Project Soylent Green: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 19 Oct 2004.
  1. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    well, if BN is anything to go by (huge fan here) ill be subscribing to this aswell
  2. adio
    adio New Member
    23 Sep 2004
    This case is going to be great, chrome is the best way to go, it is easily worth the money. I have subscribed to this thread and i cant wait to see what you do next. I was thinking about getting a FMJ for my 1048 but i was wodnering what the dimensions of it were first since my current case is pretty limited on space. Modsquad if there is anyway you could just measure it real fast whenever you get a chance let me know and i would really appreciate it. :D :dremel:
  3. apHytHiaTe
    apHytHiaTe New Member
    9 Jul 2004
    thx!
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I got quite a bit of work done on the project over the weekend.. Painted and installed the Innovatek HPPS 12v pump in the the Aqua-Computer Full Metal Jacket (sorry Adio, the FMJ is not at my location, I will get you those dimensions ASAP). I retapped/threaded the FMJ to accept stainless 6-32 hexhead bolts.
    I also cut the top window in the case. The window WILL NOT mount the Innovatek reservoir, it will serve as an cover plate. The reservoir will be mounted from underneath with another green UV acrylic panel that well be bolted to the case (via more stainless bolts). I also made up a green UV side window (may get replaced with a laser-etched one). Just a teaser picture.. Many more soon..
    That is some serious green UV acrylic, just overhead fluorescent light.. Man the stuff catches the light well.. Many more pictures to come.
  5. Thrillseekah
    Thrillseekah New Member
    21 Oct 2004
    Would love to see it with uv in it and then in the dark :D
  6. Firehed
    15 Feb 2004
    Wow, that hurts my eyes from brightness and it's daytime.
  7. Isuo
    Isuo New Member
    13 Oct 2004
    Praying to see more...
  8. TheDon
    TheDon New Member
    21 Oct 2003
    Very loud.. I like it......
  9. modsquad
    27 Feb 2004
    Top window Cut
    OK this is the step-by-step top window installation. The first thing was to tape off the hole top of the case then "mock-up" the window. Measure twice, cut once..
    Lets cut.. Using a jigsaw for the "ruff cut" then the dremel with a grinding wheel to finish it off.
    And the finished top window. The pictured acrylic panel will only serve as cover plate. The Innovatek reservoir will be mounted in another green UV acrylic panel bolted to the case from underneath.
    This is the first time I have worked with green UV acrylic. The stuff is "unreal" any cut edge glows like Chernobyl........
    I will have a side window update soon. As well as a hardware update, both the Alphacool CPU block and Aqua-Computer GPU block are in my hands. Both look GREAT. More very soon......
  10. KAMIKAZE-FREAK
    KAMIKAZE-FREAK New Member
    30 May 2004
    i hope very soon = this evening
  11. modsquad
    27 Feb 2004
    I will try.....
  12. hmekk
    hmekk New Member
    17 Jul 2004
    :jawdrop: :jawdrop:
    i want that plexy ....
    :jawdrop: :jawdrop:
  13. nat83c
    nat83c New Member
    25 Jun 2003
    Cool. Totally awesome
  14. modsquad
    27 Feb 2004
    http://www.cuttingedgecasemods.com/
    I am by no means a Acrylic expert. I have worked with red,blue and clear. When I first cut this stuff, I was shocked!! Perhaps all UV acrylic is like this I can't say. This being my first case with the stuff I can only say (in all honesty) it looks even better in person.
  15. TheDon
    TheDon New Member
    21 Oct 2003
    That stuff looks radioactive.. Kinda Funky. All you need is a disco ball and you can start giving kids seizures. I really like the design of the window. .
    The thing that I like is that with any good modder alcohol isn't too far from the genius
  16. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Hey looks a great mod. Done nice work so far...lets hope you can carry it on ;). Hope all run's smooth (now there's a hope). Good job so far mate.
  17. unrealhippie
    unrealhippie New Member
    24 Jul 2004
    nice, very nice...
    how much would it cost to have an entire case done in chrome :idea:
    Oh and it looks like you could setup a business with the amazing work your doing! :D
  18. -Enforcer-5716M4
    -Enforcer-5716M4 New Member
    1 Sep 2004
    Where did you get these pimp chrome covers?
  19. DesertFox
    DesertFox Member
    25 Oct 2004
    So when can we start placing orders?! :D
  20. darklord
    darklord New Member
    12 Jul 2003
    ok, I am abit crosseye'd as I have just gone through both your projects :eeek: , amazing work MS.
