Scratch Build – In Progress Project : GTR -X CANCELED X- sorry :'(
Discussion in 'Project Logs' started by Dark~3nergy, 20 May 2007.
  1. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    great looking job and great looking CAD work
  2. BenJ
    BenJ What's a Dremel?
    1 Jan 2004
    Hi
    Looks really good. I will follow your progress.
    Regards
    BenJ
  3. fungry
    fungry What's a Dremel?
    14 May 2006
    i really like the wood work and the CAD. excellent job there :D...
    may i ask, what exactly is a mill?
    i'm continuously browsing these forums on how to do things... planning to initiate a mod with a friend in about 1.5 weeks from now. :) will have to purchase tools and materials along the way.
  4. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    very nice, the sketch is awesome!
  5. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    If you haven't all ready ordered your WC parts I'd recommend you get it from Aquacomputer.de and get the New cuplex XT Double Impact: [​IMG]
    Looking great, can't wait for the next update :thumb:
    -Fr4nk
    PS: Subscribed :)
  6. The_Beast
    21 Apr 2007
    That is a great looking block, looks like there is alot of other great stuff
  7. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
  8. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Hi all ,
    I've never expected that I would be featured in the project log update :lol: !!!
    I'm sorry I couldn't get an update sunday cause I felt sick but now I'm fine.I've ordered the reservoirs and some other stuff soo they will probably be here on friday.That means UPDATE on saturday(or later if the package doesn't come on friday) !!!!!!!
    @ Fr4nk : I was planing to get that waterblock but I won't buy it until I've got my cpu.
    @ Darkened : that's a good idea, I don't have one but I will see if I can get one or if I can borow one from a friend.
    @ fungry : I'm not 100% sure of the name but it looks like this: [​IMG]
    soo cya on saturday !!!
  9. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    he means a router its like a kind of glorified drill which you use special bits in it and it cuts like the ones that he has done you can get loads of different bits for it! its mainly used for wood.
    http://www.tooled-up.com/Product.asp?PID=20535&MAN=Draper-1-4-inch-Plunge-Router-1200w-240v
    thats about the cheapest one you can get.
  10. Caliber
    Caliber Minimodder
    26 Aug 2004
    Great looking project so far, will be keeping an eye on this :thumb:
  11. Colossous
    Colossous Minimodder
    28 May 2007
    Got to subscribe to this one, looks amazing ! :D
  12. Dark~3nergy
    14 Jan 2007
    Hi all !
    UPDATE 5
    I didn't get the things I ordred soo I couldn't do what I had planed :waah: .
    but I've got my mobo :
    soo I started with the back panel.
    I made two holes for the fan and cut out the hole for the ... I toke it from an old aerocool case I have .
    Then I wanted to finished the front, I used my dremel but at 3/4 of the hole preparation -it died :waah: :waah: rip my trusty dremel !!
    So I improvised ... i drilled some holes and then I used a hammer to get it off and it looked like this :blah: :
    After some sanding :
    After a lot of sanding it looks like the other one :
    Then I started with the window, I bought a 50x50x0.5 acrylic panel :
    I marked out where I must cut :
    then I used my jigsaw and some sandpaper and perfect :clap: !
    I put it on the side panel to see if it fits :
    That's all for now maybe more later today !
    Cya and stay tuned
  13. fungry
    14 May 2006
    woohoo! an update at last! pity your stuff didn't arrive, i would love to see them.
    man, i hate it how i lack any money :(, i love those aquacomputer parts. The good thing is, if i do get money, i found an etailer that distributes things like the aquatube, aquabay, aquastream internationally, in that they actually send the products to a location out of their country. in my case, china ^^. just got to pay up for the postage.
    btw, its a pity that your dremel died :(, but atleast you got around the problem so kudos to that!
  14. x06jsp
    2 Apr 2007
    nice goood improvising and a shame bout your dremel!!!! quick buy a new one!!!! lol
    good wrk keep it up
  15. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    Great stuff man! :D
    I subscribed to this thread a while ago and look forward to your updates ;)
  16. Handon
    Handon What's a Dremel?
    10 Feb 2007
    Sry if you posted the answer before but why do you want to buy a Aquacomputer waterblock ?? They are really not the best ones and they're really expensive. Good waterblocks are the Alphacool Highflow or NexXxos....
  17. Teyber
    Teyber ******
    18 Mar 2007
    how are you going to mount the plexi on the MDF? and what are you going to use as a frame? and one last question, Are you going to router the fans so that you don't need like 3 inch screws to mount them? im going to build a mdf case soon and am you are teaching me a lot!
  18. Dark~3nergy
    14 Jan 2007
    small Update
    Hi all and thanx for the comments !!
    @ Handon : The alphacool block are realy good but I prefeer the look of the
    aquacomputer waterblock .The alphacool Highflow have the same price as the aquacomputer cuplex XT where I buy my wc parts.
    @ fungry : Aren't there any online shop where you can buy wc stuff?? That sounds strange.
    @ Teyber :For mounting the plexi on the side panel I'm gonna use, I will not use a frame and I'm not 100% sure yet how I will do for the fans but I think I will router them in place.
    :D I recieved my stuffs this morning and here they are :
    Ther's two aquatubes, two twinplex XT Chipset water blocks ,two covers for the aquatube and two 30cm white cold cathodes.
    (don't mind the color of the aquatubes I'm gonna paint them orange later)
    I directly put the water block on the mobo :
    But as stupid as I am, I forgot to order the ... (I don't know the name :worried: but it look's like that ) :duh:
    And now for the dremel ! I think I have the warranty somewhere -I gotta find it !
    :worried:
    Cya and next update will probably be next wednesday
  19. Boxcarhobo
    Boxcarhobo What's a Dremel?
    12 Sep 2006
    Going nice.
    Are these 120mm fans at the back?
    I thought it would be nice to paint the ress black but orange will be the theme of the mod right?
  20. Dark~3nergy
    14 Jan 2007
    Boxcarhobo,
    the fans at the back are 80mm. For the res I didn't think about that, But I will do some sketch-up work to see how it looks !
