Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Ok guys my long awaited project is finally here, but I must say I'm still not sure on the name so if anyone has any better suggestions please go ahead and reveal them.
    This all started out as a design to try and really push my skills and the ideas behind a computer case and also as a way of promoting my shop.
    The design started off as quite a simple modular idea
    But then it quickly evolved into Modularis Evolution
    So as I have got my workshop all sorted out and ready to mod I grabbed one of my sheets of 2'x4' aluminium and marked it ready for cutting (please excuse the blur i didnt have my tripod to hand)
    I quickly got that cut up with my trusty jigsaw and moved onto the bending with my amazing 30" manual sheet metal brake.
    So thats one side done on to the next
    I then cut a piece for the top - this will be the removable section for access to the mobo tray.
    I then grabbed one of my spare motherboard trays and put it in for a very rough test fit - note it is not going to be that low down when it is mounted.
    So unfortunately that is all I had time for today but dont worry I will be doing some more to it on Monday.
    Plan for Monday is to get the window in the top section cut and maybe the front and back panels cut.
    Until next time
    Josh
  2. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    looking mint there :thumb:
    how about Project OverFlow?
    It would nicely describe the watercooling flowing over into other modules :)
  3. x06jsp
    2 Apr 2007
    Thats quite cool i think for now i will keep the name and put together the names suggested and do a poll.
    And thanks :thumb:
  4. Guest-23315
    Guest-23315 Guest
    Nice bending so far.
  5. x06jsp
    2 Apr 2007
    Thanks mankz.
    It comes from being very patient :thumb:
  6. cc3d
    cc3d It's a mod mod world
    14 Jan 2008
    Good job and a quick start. Could you show a little more as to how you are getting the bends so precisely? I suppose you are using a break of some sort but I'm missing that somewhere.
  7. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    Josh is using a 30" bending brake
  8. x06jsp
    2 Apr 2007
    i will post up a more detailed demo of what i go through for each bend when i get onto the next module :thumb: thanks guys !
  9. angelorus2000
    angelorus2000 What's a Dremel?
    14 Nov 2003
    wonderfull begining.
    mod on!!! :dremel:
  10. frizzeh
    frizzeh What's a Dremel?
    5 Jul 2008
    Are you staying with the black and green theme? I've always loved a combination of those two colours together :)
    Is that little green dot at the front of the large module the power switch? Are you going for a bulgin type switch or coming up with one of your own design?
    Which module will the power supply be housed in? I can't see any room for it in the main module unless it goes under the motherboard tray, as you said it would be mounted higher in the final version.
    Would it be possible to label what is going in each module? will be much easier for the rest of us onlookers to see where you are going with the design :)
  11. x06jsp
    2 Apr 2007
    Thanks guys :thumb:
    Yes im going with green and black and there will be a twist to show later on in the mod...
    The green dot will be a vandal resistant switch like the bulgins
    The psu will be in the lower right hand side module. i will add a labeled diagram on my next update.
    Josh :thumb:
  12. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    can't wait to see the outcome:)
    *Subscribed*
  13. x06jsp
    2 Apr 2007
    thanks bigsharn :thumb:
    I will have another update this afternoon this is moving along quite quickly thankfully.
    Josh
  14. x06jsp
    2 Apr 2007
    Well I'm back for another update, Unfortunately i didn't get quite as much as i was hoping done today but nether the less i have an update anyway.
    Firstly here is the top panel marked for cutting out the window.
    And after a short session on the scroll saw before filing we get this
    And after a bit of filing we are left with this
    But im not too sure on this i think it may be a bit small for this case and i also havent rounded off the corners so i think i will enlarge the hole and round off the corners aswell.
    And mounted to the rest of the case
    Now is the time to move on to the front and back panels so here you go front panel cut out
    Front and back panels cut out
    And then onto the back panel i/o cutout (sorry didnt get any pics of marking out etc etc
    But here it is in the vice being filed
    And unfortunately that's all for today more tomorrow.
    Hope you enjoy
    Josh
  15. bigsharn
    9 May 2008
    Looking good looks nice and tidy mounted on the rest of the motherbard compartment:thumb
  16. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    looking great
  17. x06jsp
    2 Apr 2007
    Thanks guys :thumb:
  18. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    promising start.
    I have been playing around with a similar idea...but not that many 'pods', just two or three. I'm interested how it'll turn out.
  19. x06jsp
    2 Apr 2007
    Thanks for the comment jokkos :thumb: im hoping this will turn out as good as the rendering of it (maybe better )
  20. sock58
    sock58 Budget mods
    6 Jun 2008
    aint you the guy who ripped off a compay sponsoring you on the aqua pc threads???
