Case Mod - In Progress Project: TJ 180
Discussion in 'Project Logs' started by WiK1d, 24 Dec 2006.
  1. WiK1d
    WiK1d What's a Dremel?
    16 May 2006
    Hey Guys. I started this project quite a while ago but never posted it here. But now I said screw this. The project is starting to pick up steam now. And I'm very pleased about the results so far. I also think that it is going to be a one of a kind project
    Firstly. More about myself. I'm a 16 year old from Sunny South Africa and found my interest in computers almost 4 years ago. I love modding. I am currently busy with another project which I put on hold for a while due to finacial issues. This mod will feature my main rig which consists of the following
    AMD Opteron 170 (Super PI Time of 27.72s @ 3GHz :rock: )
    DFI CFX3200
    1GB Muskin Redlines
    X1900XTX
    Those are the main componants.
    Then my watercooling setup consists of:
    Swiftech Storm G5
    Danger Den Maze 4
    Danger Den D5 (Which Sadly Died)
    Black Ice Extreme GT 240 Radiator
    Alphacool Shuttle Reservoir (Goodness this thing is tiny)
    And then 1/2" Tubing
    I imported all my watercooling from Performance PC's. Awesome service from those guys.
    So the case has went through various changes with diffirent ideas and waterloops and so forth. So I'll take you guys on a tour from the beginning.
    So here is the case a few weeks after I got it. Or should I say before I started modding it? :p
    *REMOVED ALL THE IMAGES*
    Here's the latest available shot of the case:
  2. WiK1d
    16 May 2006
    I decided to make a Plexi cover for the raddy... (Excuse the Phone Pics)
    A guy on another forum made these designs for me and I was thinking of making them. But nope. I don't have nearly enough skill.
    Here is the Cover at night
    And I put some rubber sponge lining between the case and the perspex, still need to file the perspex smaller
    This must be the messiest install anyone has ever seen :duh:
    Maze 4
    Storm
    Reservoir
    I used some food coloring to make it...uhm...bloody? :duh:
    I got my DFI SLI-DR Expert and immediately ripped my PC apart to put it in. I couldn't use the P180 yet and used a Thermaltake Tsunami (Don't hate me :( ).
    Busy installing it..
    Fitted the water for the leak test...does it look clean enough?
    PS...that unconnected tubes are going to the GPU waterblock
    This must be one of the neatest installs i have ever done.
    Leak Test = Success
    First time ever that I had with 1st installation no leaks...
  3. WiK1d
    16 May 2006
    Building the P180
    All Done...Except For The XTX's Cooling...My Mounting Plate was at a friend
    So in the process of having some fun with my Opteron I managed to toast my DFI SLI DR Expert. Luckily a very good friend of mine (Aswell as my hardware supplier) RMA'd the board and got me a CFX3200.
    Man this board is nice...i wonder if it clocks aswell as the Expert...it better CARL!!! :p
    Applying AS5 to all the spots needed
    Look how crappy the stock is... :eek:
    Then my beloved ATI X1900XTX
    The Core...
    Mounted The Block
    Other Side
    Copper Valley
    Board Fitted
    And Finally In The Case
    So in this period there was a stall of about 2 Months
    So I stripped the case and watercooling...man check this dust on the RAD..
    All taped out...
    I ran into some problems with mounting the RAD... :S
    I want to move it inside...but seems it just won't cut it..
    Option 1: Both Inside...NOT gonna work.. :(
    Option 2: RAD inside...Fans outside.
  4. WiK1d
    16 May 2006
    So I thought of a better Idea...Raddy on top fans below
    The red circle is the bottom mounting hole for my waterblock...so the top one is there somewhere...I think it will fit that way...
    Made the cover ready for cutting...which will probably happen in a few days time
    I have the worst luck with reservoirs..EVER. My first one had leaks that almost had me in tears.
    Now the new one cracked so badly..
    And then in this stall I thought of a new name and theme. The case was gonna get Carbon Fibre'd...Hence Carbon P180.
