Project Soylent Green: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 19 Oct 2004.
  1. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    I want those boobs ...
    :jawdrop: :jawdrop:
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Side window update
    As promised, the side window update. The SilverStone case has the side window cut from the factory, it was a simple matter of unbolting the clear one and using it as a template for the green uv.
    Then cut it out using the jigsaw. Very EZ mod. I don't think it took mre than a half hour to complete.
    And a few case shots.
    Up next will be the acrylic plate to mount the Innovatek reservoir to the case ( I will not be using the aluminum mounting plate in the pictures, it will be bolted right to the green acrylic).
  3. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    I LOVE THAT UV GREEN PLEXI!!!!!!!!!!!!! :rock: :rock: :rock: :drool:
    Looking so cool
  4. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    why dont make a uv plexi mounting plate for the reservoir?
  5. modsquad
    27 Feb 2004
    Basically that is what I am going to do. It's hard to explain, just hold off for the next up date and you will see what I am talking about.
    I also need to do a hardware update on the H20 blocks that came in.
    More Soon..
  6. KAMIKAZE-FREAK
    30 May 2004
    i cant wait :D
  7. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    Great mod so far! That plexi is amazing. I'm drooling over the chrome.
    I'm worried about you mounting the reservoir using the plexi instead of the supplied metal plate. Do you have any concerns about the plexi's ability to hold it? That 1/8" plexi isn't very strong, I would double it up at least under the reservoir. But then again I tend to over-build :).
    Looking good, oh and thanks for the plexi resource, I'll be looking them up for my next project!
  8. NoodleNogin
    NoodleNogin What's a Dremel?
    11 Jun 2004
    Um..chrome..green plexi.. :idea: are you sure your name ain't G-Gnome?
  9. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    please dont start saying he is copying others its not like g gnome patented chrome and green. just dont want to hear another war about copying ideas
  10. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    omg, did you not realise that green looks nice on black? and he has everything chrome on black narcissus?
    And how is it copying really - its called inspiration.
    Thats like the 1st person with a black case, saying no one else is allowed black... :hehe:
    Thats like the first person to buy an FX-55 saying no one else is allowed to buy an FX-55.
    Why would you publish your work on the net, and expect elements not to be used by other people. It would give me great pride if others used my idea's, and also to try and improve upon them.
  11. [ShoNuff]
    [ShoNuff] Minimodder
    10 Sep 2004
    You have an uncanny skill for this type of work
    O.K., I have an idea...
    "Modsquads Performance PC's" where one of kind high performance PC's are born.
    Yes...No :hip:
  12. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Looks amazing. I am using uv green in my mod right now, but my stuff doesn't glow like that., wish it did. :(
  13. modsquad
    27 Feb 2004
    You and I think alike. The mounting plate will be 2 sheets of acrylic (the size of the top of the case). I may just pickup some 1/4" thick clear and use that. I need to get longer bolts for the reservoir before moving forward.
    MS
  14. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    What size fittings does the X800 block have? Any chance of getting 1/2" fittings in it?
  15. modsquad
    27 Feb 2004
    It uses G1/8" (small thread). It is like most German watercooled equipment, small bore. I know Aqua-Computer makes a G1/8" to 10mm barb that would work, but I would think it would be h20 restrictive in an 1/2" system.
  16. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Im loving both of your mods! Looking great, keep up the noice work
  17. modsquad
    27 Feb 2004
    Hardware Update
    Let's start with the H20 blocks. The Aqua-Computer AquagrATIx800. An all aluminium GPU block, as would be expected from AQ--high quality.
    For CPU and Northbridge, the Aqua-Computer Cuplex Pro and Twinplex.
    To keep track of the temps on those blocks the Innovatek Fan-O-Matic LCD. This unit was originaly slated to go into project BN, but found it's way to SG. It is a very nice unit. It will do everything you would expect of an LCD (aka Martix Orbital) plus give the user a H20 flow rate in Litres per minute ( with Innoavtek's flow meter).
    With the Black face plate out of stock, I painted the stock one satin black.
    I still need to make up a green UV acrylic face plate to screen the display from blue/white to green/white......soon.
    I ordered the 1/4" clear acrylic as well as the need stainless bolts to get the reservoir installed next weekend.....Until then....
  18. crimandevil
    crimandevil What's a Dremel?
    30 Jun 2004
    That Aquagr block looks absolutely amazing. :jawdrop:
  19. modsquad
    27 Feb 2004
    New Product from AQ. Aqua-Computer is the Rolls Royce of water cooling, there is none better in my book........That block came with no instructions, just a bag-o-bolts. Not having an ATI x800 video card I can't say, but I hope it EZ to install.......
  20. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    looking sweet man good luck with the mod..
    - Sc0rian
