Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Very nice design !
    and the build quality is realy amayzing !!
    but the design kinda reminds me of dutchcedar's casemod.
    keep up the good work !! :thumb:
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Thanks dark :thumb:
    and it was inspired by cedar but in no way copied and very very different
  3. x06jsp
    2 Apr 2007
    Ok guys well i tried out drilling the holes through the support and it worked out quite well but i noticed if you drill all the way through you will chip the side that the drill comes through whereas if you drill most the way through so that the drill is just poking through then turn over and drill the other way you dont chip it.
    I then decided to move on to the next module.... so here goes
    step by step :
    1. i mark out the piece that will be bent
    2. then cut it out
    3. then grab your 30"bending brake
    4. mark where you want it bent
    5. start bending untill you think its about right
    6. grab your set square with a handy 45degree angle on it
    7. check angle its not quite right just bend some more and if its too bent then just push it back with your hand.
    8. repeat stages 4-7
    and that is it for today guys.
    hope you enjoyed it
    Josh
  4. p3ri0d
    p3ri0d What's a Dremel?
    9 Jul 2008
    Hmm, what's that?
  5. x06jsp
    2 Apr 2007
    It is the starting of the psu housing (the right hand lower module)
  6. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Nice designs, nice execution! :)
  7. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    i like the work with perspex - toxic green with black is one of my favourite color schemes :) Good Job so far! I will be watching this one for sure!
  8. p3ri0d
    9 Jul 2008
    Oh ok i see, it's gonna be great :D (Do i even need to say that? lol)
  9. x06jsp
    2 Apr 2007
    Thanks guys :thumb: its great to hear people are liking my mod :D
  10. Cheapskate
    13 May 2007
    The layered look rules.:D
    You say you had trouble with the tile saw? Was it the plastic protective layer, or water in the face syndrome?
    It looks like a little water could help your drilling too. Either that or the wood under the material was too soft.
    When I asked about 'gaps' I meant 'seams.' I was kinda sleepy. My punctuation and vocabulary goes away when I'm sleepy.
  11. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Liking's a bit of an understatement from the looks of it:hehe:
    well, from me, definitely
  12. x06jsp
    2 Apr 2007
    Thanks guys :thumb:
    and cheap it just wouldnt cut straight i ran it along the fence but then as soon as the first part got past the saw it started to go off to the right...
    and i did use water with the drilling. but i dont mind about the drilling thats easy enough to sort.
    Josh
  13. ComputerKing
    8 Sep 2006
    Dude You are doing a KICKASS job here. I Don't know how I didn't tell you that from long time :D but it rocks, Keep Us updated. ROCK ON!
  14. x06jsp
    2 Apr 2007
    Lol thanks ck there will be an update tomorrow night aswell :thumb:
  15. x06jsp
    2 Apr 2007
    ok guys time for another update!!!
    ok the rest of the psu housing has been bent!
    and the side bent
    And on the side
    And now just a quick mock up using parcel tape to show you lovely people how this is going together
    Its pretty big!
    Hdd housing alu marked out
    And bent and joined
    and put on top of the psu housing to show how it goes
    I hope you enjoyed it and tune in tomorrow :D
    Josh
  16. bigsharn
    9 May 2008
    Looking good:)
    But how are you going to drill the holes in there for the cables to fit if the HDD housing is fully built?:confused:
    Unless it's not fully built and I'm a dipstick for not noticing?:p
  17. ComputerKing
    8 Sep 2006
    Hot Hot hot. Good job my buddy. I hope you end this project before world end :(
  18. x06jsp
    2 Apr 2007
    Lol ck!! it wont take too long to complete :up:
    And bigsharn all i have to do is cut a hole in one of the sides for the cables its not too hard... and its not completed yet just bent to the right shape :thumb:
    Josh
  19. p3ri0d
    9 Jul 2008
    going on nice ^^
  20. x06jsp
    2 Apr 2007
    thankyou :thumb:
