project: LN23 *** last pic : 22/09 ***
Discussion in 'Project Logs' started by tortuegeniale, 7 Mar 2004.
  1. tortuegeniale
    tortuegeniale What's a Dremel?
    7 Nov 2003
    LN23
    00.update : Intro
    01.update : Vumeter 02.update : External power part
    03.update : Fanbus
    04.update : Iron painting
    05.update : Dvd faceplate
    06.update : Ps2 plugs
    07.update : Dvd support
    08.update : Dvd part 1
    09.update : Dvd part 2
    10.update : Top part 1
    Burning Chrome
    I've seen cubic pc, pyramidal, spheric but not a lot of cylindric pc !
    So here the one that will become my future TV/divx/mp3 station :
    It's a linen basket :hehe: Lot of holes for airflow, plenty of space to include basic components of a pc
    During misc research, I found few computer concept art with cylindric case on applecollection website (this for example)
    stuff that I planned to put together:
    - µATX mobo with P3 1Ghz (integrated sound), 128MB PC133
    - Geforce 2 Mx200 (with tv-out)
    - tv card wintvgo
    - hdd 120Go seagate (1 to start, 1 or 2 more when money will rain)
    - 1 hdd rack
    - 3 or 4 PAPST 120mm fans
    - 145W PSU that was with the p3 mobo i got
    - a DVD player, maybe slot-in
    - Ati Remote Wonder / or usb IR receiver + basic remote control
    - IR keyboard
    - 1 or 2 liquid effect neon
    and for software:
    - Aurox Linux
    - MythTV (here is the real challenge!)
  2. tortuegeniale
    7 Nov 2003
    project: Burning Chrome
    let's start dremel !
    I cut the original µatx case to take the two 5'1/4 slots (1 for hdd rack, 1 for dvd)
    I want to put the two 5'1/4 slots at the bottom of the BC case
    plastic borders (originally for car windows) for safety
    the hole is larger than the effective size of 5'1/4 because I will hide this with a cover
    quick try
    chromed cover
    chromed cover with plastic border, but the result is not as good as I'd intended.. I'm searching for an alternative solution for covering dvd drive, maybe some wood ?
    didn't choose yet what is the more practical, dvd on top or rack on top
    temporary system to attach the mobo tray
  3. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    I have seen a few of the cylinder pcs onthe forum... looking good. I like the choice of cdroms... kkings of looks like a round g5... good work
  4. tortuegeniale
    7 Nov 2003
    really ? did u remind the names of these projects ?
  5. whiteagle
    whiteagle What's a Dremel?
    28 Aug 2003
    I always love to see cases in new and unique shapes. Something other than 6 flat sides is as refreshing as it not being beige. I really like the look of the chrome with the holes. I don't know what exactly you have planned, but it might look pretty cool as a pc/decorative lamp, with a couple of cold cathodes stuck in there. What ever you do, it's definitely off to a great start. :rock:
  6. Bradish
    Bradish What's a Dremel?
    7 Mar 2004
    nice looking... looks like it will turn out to be a bit of work... i hate working with round stuff in conjunction to computers :grr: hope it works out for ya, Happy Modding:dremel:!
  7. tortuegeniale
    7 Nov 2003
    As it will stay next to the tv, I don't want a lot of leds (or maybe with low intensity) but I planned to put a liquid effect neon inside the case that I will power on to use like my lava lamp, so effectively it can be considered as a pc/decorative lamp :thumb:
  8. KONIJN
    KONIJN What's a Dremel?
    30 Nov 2003
    little boy was one of them i think
  9. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    I do not remeber the exact names but there has been a few on the forums in the last month... go through the old posts and see.
  10. tortuegeniale
    7 Nov 2003
    oh yes i remember now.. project little boy is awesome !
  11. SEA
    SEA What's a Dremel?
    1 Feb 2004
    I like the way you think. My next project is going to be somewhat like that. :thumb:
  12. -=Nemes1S=-
    -=Nemes1S=- What's a Dremel?
    12 Feb 2003
    Did you get the name from the William Gibson novel?? just wondered :)
  13. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Damn thats sweet. It will look really cool light up green
  14. tortuegeniale
    7 Nov 2003
    yes :clap: !
  15. FourDee
    FourDee What's a Dremel?
    6 Mar 2004
  16. tortuegeniale
    7 Nov 2003
    Little Update
    PSU with a papst 120mm (there will be an airduct and a second fan 120mm)
    little test with mobo
    psu emplacement, not a lot of space between psu and hdd rack
    fitting-test with video and tv card, I dunno if I will add fixations
    two 3'1/2 for hdds, didn't defined where it gonna end up
    two vandals buttons, one with a protection (looking at my local electronic shop, I found the same protection as in ZapWizard Ammo pc mod, so I HAD to buy it :brrr: )
    + ampermeter to display the state (on/off) of the pc displaying amper and power used
    i'm thinking about the visual aspect, i found different solutions :
    - keep the chrome and doing covers with chromed objects
    - keep the chrome and doing covers with wood (like old cars: wood and chrome)
    - keep chrome and adding stylistic flames in color or rust
    - paint everything in one color
    - add a special effect (piloux's blackmesa mod is hypnotic) : rust, old bronze
    i've been searching about this last option :
    paint test : on the right, green old bronze, on the left, black paint + green old bronze
    i've bought some bronze paint so i will do same kind of test tomorrow
    this is the end : cold cathode will be green for a "tommyknockers powered" effect :D
  17. OilonBoy
    OilonBoy What's a Dremel?
    26 Jan 2004
    I would leave it as a chromed thingy 'cause it would suit better with the other apparatus that will be standing next to it... that's what I think at least... anyways I'm looking forward to this thread! :)
  18. Evilhue
    Evilhue What's a Dremel?
    11 Jan 2004
    very nice so far and I like what you have planned. Definately subscribing to this thread.
  19. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Looking good, :thumb:
    I like the amp meter.
  20. Skaal-tel
    Skaal-tel What's a Dremel?
    12 Jan 2004
    Nice work! and an absolutely fantastic idea... Terrific! :thumb:
    I've done some work with a round and assymetrical case myself.. (helmet)
    and I found my saviour to be plumber's epoxy, you can shape it safely with your fingers, it's like plasticene, but it dries and is as hard as steel. (the epoxy is in fact 90% steel) I don't know if you'll need it.. but it can be much easier to attach things with your fingers than finagling a bracket into place on a rounded object. Awesome idea!
