Scratch Build – In Progress Project : GTR-r - nom nom nom teaser
Discussion in 'Project Logs' started by Dark~3nergy, 4 Jul 2010.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    hi everyone !
    Here is my summer project, called GTR-r,after my previous unfinished mod GTR because i used some of the ideas from it.
    I'm building this case because my main computer died and i need a new one.
    Anyway, here's what it will look like :
    done in 3ds max 2009 with Vray 1.5
    i had some better renders but i lost them when my computer died. i will make better ones when i've finished this computer.
    here's what it is currently looking like :D
    updates coming tomorrow ! :thumb:
    cheers and please comment !!
    I'm also looking for sponsors :)
  2. BiotecVirus
    BiotecVirus Everything should use Torx Screws
    10 Jun 2010
    Looks very nice. What you planning on having in the top section? Cos if it produces alot of heat I would add a blow hole at the top.
  3. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    This looks awesome dude!! Will be following!!
  4. (FIH) The Don
    (FIH) The Don What's a Dremel?
    27 Jun 2010
    A wooden case, I are following tehs one :D
  5. Evenge
    Evenge Minimodder
    16 Sep 2006
    Well the plan looks nice. Good to see more wooden cases (I'm assuming the construction material is wood :))
  6. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really like the design I was wondering though, will the dvd- rom be external?
  7. Combatus
    16 Feb 2009
    Stunning rendering! Looking forward to the worklog:D
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Such a simple yet elegant design, was really praying this would evolve into a build from the render thread :D
  9. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Man this case're crazy!!!
    Congratulations!!!
  10. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Looks good to me.:thumb: As always your renders are the cream!:sigh: Sub'd:D
  11. stonedsurd
    11 Mar 2009
    Gorgeous renders and great start dark!
  12. Dark~3nergy
    14 Jan 2007
    thanks :D
    Ang3l :yes, i only use a dvd drive to install windows, so i don't really need one in the case.
    BiotecVirus : it won't need any cooling i think,only an aquaero and cables.
    Evenge : some sort of plywood ;)
    and thanks again to the others :thumb:
    the update is coming later today !
  13. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Nice I like the shape.
  14. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    I've fallen in love with this case, its simple yet perfect.
    Its making me reconsider Mocha70
  15. BiotecVirus
    10 Jun 2010
    Ok awsome, just had to check incase. Good luck with ya build, hope it goes well for you.
    subbed :)
  16. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I like the design. Simple and elegant. I like the frames around the windows as it gives a nice contrast. Subbed
  17. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Nice start. :thumb:
  18. zerohavoc99
    zerohavoc99 What's a Dremel?
    15 Jun 2010
    So simple, so amazing, I hope you do not mind if I take some of your ideas for my self...
  19. Dark~3nergy
    14 Jan 2007
    UPDATE 1
    here it starts, bought some wood for 68.-CHF
    and here a picture of the workshop i will be using. +1rep to the person who can identify the bust on the shelves :D
    best view ever from a workshop ;)
    anyway... started by drilling some holes and assembling the "frame" of the case:
    and this happened :
    then repeat the same thing again :
    and again :
    and again :
    and after an hour :
    sadly the wood got a bit messed up on the back side, i don't think that it's too bad though :
    otherwise i'm really happy with the result:
    and now the inner part :
    I started by making a piece to hide the cables :
    then fastened it to the part that separates the different "levels" of the case :
    used my router with this bit to cut it to the right size :
    cutting the second part :
    fastening it to the rest :
    and quickly attached to the case :
    i also attached the right side to the case :
    the case is upside down on these pictures.
    and that's all for today :) more tomorrow !
    comments and questions are more then welcome ! :thumb:
  20. Darkraven
    Darkraven What's a Dremel?
    23 Dec 2006
    Probally out on a limb here but looks likes Vladimir Lenin on the bust.
    Says location Switzerland but I'd have guessed the view from your shop was North Louisiana. Looks like home to me. Except for the style of gutter on the house.
    Dark~3nergy likes this.