    So I ordered all my goodies from Performance PC's and so on. Installed my new Raddy and all was good :D
    Still lots of space left there :D
    I forgot to take a pic of the drawing...but here is it with some dust and holes...
    A very very rough cut
    Test Fit
    One the case
    Here is my basic idea for the tubing..I'm gonna try keep this as neat as possible :D
    I dunno if that actually makes sence...but you guys will see soon enough :D
  5. WiK1d
    16 May 2006
    So I went and bought myself some Allen Cap Screws :D
    I bought myself some Carbon Fibre Vinyl aswell...I like :D
    Applied it to my one sidepanel...
    *damn that looks crap* High Res Pic To Follow Soon
    High Res 2MB
    The one sidepanel is COMPLETE :D
    High Res Pic 1 (1.2MB)
    That's It For Now :D Hope you guys enjoy it. Now it is sleep time. 3.30AM here :(
    Cheers
    High Res Pic 2 (2MB)
    High Res Pic 3 (1.3MB)
  6. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    aw man. not bein' able to afford the real deal sucks dont it? :rolleyes:
    nice job so far. keep the updates coming, i'm sure there'll be a few following your progress.
  7. WiK1d
    16 May 2006
    Heck if I could have bought real carbon fibre that would have been totally insane :D But yeah. It's so expensive. And cool things like that is so hard to find in South Africa...almost everything cool I want I have to import because we don't have it or it's just too expensive :(
    But thanks for the kind words :D
    I also did the front panel today. It's busy drying now. Will post some more pics tomorrow.
  8. The Bart Man
    The Bart Man What's a Dremel?
    27 May 2004
    Nice carbon but why use not some REAL carbon!! On ebay lot of carbon sheet. Personally i don't like the vinyl stuff. But ok the real carbon will be a hack in to any budget. And that money you spend also on some beers or other gadgets.
    But i do like the design!! Looks verry promissing!!
    Keep up the good work!
  9. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    People have spoken about using Carbon Fibre for cases before, but have all been let down by the fact that Carbon Fibre can conduct electricity, or something of the sort? By the way, didn't you just defeat the entire purpose of the P180 - silence?
  10. WiK1d
    16 May 2006
    :D Thanks :D
    Well I guess I did. But it's not like I'm gonna have 27 fans in my case...
  11. Mod_God
    Mod_God What's a Dremel?
    7 Dec 2006
    That side panel looks sweet, Im thinking about incorporating that CF vinyl into my mod is it easy to use?
  12. WiK1d
    16 May 2006
    Thanks, The sidepanel which is cut is gonna get redone. It will be the same hight but over the full length of the case. I'm also gonna have it lasercut :D It's pretty easy using CF...Just spray some soapy water on it and then you can easily move it around. Bit a word of advice. Don't trim it while it's still wet...it will move around and cause you to make screw up's like what happened last night to me :(
    Anyways..here as promised. Front Panel
    I don't like it...made a few screw up's...will do it over...but this is kinda what the case is going to look like :D
  13. atanum141
    22 Jul 2004
    mate, where did u get ur carbon from?
    Pass me a link as i need to get some for my project.
  14. Mod_God
    7 Dec 2006
    You can get the stuff for a decent price HERE
  15. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    Looks Nice, thanks for a nice mod, lookin gd!
  16. WiK1d
    16 May 2006
    I was going to suggest mnpctech...I got mine from a place in SA. So that wouldn't have helped you...
    Thanks dude :D
  17. atanum141
    22 Jul 2004
    yeah mnpctech i a known supplier but i suspect the postage cost to be ludacris....ill look for a place in england.
  18. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Fixed. ;) :D :p
    Back on topic, your project looks good - nice to see P180's modded as there aren't many modded around. :)
    I'll look forward to updates.
  19. WiK1d
    16 May 2006
    Thanks :D I wanted to make my P180 one of a kind. I was pretty afraid to post this here as the modders here are crazy :D I love to browse the project logs here :D
  20. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    Nice to see someone mod a P180, I'll be watching this project for some ideas cause I'm gonna be posting up a project of mine in a few days also with a P180 (silver now, but black after the mod :D )
    what did you use to cut the window, a dremel maybe?
