Project: Metal Slug - [Hardware @ Dec. 1st]
Discussion in 'Project Logs' started by Captain Slug, 5 Jan 2007.
  1. frogle79
    frogle79 What's a Dremel?
    28 Nov 2006
    Just a quick bit about that pump, they are kick ass and pump a lot of water for the money. But did you try it out before you mounted it? I have a Via Aqua in my compy and it made the most horrendous grinding noise when I first had it set up. Turns out some of those pond pumps have a anti clog feature that keeps them from burning up when you use them in a pond. The problem is when you use them in a closed circuit WC loop, the anti clog feature rattles and makes a hell a lot of a noise.
    Anyhow, if to figure out if you have that kind of pump, take out the impeller, hold the magnet end of it, and see if the impeller end spins about 3/4 of a turn. If yes, then you need to glue it in place or else you get the noise.
    Also, they have a hard time pushing thicker than water coolant. I tried mine out with 50/50 Zerex and water and the thing wouldn't start. I thinned out the mix to about 25/75 and it starts all the time.
    Your doing a bang up job, keep up the work. Hope this helps out.
  2. exo²
    exo² What's a Dremel?
    22 Dec 2006
    i like the idee
    looks good
    the drawings were very good
    keep going
  3. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Yes I'm aware of the anti-clog feature. I'll be fixing the impeller with epoxy some time this week prior to setting up the loop for the first time.
  4. Captain Slug
    25 Nov 2001
    Felt crappy all day sunday. I did manage to design a thingy.
    And get rid of the anti-clog feature on the pump impeller with super glue.
    Lots of stuff to do on Monday.
  5. frogle79
    28 Nov 2006
    :thumb: Good stuff
  6. Captain Slug
    25 Nov 2001
    Put the pump back together, trimmed the motherboard tray, machined the covers, added the plastic mesh, and test fitting it all inside the case.
    Now I'm working on the front, sides, and a support bracket for the video card.
  7. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Nice and CLEAN-- Looks Great!
  8. Captain Slug
    25 Nov 2001
    Lost momentum during the second half of today. Stupid weather...
    Finished the video card support bracket before quitting.
    I was originally going to use a card keeper, but since the video card installs in the first available slot that product wouldn't have provided any extra rigidity. My alternative is bolted directly onto the through-holes at the corners of the video card PCB.
    Thanks. It's only going to get progressively cleaner as I have very specific plans for hiding cables. The end goal being that absolutely no cables can be seen when the left side of the case is opened, and segregate the water-loop maintenance to one side of the case, and cable plugging/unplugging into the other.
    I also took great care to make sure that the motherboard cover will be easy to remove even when tubing is routed. That's why it was constructed from 4 separate pieces.
    Lots of little things to do before I can send the case to be powder coated.
  9. axscpu
    axscpu What's a Dremel?
    2 Jun 2006
    nice mod... I have the same motherboard and they work quite well.... never tried to overclock them though, keep it up... like how its coming along
  10. JazX101
    JazX101 What's a Dremel?
    27 Jun 2004
    May I ask what you are doing the CAD simulation with. Very nice results which actually look like the finished thing.
    Jaz_knos
  11. Captain Slug
    25 Nov 2001
    Alibre Xpress. It's free and easy to use.
    http://www.alibre.com/xpress/
    I can simply print out the individual parts of the CAD model on label paper then stick them to the sheets I cut to matching dimensions using my table saw.
  12. Captain Slug
    25 Nov 2001
    Put together the double power cord for the power supply and pump relay.
  13. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    That rocks! It looks military, almost bullet proof. Kinda like a black box...
    I want one. :p
  14. Captain Slug
    25 Nov 2001
    Finished the bay cover. This will help keep all of the cabling on one side of the case.
  15. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    this is looking very very nice... :thumb:
  16. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Duuude, this is looking insane! I think you may end up needing to do custom handles - they're starting to look a bit big.
  17. Guest-23315
    Guest-23315 Guest
    ever thought about painting the inside of the case ??
  18. JazX101
    27 Jun 2004
    Class, thanks, will have a looksee.
    Excelent work, looks to be very interesting.
    Jaz_knos
  19. Snafu-X-
    Snafu-X- What's a Dremel?
    27 May 2005
    Is the goal to have a window to a bunch of smooth surfaces? It looks extremely well done, but I'm just not understanding your goal I think. If the inside is largely a featureless expanse, where's the visual interest? Or is minimalism what you're trying to achieve? I do love the exterior so far though, looks great.
  20. galimim
    galimim What's a Dremel?
    7 Jan 2007
    Wow. Will be there any lights in it??
