Case Mod - In Progress Project: Gearbox 2.0 - mini P180 Back to Basics
Discussion in 'Project Logs' started by THEkorean, 2 Jun 2007.
  1. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    nice work.
  2. bustamove
    bustamove A Dremel is a wotsit.
    11 Jan 2008
    Very nice work so far. Really looking forward to seeing this complete.
  3. THEkorean
    THEkorean 42
    10 Jun 2005
    First pieces painted:
    More to come.
  4. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    That's some sweet paint dude, Awesome work :clap:
  5. skullen
    skullen Minimodder
    31 Oct 2007
  6. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    nice to see you're working on this again
  7. THEkorean
    THEkorean 42
    10 Jun 2005
    Before I painted the rest, I couldn't resist a mock mount:
    fits well, connectors dont bump into anything, awesome!
    Then things were painted, remounted, and the XLR jacks were added for some perspective
    Macro shot of the acrylic divider
    Macro of the XLR
    top shot
    back shot.
    Everything is painted with 3 layers of grey wetsand printer, followed by 3 layers of semi flat black from krylon, and 2 layers of satin clear from Krylon. Mmm that's about it for now, next time will detail some wireing hell that Ill have to go through (especially with my level of soldering) but I think Ill manage
    Until next time!
  8. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Can't wait mate, would like to see some detailed pictures of how your wiring the whole junction box thing, if I'm allowed to make such requests, anyways keep up the great work mate :thumb:
  9. NZ_mod_man
    26 Aug 2007
    I'm liking how the junction box is coming along. Keep it up! :D
  10. THEkorean
    THEkorean 42
    10 Jun 2005
    Before I start, let me just say, I SUCK AT SOLDERING BIGTIME. So im still learning so bear with me please :) . Make sure you leave some tips if you see any shoddy workmanship :thumb:
    OK lets begin..
    There are the pieces to-be-wired, mounted
    Wired, also mounted the case speaker in there too,
    routing power-in to the other chamber,
    connected and tested (the fans are alive!)
    fans closeup
    XLR closeup
    OK that's all I got done, and it took FOREVER because I messed up so many times :( hopefully things will move alot more fluidly from here on out.
    and of course, the customary mock-fit:
    hrm, a bit too long, but it looks fine, so I wont need to fix them.
    Well that's all for this week.
    Now.. I need your help.
    So if you hang out in the modding section, you know I've screwed myself with my key switch, its and ON-OFF switch with the key only removable in on ON position. I wanted to use it to ARM the power switch but it's not going to work like that due to the nature of the switch. I would simply remove it, BUT I already drilled the hole :wallbash:
    What should I do it. It has 2 soldering cups on the back, any creative ideas welcome. The best I could think of right now is a temporary fan or pump cutoff switch. BRAINSTORM FOR ME PLEASE I NEED IT :(
    Until next time!:thumb:
  11. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    you call that mayhem? You should see my desk! :lol:
    one tip:
    Get some strong iron-wire (ignore the language barrier plz, you know what i mean :p), and put that insside the cable sleeves with the cables. The wire can be bent to get the exact shape you want. All the cables will look much more organised going in straight, parralel lines and bends. To be completely certain that the form-wires don't contact anything you could use some tape to insulate them i guess.
    Anyway, good luck on the soldering lessons, i'm going to have to do the same thing too soon :p
  12. Cheapskate
    13 May 2007
    I'm using stripped, heavy, single-strand copper wire for what Xtrafresh said. The other option you have is to hot glue the molex plugs to the board, Compaq-style. (They glued the cr*p out of their systems.:duh:)
  13. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    Nice i love the wiring, using similar plugs to what i hope to be using, looks very nice, if myns half as good ill be happy :)
  14. Guest-23315
    Guest-23315 Guest
    I don't think that looks bad at all!
  15. MixWizard
    MixWizard Minimodder
    16 Jan 2007
    i no youve already started using the RCA's but you could also use din plugs for when there is more then 2 sets of wires needed, like PCI-E connectors.
    Like the ideas and progress so far though
  16. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Well, as for the hole...
    Do you have a reset switch? or do a switch for the lights.
    *shrug*
  17. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    Your still watercooling this right? I assume your putting the radiator above the junction boxes?
  18. THEkorean
    THEkorean 42
    10 Jun 2005
    @Xtrafresh & Cheapskate:
    Yea, strong single strand wire seems like the smart choice, but I dont really like the stuff mainly because I like how multi strand wire sort of "soaks up" the solder and it makes it easier for beginners like me to get work done. I've tried the single strand stuff before and I found it difficult to use :( I was probably doing it wrong, but I think ill stick to the wiring I have. Maybe once I get better, Ill try the single strand :)
    @Teknokid and '91
    Thank you :)
    MixWizard:
    Yea, I was planning to do that for the front panel connectors, my only qualm with DIN connectors are that they are ugly :hehe: Ill probably have to get some anyways and hide them in a corner.
    500mph:
    Yes I have a reset switch, came with he case haha, I might use it as a light kill switch though, Im going to be taking this to my dorm next year so it may be nice to have a kill switch in case my roomate is bothered by it. Thanks for the sugestion.
    Monkey Nutz:
    Yes it is, and you are right, the rad and fans go above the junction box. I'll put them back in once i get the fans painted and some modifications are made to the radiators.
    Keep the ideas and comments coming please!
    Until next time
  19. MixWizard
    16 Jan 2007
    Look at DMX connectors, they are nomally used for stage lights. Look like XLR's only with more pins (Come in 4/5 pin versions). Ive seen the screw type din connectors used elsewhere on someones mod and they looked quite good.
  20. THEkorean
    THEkorean 42
    10 Jun 2005
    SO, I got bored today and didnt feel like wiring, so I made a piece I've been meaning to make for a while now, here it is:
    Acrylic border for the underside of the mobo tray.
    More pics!
    The thing is going to lit from the inside with White LEDs connected to a controller that will make it pulse with the audio or just stay on, cool no?
    It still needs to be fine tuned to sit perfectly on the mobo but its almost there.
    Until next time!
