Project Interceptor - Interactive Modding!!
Discussion in 'Project Logs' started by TheGreatSatan, 16 May 2007.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    7 Votes - Gray
    7 Votes - White
    2 Votes - Black
    Now what? I think I'm gonna go gray...
  2. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    hell yeah, make it gray
    oh and I love Bas's prison bars suggestion for the fan guards inside the cuffs...
  3. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    I vote black, but that's bound to lose.
  4. widmod
    widmod Minimodder
    9 Oct 2006
    where is the window planned?
    i supose one cause of the paint inside?
  5. TheGreatSatan
    5 Aug 2005
    That's a good idea, let's get that planned now. I'll start painting tonight and you guys kick around the window idea. At first I thought of just using a plain square , but lately I've been thinking of having the window follow the side stripe like this:
    Maybe I can go with a certain shape? Let me know.
  6. Dira
    Dira What's a Dremel?
    1 Sep 2005
    I think the painting needs alittle more life :) But not an easy job :p Maybe add a thin line of gray btw the black & white?
  7. TheGreatSatan
    5 Aug 2005
    I cut the two blowholes for the cuffs on the front.
    And here's kinda what it'll look like later.
    How should I fill in the area around the holes?
  8. ady1989
    ady1989 What's a Dremel?
    17 Oct 2004
    Normally I don't post much here, but I just had to say something :lol: . First off, the paint scheme needs to be more interesting! Maybe add some stripes, etc... I photoshopped some more details on your sketch. Also, PLEASE consider changing the blocky lights on top to a nice smooth arch-shape. Look at my pic to see what it would look like. It would be really sweet if you could make them light up in the pattern that cop cars have theirs light up (red flash twice, white flash twice, blue flash twice, all three flash white twice, repeat, etc - or something similar). I'm guessing the circuit woulden't be too hard to build for that, and it would add a LOT to the case mod. I think you should use clear frosted plexi for the light, and use colored superbright LED's to light it up. The sequence in which they flash should be fairly rapid. Good luck!
    Image: [​IMG]
  9. TheGreatSatan
    5 Aug 2005
    I do like your paint scheme, but I think too many people are getting the idea that this is a racecar and not just a plain cop car.
    Just so you see what's next...
    What should I do to fill this up?
    Here's some more pics of the inside......The I/O is part of the frame so I guess I'll have to cut it out.
    I guess this was for the HD or something?
    That had to go.
    The old motherboard was set in with built in standoffs. Obviously they never in a million years thought that it would be getting modded so I'll have to drill the new standoff holes myself.
    I checked my supplies because I thought I had gray paint. Turns out I just had a lot of SILVER. I'm going shopping tomorrow!
  10. jokkos
    10 May 2005
    Something that just crossed my mind...maybe you could add something in the line of the 'police line - do not cross' tape somehwere in the project? Like around the edges of the windows?
    Or do a contour in white chalk, maybe on the window itself?
  11. dacust
    dacust What's a Dremel?
    10 Mar 2007
    That's a good idea. The sketch looked awesome, BTW.
    I agree. But the graphics on many cop cars have gold stripe outlines. Maybe that could work? Or add a shield somewhere? I'm just throwing out ideas here, cause for myself, I like the plain simple bold look you have so far.
    I do agree the rough sketch you drew of the lights could use some design adjustments. If I was going to try for the lights ady1989 showed, I'd want it raised more, like the low-profile lights, not faired in like they drew. Or even up on brackets like on gutter mounts.
    Looking good!
  12. TheGreatSatan
    5 Aug 2005
    I will do a badge decal on the right side, I just haven't chosen one yet.
  13. TheGreatSatan
    5 Aug 2005
    I cut the blow holes all the way through.
    Then I used expanding foam for the front and back. After I shave it evenly, I'll cover up the top of it with either bondo or some type of fiberglass. We'll see.
  14. widmod
    widmod Minimodder
    9 Oct 2006
    yes thats just what i ment :naughty:
  15. BlueBerryBoy
    BlueBerryBoy What's a Dremel?
    22 May 2006
    The swedish police drove Porsche in the 70s...
    nice project
    btw, built-in standoffs are still standard in europe
  16. exitus
    exitus What's a Dremel?
    25 Apr 2007
    They knew what's good :D
    what is that that you put down in front?
  17. TheGreatSatan
    5 Aug 2005
    The Expanding foam you mean?
  18. TheGreatSatan
    5 Aug 2005
    The Bondo Begins!!
    Just thinking of the future.....
    I needed to clean the case so I let the rain do it for me.
  19. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I say put the POLICE stickers on the opposite side of the window going at the same angle as the white strip
  20. TheGreatSatan
    5 Aug 2005
    Next I have some small touch up to do. I have gloves on to keep that bondo smell off me.
    I also took the time to remove the old Netserver logos
    Here is where I'm at now. I still have a little more spot bondo'ing to do.
