Project:Rise Lord Vader (FKA RLV) Update 12/7/06
Discussion in 'Project Logs' started by best49erfan, 2 Sep 2006.
  1. best49erfan
    best49erfan What's a Dremel?
    27 Dec 2002
    Parts:
    The motherboard JetWay J7F2WE1G5D-OC-LF 1.5Ghz Via C7 processor
    Power Supply: Pico PSU 120W
    Slim line to IDE adapter
    Mobo adapter
    Hard drive and 2.5 to 3.5" adapter
    Case fan
    Short IDE cable made with the help of fellow BTers
    Temporary Mobo tray
    This is only temp because I made a few mistakes that gave the tray some extra holes in it.
    USB ports
    USB & Firewire ports
    USB & Firewire template
    This was the PCI slot part but I am using it as a cutting guide for the ports.
    VGA Cable
    Audio cable
    Cat5 Cable
    Cat5 Jack
    Cat5 Plate
    DVD drive
    Memory
    power supply adapter
    rounded IDE cable
    Still Need: Windows
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
  3. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Yup
    Doesn't this need more in it?
  4. best49erfan
    27 Dec 2002
    Yes
    what do you mean?
  5. AJB2K3
    12 Dec 2005
    When i first saw this mod all that was there was a tiny bit of text and a single picture.
    Now theres more to it.
    What os are you gunna run on it?
  6. [<x>] Kiyusoma
    [<x>] Kiyusoma Deus Ex Machina
    16 Jun 2004
    i very interested in this project.
    how does that board perform? any benchmarks?
  7. eegg
    eegg What's a Dremel?
    29 Aug 2006
    what is that psu??
  8. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    Its very good mobo/cpu set for Media Center or light surfing/mp3 machinae...
    and that psu looks like pico-psu... Am i right?
  9. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    that indeed is a Pico PSU, but which one? the 80Watt or the 120Watt version?
    What is that ... thing... you are going to put this computer inside?
  10. Zheele
    Zheele What's a Dremel?
    17 Feb 2004
    Not to be rude or anything but if you read the first post in this thread you'll get answers to your questions...
    That said, looks like an interesting project. I always wished I had the cash to do a Mini-ITX project.
  11. LuitvD
    13 Aug 2006
    :doh: stupid, how could I have missed that :p
    It indeed is a nice project. Zheele: A Mini-ITX isn't as expensive as modding a normal computer...
  12. best49erfan
    27 Dec 2002
    Me too! This thing is expensive!
    More than likely, XP Home.
    That is a very good question. :D
  13. LuitvD
    13 Aug 2006
    And do you have the answer to that qu... wait... your answer will be "yes I have"... :)
    Do you want to tell us somewhere soon? :D
    Then tell us! :p
  14. best49erfan
    27 Dec 2002
    That question will be answered soon enough in a....different manner than the norm....
  15. best49erfan
    27 Dec 2002
    Now for the start of the Project!!!!
    First thing I did was start cutting out part of the case where the mother board would fit. It was not too hard, but instead of using a :dremel:, I should
    have just used a razor blade. I think the cutout areas would have looked better. I did have to cut out some by hand because the :dremel: couldnt reach it.
    I cut out the area, but left 1/2" for the adapters to attach to
    The cutout area
    I cut, drilled, and tapped the mobo adapters to fit the case. they are drilled out M4 for the holes that attach to the case and tapped to M3 for the tray to
    attach to.
    Adapters installed
    For the holes attaching the adapters to the case, I had to hold the drill bit by hand. My thumb still hurts!
    Next was to mount the mobo tray to the case. I just used some M4 button cap bolts. Then the motherboard was to be mounted on the standoffs.
    Mobo Mounted
    After that, I mounted the PSU
    Pico PSU mounted
    The short IDE cable was for the hard drive
    Here it is after I tested it on my desktop to make sure I didn't mess it up!
    That is all I have for now till I upload more pics!
    Alright! got a little more work done on it.
    First thing I did was drill the whole for the DC adapter for the PICO PSU. I used a 8mm drill bit.
    Hole Cut!
    Then I installed the plug.
    Plug installed
    After this was completed, the templates for the USB and Firewire ports were installed. They were cut out using a razor knife
    Templates mounted
    Now the ports are mounted
    Ports finished
    And then the fit of the ports is tested.....success!
    Port Test
    that is all for the work that has been done, but I did get some more stuff for later and I am awaiting the VGA cable to be delivered.
    Here is a set of bits that I got the other day
    New sheet of Lexan to replace current Mobo tray
    Lexan
    Cat5e cable to extend the Cat5 port to the back of the case
    Cat5e cable
    Cat5e quickport
    Also a single port quickport wall plate. They only had almond, but this does not matter because it will not be visible from the outside.
    Wallplate
    Of course, I had to work, and my daughter wanted me to stay home so she could help me build this PC. Well that lead to.......
    An upset daughter
    More updates to come!
  16. Muon
    Muon What's a Dremel?
    1 Dec 2004
    does this case have something to do with her? considering u haven't told us much... :confused:
  17. best49erfan
    27 Dec 2002
    :read:
    No. She just wanted to help. There is only one thing I have not said about the project. come on! You gotta have some mystery.
    I will be nice and give 5 clues. here is the first one
    1. The case was made in 1980
  18. Heero195
    Heero195 What's a Dremel?
    12 Jun 2006
    I've been wondering the same. Mysteries are all well and good. must have details
  19. gebrek
    gebrek What's a Dremel?
    11 Apr 2005
    Is it a Tandy?
  20. hydro_electric_655
    13 Jul 2006
    [​IMG] I think that is the case at least that kind of step stool. Just my guess. more clues.
