Case Mod - In Progress Project Styx - Updated 4th March
Discussion in 'Project Logs' started by stonedsurd, 30 Jul 2009.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Man I really like your loop design its very neat and at the same time WOW!!! And your panels are really interesting! I wonder though, the fill port, will it stay on the bottom?
    stonedsurd likes this.
  2. stonedsurd
    11 Mar 2009
    Thanks for the view and the comment AnG3L. I was beginning to despair :p
    That fillport actually serves as a drain port. The first time I messed with WC'ing (someone else's rig) the one thing I noticed was that draining/cleaning a loop is a royal pain. So I'm determined to keep it simple and neat in my own first attempt.
  3. stonedsurd
    11 Mar 2009
    Powdercoated stuff arriving tomorrow. Looks like this one's going to be down to the wire.
    Stuff left to do:
    1. New PSU (my DA700 has not yet been delivered :grr:)
    2. Cut and paint the mesh shelf to accommodate the tubing/fittings - has to be done tomorrow because the chassis is at the powdercoater's
    3. Put it together and fill up the loop :)
    This is going to be down to the wire (I fly back to univ on the 25th morning :p)
    Anyway, I did some final touch-ups and the like. Found the aluminum faceplate for the front I/O ports, so that if getting stuck onto the ex-ghetto I/O plate. Painted the mesh that holds up the res and got some rubber slabs for some SERIOUS vibration-isolating pump mounting :D
    Mesh:
    The rubber slabs - this is the rubber that's fed into dies before being squished into stuff like o-rings, bushings and such:
    They're all between 12-13mm thick, except one which is 5mm:
    When you stack them up like this:
    You get a pretty neat (if slightly untidy) pump mount!
    And here's a shot of a lot of clampage getting the I/O ports epoxied up:
    One more update tonight (when the clamps come off). Then the finale tomorrow. Hopefully I can get it wrapped up in 24-odd hours :worried:
  4. stonedsurd
    11 Mar 2009
    Last update before I crash.
    I forgot, I got a bunch of M6 socket head bolts for the switchplate. Also, the top I/O plate is done.
    Switchplate:
    And again, for kicks :p :
    I/O plate:
    Now what I would like to know is this - the I/O plate has some obvious scratches, along with being upside-down when mounted. Should I leave it as it is in the pictures or just give it a couple of coats of black? I'm not really fussed about getting rid of the markings - they're for n00bs anyway :hehe:
  5. The boy 4rm oz
    10 Apr 2008
    Looking really good mate, keep it up.
  6. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    very goodlooking loop, especially for adding GPU fullcover block in the future :)
  7. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    I love the Switchplate
    i think you should try to get rid of the scratches
  8. stonedsurd
    11 Mar 2009
    Thanks!
    Yep, that's on the cards as soon as the GT300 vs HD58xx battle has a winner :) Thanks!
    I would, but no time. I think when I come back for vacations I'll try a belt sander.
    Anyway, I am working to put everything together. The clock is ticking.
    Here are some pics while the rad and block get a little vinegar bath.
    Chassis back from powdercoaters:
    Front panel:
    I/O masked before being sprayed:
    New power supply (CM Silent Pro M600):
    I think an update or two from now I'll be done :)
  9. The boy 4rm oz
    10 Apr 2008
    Nice new PSU :thumb:.
  10. AnG3L
    19 Mar 2009
    Matey matey I love your progress so far! Can I suggest something? You can create an acrylic box (black not transparent) to put all of these foams inside and put the pump at the top.
    You can put the pump lower into the box just a tiny bit for the foams not to be visible!
    This is MHO! All the rest are going excellent!!!! Go on buddy!!
  11. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    +1 hide that foam! Looking really nice bud :D
  12. stonedsurd
    11 Mar 2009
    Thanks! But I'm still a bit bummed that the DA700 STILL HASN'T REACHED!
    Yeah, I was thinking I'll do an acrylic box or mesh covers for the sides to hide the ugly edges. :thumb:
    Thanks!
    But on the other hand, I epic failed.
    Had to leave for Univ with the whole thing put together, looking fine and all that, but the loop was left unfilled because I simply did not have the time.
    Hopefully will get this completed over winter break.
  13. stonedsurd
    11 Mar 2009
    Right, just thought I'd let you folks know that I've resumed work on this. I was in the middle of partially dismantling the rig when I realized that my last update had been woefully inadequate in terms of pictures. So here are a few for those of you who are curious to see what she looks like.
    This last one if a bit of a dodgy stitch I tried of the previous two images. :p
    I'm currently in the process of getting another power supply and making a new hex mesh bottom partition, not to mention trying to lay me hands on another side panel so I can try not to frak the whole thing up again :p
    Also, UV and red CCFLs are gone, going to get some SMD LED strips instead :thumb:
  14. stonedsurd
    11 Mar 2009
    Obviously I lied when I said this would take me a week to wrap up.
    Besides that pesky annoyance known as 'real life' coming in the way, I was also basically just lazy. Anyway, I got my PSU today after a lot of shilly-shallying on my part. That was all the impetus I needed, so I got down to sleeving :thumb:
    Removing the wires from the 8-pin connector:
    One set of wires removed:
    All done:
    Injuries of teh day:
    Sunbeam really needs to watch the safety of their tools. Chock-full of sharp edges tearing my hands up :grr:
    Also daisy-chained my rad fans so I wouldn't have to deal with a ton of extra cables:
    That's all folks - will try and be more regular from now on :blush:
  15. rakesh_sharma23
    rakesh_sharma23 Minimodder
    2 Sep 2007
    :thumb: That's a hell o good work.....
    Super sleeving....
  16. AnG3L
    19 Mar 2009
    You see, thats better now! I didnt see that update you did with the mesh, thats very nice and clean! Be more careful with the tools, but you are right, sunbeam and not only, should make better and more functional tool, especially that ATX remover must be redesigned I believe. Mod on!
  17. stonedsurd
    11 Mar 2009
    Thanks Rakesh!
    Yep, I've always wanted a 'false floor' in a case, and this one serves a dual purpose :D
  18. stonedsurd
    11 Mar 2009
    Waterblock (not really an update)
    Got the waterblock for my 5870, will mount it up as soon as I get the card off the LN2 bench :D
    Yes, I know this hardly counts as an update but I need to keep this worklog alive :worried:
  19. MugenUK
    MugenUK What's a Dremel?
    5 Aug 2008
    Loving the look of this so far mate, will check back soon.
  20. ashtefere
    ashtefere What's a Dremel?
    29 Nov 2009
    Duuuuuude....
    That frontpanel is fracking gorgeous.
    I love it!
    Very murderboxish, clean, minimal, and industrial. Nice work!
    -Ash
