Project Interceptor - Interactive Modding!!
Discussion in 'Project Logs' started by TheGreatSatan, 16 May 2007.
  1. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    Looking great :) Defo needs Red and Blue LEDS ;)
  2. dacust
    dacust What's a Dremel?
    10 Mar 2007
    I'm thinking it's because it's a car window. About the right size and position for a car window. And he's putting something like a shield/logo/words under it, like it would be under the window on a cop car. Only slanted. I think it's inspired.
  3. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    In that case - it will look great like it is. Never thought about it that way.
  4. fungry
    fungry What's a Dremel?
    14 May 2006
    shaping up more! nice white stripe. pretty nice :)
  5. widmod
    widmod Minimodder
    9 Oct 2006
    that came out really great
  6. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    I moved on to the clear coats.
  7. TheGreatSatan
    5 Aug 2005
    The stripe is pretty much done.
    Now time to prep the left panel to cutting, sanding, painting, etc. Should I put anything here?
  8. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Yes, the police logo
  9. widmod
    widmod Minimodder
    9 Oct 2006
    yea a police logo is a nce idea :thumb:
  10. TheGreatSatan
    5 Aug 2005
    Any suggestions? It's getting too hard to not stick to a specific department theme especially when it comes donwn to adding a logo. Should I just get a LAPD one?
  11. TheGreatSatan
    5 Aug 2005
    I've been trying to find a way to fill the void between the front and the case frame, so like many suggestions received I went with "bars". Let me know your honest opinion.
    I used the grill top that came with R2-D2's head. The fans are for effect. I'm not sure what colors I'm actually using. Any ideas?
    I attached it with a zip tie.
    Well?
  12. TNash
    TNash What's a Dremel?
    12 Mar 2007
    looks cool, like bars to a jail...
    hehe...Tandy box...
  13. wbdog206
    wbdog206 not me
    15 Jan 2007
    looks sweet
  14. Morphine-Kitty
    Morphine-Kitty Dead account.
    22 Apr 2007
    I think that one looks best by far. I honestly thought the police theme would come out looking corny, but its going awesome man. Keep it up :thumb:
  15. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Yup, the bars looks awesome!
  16. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Oh, yes, just get a normal LAPD one.
  17. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    I really like the bars :D i'm glad you used my idea :thumb:
  18. TheGreatSatan
    5 Aug 2005
    Thanks for sharing!
  19. TheGreatSatan
    5 Aug 2005
    More to do...
    The left window is done and the panel is receiving the white coat first.
    I also decided to paint three bay covers, because I was planning on adding a white DVD drive to the top
    BUT! then I had a problem. I forgot that the drives are attached via this slide-in cage.
    The top corner (This is the inside) has a piece of metal at the top where the floppy drive was.
    this is the outside...
    I'm not using a floppy drive, especially on top of the CD/DVD drives so I cut it out. Then another problem popped up.
    The drive doesn't fit!! I guess it needs rails?
    If I even get the drive in, what can fit in this slightly thinner 5.25 bay?
  20. Morphine-Kitty
    22 Apr 2007
    I would suggest an LCD screen, or maybe a custom emblem that says "Police" or perhaps your name "TheGreatSatan. Always good to promote your own name over the internet. :thumb:
