Scratch Build – In Progress Project : GTR -X CANCELED X- sorry :'(
Discussion in 'Project Logs' started by Dark~3nergy, 20 May 2007.
  1. cheezeit
    cheezeit What's a Dremel?
    29 Aug 2007
    Wow, I can't believe i missed this mod before! It's great, keep up the good work!
  2. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Update 13
    Hi,
    I must apologyse for the pictures of this update, I usually use my father's camera but today he left it at his work :( , so I had to use another one.
    UPDATE 13
    Today I continued to work on the second phase, I made the back, the front and half the side, since I had no good camera I didn't take any pictures of my work, just the result.
    I just put it together, I wanted to screw it together but I didn't have any screws left :waah: . For fixing the psu I'm gonna use a lian li psu bracket.
    I put the fan and the rad to see how it look's:
    I still have alot of bondo to sand down and some holes to hide.
    that's all for today, I'm going to buy more screws and plexiglass on saturday for another update :D
    cya !
  3. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    at last an update :p looking as good as ever
  4. Kylevdm
    4 Oct 2007
    Spoke to soon
  5. Dark~3nergy
    14 Jan 2007
    I'm sorry I was very sick last week so I couldn't do anything :( but now I'm feeling better. I've been modding this morning ;
    so there's a very big update comming !!!!!! :D cya
  6. Kylevdm
    4 Oct 2007
  7. Dark~3nergy
    14 Jan 2007
    UPDATE 14
    Hi all !!
    Update time !!! first of all, I still haven't recieved the rca and xlr connectors :miffed: and I order some stuff yesterday so they will probably come on wednesday.
    UPDATE 14
    Yesterday I glued all the pieces together but not the left side :
    I used the left side as suport for the front so I could get it straight :
    Then I glued the piece that goes under the bottom :
    then I glued the top :
    I put the side on :
    I did alot of bondo/sanding but I got realy bored after 2 hours , I still need to do a lot of bondo work.
    then I put all the pieces together :
    then I added the ccfl to see how it looks :
    That's all for today, next update on the next weekend !
    comments and question are wellcome
    Stay tuned ! :D
  8. Kylevdm
    4 Oct 2007
    yay an update good work
    are you going to paint the inside black?
  9. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    Nice lighting. I don't like it when you can see the actual light sources inside a case so this is done well.
    Think you can give us an idea of how much this case weighs as of now?
  10. Dark~3nergy
    14 Jan 2007
    the inside is going to be white*
    it weighs 17.5 kg :jawdrop: LOL
  11. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    17.5Kg is nothing, my old chieftech dragon when fully kitted with 4 HDD 2 opticals, and watercooling weighed in at 26kg dry load, when filled with water it was about 27-28kg as it squeezed a massive rad and res in it! lol!
    maded lan parties great!
  12. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    17.5kg? That's indeed nothing to worry about
    *looks over at Der_Meister, that weighs over 50kgs*
    nice update by the way, the white ight looks great together with those black 'n red Aquatubes! :thumb:
  13. Dark~3nergy
    14 Jan 2007
    XLR and RCA
    thanks all,
    You've right, 17.5 kg is not that much, but it's still missing the psu, the water blocks, the coolant, ...
    anyway, today I recieved the XLRs and the RCAs :D
    but ther's a big problem !
    The XLRs are too small :( they are only 11 mm big :sigh:
    and I don't realy know if i can use them :(
  14. Kylevdm
    4 Oct 2007
    lol
    you waited so long for them
    btw my current pc is 20 kg with no water cooling equipment :p
    its annoying to to cart round but i can't break it :p
  15. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Awesome! great call on the white light too.. I'd be proud to have this one on my desk :cooldude:
  16. Jipa
    5 Feb 2004
    Nice design and good work! That doesn't look like it's made of wood, which is a good thing! Nice to see wood being used in DIY cases other than silent cubes..
  17. Sark.inc
    Sark.inc What's a Dremel?
    9 Dec 2007
    Great work, given me a few idea's for my mod :D
  18. Kylevdm
    4 Oct 2007
    you on holiday again?
    lol
  19. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Yeah, Im missing the updates
  20. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    You should really chamfer the upper right corner of the window. That will match the bolts and the woodwork perfectly :)
