masterclass of outstanding fabrication :), would be a sweet dream being able to weld this nicely :) nice layout too & I actually like the multi heart grills, good idea for a grill :D.
    Welding looks a lot of fun once you get awesome at it like you :).
    +rep +5star +:rock::thumb:
