Project Interceptor - Interactive Modding!!
Discussion in 'Project Logs' started by TheGreatSatan, 16 May 2007.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    I added a light coat of primer to the face to bring out the all the areas I still need to touch up with Bondo.
  2. TheGreatSatan
    5 Aug 2005
    I was thinking of adding a badge like this (maybe):
    To here:
  3. wbdog206
    wbdog206 not me
    15 Jan 2007
    thats what you should make the side window shape.
  4. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Great! I love the badge in front idea. For the side panel, i wont make the star there, maybe just increase the size of the window in the current shape it is in at the moment.
  5. TheGreatSatan
    5 Aug 2005
    BTW, I don't plan on using the star badge I posted. It looks too Old West-ish. Problem is that all badges I've looked at have a specific city/county/state name on them. I wish I could find something modern that only says POLICE
  6. dawg218
    dawg218 What's a Dremel?
    10 Oct 2005
    Hey, nice idea with this mod... haven't seen a whole lot of cases following this theme (hell, any of them actually!) so this should be a nice mod. I like the interactive part, I'd vote more but I don't have oodles of time to browse the forums. I only came upon this one by chance.
    Great idea using the expanding foam, I was working on an auto-themed mod for a long time (still am, kinda, but I haven't been able to get to it for over a year... stuck in my old house and I have nowhere to work on it) and I couldn't figure out what to use for a grill. Great idea there!
    This looks like it could be a kick-@$$ mod, keep us posted! And thanks for the foam idea!
  7. TheGreatSatan
    5 Aug 2005
    After the holes were fixed I re-primed it.
    And the inside
    After 2 coats of primer I began the 1st coat of black.
    I usually do 4 coats of color and at least 3 coats of clear after that.
  8. TheGreatSatan
    5 Aug 2005
    Alright, I finished all color coats on the front
    The 3rd and last color coat on the top.
    And the 2nd coat on the right side.
    Question: When I'm all done with the black.....
    1. do I clear coat a few times, add the white stripe and clear coat again?
    or
    2. Finish black, add white then clear coat all?
  9. widmod
    widmod Minimodder
    9 Oct 2006
    the reflection allready locks like a clearcoat so i thinl it s enough to add the white and then the clearcoat
  10. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    add white and then clearcoat. Are you gonna cut the side panel before you spraypaint the other side?
  11. TheGreatSatan
    5 Aug 2005
    Yeah, I sure am.
  12. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Why dont you just make a police car from scratch? That would have been very cool i think.
    It can be quite difficult thou, and you have already started so..
  13. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Because this is interactive modding, he started with a choice between two cases, the police theme came later on.
  14. TheGreatSatan
    5 Aug 2005
    Next question. How do I attach the handcuffs to the front?
    1. Rivets
    2. Screws
    3. Bondo
    4. Glue?
  15. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    I dont know much about this, but i'd say bondo. It will be the strongest.
  16. Dj Ovin
    7 Nov 2005
    What about Hysol or Epoxy ? Im using Hysol to glue the plexi to the side panel and stuff, works very well!
  17. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    Number 5) Bolts. :)
    H.B.
  18. TheGreatSatan
    5 Aug 2005
    But will epoxy hold Nickel plated cuffs to a painted bondo surface?
    So, I attached the panel to measure where I'm putting the window/stripe.
    And here's where it gonna go.
    And now I've moved on to painting the stripe on the top and right side.
  19. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Looking great! Why dont you make the window a bit longer donwards?
  20. TheGreatSatan
    5 Aug 2005
    Uh, good idea :)
    I've decided to go with Rivets and Epoxy. I will drill the bottom-side of the cuffs at the point where the two pieces come together (1). And I will drill a tiny hole in this area where there is already a pin (2).
    All holes will be under the cuffs and will be attached from the inside so that it won't be seen from the front.
    Here's kinda what it'll look like
    And here you can see the stripe drying
