Scratch Build – Complete Project Pupp3r
Discussion in 'Project Logs' started by MLyons, 7 Aug 2019.
  1. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    At long last I've decided to start the build log of my scratch built tiny PC. The name is project Pupp3r for obvious reasons. The goal is to cram as much performance without throttling into as small of a space as possible while making it strong enough to handle going to LAN events while also looking good.
    I'd like to give a big thanks to Corsair who have been kind enough to support this project by supplying:
    H100i RGB PLATINUM SE
    VENGENCE RGB PRO 2x8GB 3200MHz
    SF750
    MP510 480GB
    LL120 RGB triple pack
    The plan is to paint the power supply white to fit in with the builds internal theme. The case will be as white as possible on the inside and as dark as possible on the outside. This is for a party trick the case will have but won't be revealed until I've checked if it will work.
    The Case will be built of 5mm thick acrylic and held together using metal cubes with bolts as can be seen in the image below.
    More updates soon but for now I need to get back to doing my actual job :thumb:.
    adidan and Cheapskate like this.
  2. Kiyosen
    Kiyosen What's a Dremel?
    17 Jul 2019
    Nice
    MLyons likes this.
  3. DesignDoge
    DesignDoge What's a Dremel?
    18 Jul 2018
    :clap::clap::clap:
    MLyons likes this.
  4. maxlxyd
    maxlxyd What's a Dremel?
    4 Oct 2018
    :eeek:
    MLyons likes this.
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    :lol:
    MLyons likes this.
  6. Cheapskate
    13 May 2007
    :lol: Our supreme overlord posts a log with no modding. I just hope this doesn't go the way of Nexxo and you abdicate and quit half way through. The serf community will lose heart.
    Also, You've inspired me to name my next rig 'PUPthr0r'.
    The_Crapman likes this.
  7. MLyons
    3 Mar 2017
    with free parts and dogbert in the office I doubt I'll stall. Hope to have the screws and bolts by the weekend. The biggest block will be getting an ITX board.
    If any companies are reading pls send me an AM4 ITX board. k thx.
  8. adidan
    25 Mar 2009
    A Doge's gonna doge.
    MLyons and Guest-44638 like this.
  9. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    I need a sponsor
  10. Cheapskate
    13 May 2007
    I don't know...I fear the project could slog to a halt just because his neighbors cooked bacon.
    MLyons likes this.
  11. MLyons
    3 Mar 2017
    In this update I'll be posting the design of the case. As I'm shocking with 3D CAD software I've decided to do it in 2D but you get a sense for the layout pretty easily.
    Now this design was done and the acrylic was ordered before the stuff from corsair came in so the gaps are actually going to be smaller. The only saving grace is that the 140mm fans were made at 30mm instead of the actual height of 25mm and I've swapped to 120 mm fans. This gives me an extra 10mm to play with plus that small gap at the top to fit the radiator in. If this isn't possible then I'll have to switch to some slim fans. The gap on the right of the PSU from the front is currently in a to be decided state. The plan is to run cables behind there but I'm not 100% sure if I'm going to need to yet. The one part that I'm undecided on and is actually pretty critical is how I'm going to mount the PSU. Currently I'm thinking a shelf of some kind. If not then I'll rotate the build 90 degrees and have the PSU on the bottom.
    Oh and I've ordered 400 bolts spread over 2 variants as I'm unsure if i want to have them countersunk yet and they were cheap.
  12. Cheapskate
    13 May 2007
    I don't see any cubes in your cad. I guess potentially you could chop a corner off the fans/ file down the unused side of the cubes.
    Wire space is the only thing I wouldn't skimp on. They may be a little flexible, but they do NOT compress. I'd leave a good inch of space on the cable side of the PSU.
  13. MLyons
    3 Mar 2017
    yh I forgot about the cubes as it was 2d but with the now 120mm cubes instead of 140mm i should be fine... hopefully.
  14. MLyons
    3 Mar 2017
    So after mocking up the design in 2D I had a spare half an hour at the bit-tech HQ while benchmarking one HotBoi GPU and came up with these. It shows that there should just be enough space. Now I'll point out that these were done before corsair gave me the goodies and therefore doesn't account for the rad... Yikes. IMG_20190712_163039_841.jpg IMG_20190712_163039_856.jpg IMG_20190712_143833.jpg
    Tonight when it's not 34C in the summerhouse I'll drill the acrylic and hopefully have the main structure of the case put together.
  15. The_Crapman
    5 Dec 2011
    Looks done to me :thumb: PSU going to go in the gap next to the ram?
    adidan likes this.
  16. MLyons
    3 Mar 2017
    That's the plan. Still 33c in the shed so drilling is on hold still
  17. Cheapskate
    13 May 2007
    The local weatherman would call that "warm." :lol: You don't have an old block of wood you can use as a mini workspace in the house?
  18. MLyons
    3 Mar 2017
    I've using an old kitchenwork top as that's what I have in the shed. The house is completely full and why we build the shed for me to live in in the firstplace.
  19. MLyons
    3 Mar 2017
    Wonder what's happening at the bit-tech HQ today? :dremel:
    maxlxyd likes this.
  20. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    A reportable incident
    MLyons likes this.
