Case Mod - In Progress Silverstone TJ11 Carbon.....Final pics
Discussion in 'Project Logs' started by kier, 6 Jul 2011.
  1. RedManc
    RedManc New Member
    30 Jul 2011
    You need not explain anymore! :D
    Its looking great Kier, as for the cover of the red parts, have you just covered them with film and cut it to fit ? a little yellow film might be cool ... :thumb:
  2. ciberjack
    ciberjack New Member
    12 Aug 2011
    hi man tsih mod is awesome!
    is great the slim line dvd-r, but i have not understand how you can eject the discs without any button?!?!?... :?
  3. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Awesome and Im glad your doing a manifold setup with the GPUs so each block gets the same temp fluid passing through it.
    Just gorgeous.
  4. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Sorry for the noob question, but I just can't grasp how that manifold setup works?!
    Could anyone explain to me how the water flows through those GPU blocks? :)
    Edit: Spent 10 minutes looking at it, and the second I post this, my mind get's it! :lol:
    But it DOES require a pretty high flow from the pump to fill all 3, doesn't it?
  5. kier
    kier -----------------
    1 Mar 2011
    Just a little small update about the cables and the hdd's
    Finally I got my hdd's in, 4TB is enough for this build
    There's also a OCZ vertex 2 ssd 120 GB coming in for the OS
    So installed all the hdd's and routing the sata and power cables
    A small piece of the power is visible, but this is gonna be sleeved
    All the power cables are between the hdd bracket and the drive bay
    So almost no cables visible
    All the sata's are going to be sleeved and placed like this
    The power led, usb and other cables are placed behind the slide-out bracket (dont how it's called)
    This is it for the weekend. Greetings my modding friends
  6. kier
    1 Mar 2011
    There's gonna be water passing the in- and outlet from the gpu,s. But not that much I think
    the good thing is that all gpu's gets the same temps like HourBeforeDawn said
    If the passing flow is to much I can always close two fittings from the second gpu
    Razer2007 likes this.
  7. Angel OD
    16 Sep 2007
    I understand how it works now! :)
    I'm just wondering if the last card in the serie get's most flow through it?
    Then the second card would get medium flow, and the first card would get the least flow.
    I'm guessing that liquid will take the shortest route it can...
    Not sure.. But the build looks frikkin awesome! :thumb:
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    I've seen people do it this way in numerous builds, so I guess it works fine?
    But I've also wondered about it - I guess the water pressure splits equally into every opening, providing the openings are all the same size?
    LooseNeutral likes this.
  9. kier
    1 Mar 2011
    Sorry mate, didnt see this question before :blush:
    I have an external wiring from the original eject
    The power button on top of the case is going to be my eject, the one in front is my powerbutton
  10. kier
    1 Mar 2011
    Update: First loop filled
    Finally all the acryl pipes are connected. Had some difficult issues with a few fittings
    but it came out fine
    Like the connection on the full cover block
    But..........everything is connected now
    Made some changes to the GPU loop, instead of the BP rotery snake I've used some more crystal link tubes
    Time for the liquid.
    And one loop filled.
    The plan was to do the second loop also............but made a mistake
    Need to order some more Feser because I dont have enough for the second loop
    So to be continued :thumb:
  11. The boy 4rm oz
    10 Apr 2008
    The plumbing looks great, really neat and tidy. The coolant reminds me of puss lol.
  12. r1sKas
    r1sKas Orange or White? Lets mod!
    22 Jan 2011
    That liquid looks like a banana juice :D
    You got a explendid system over there m8 ;)
  13. Gentleman_Dingo
    Gentleman_Dingo New Member
    30 Aug 2007
    I love the coolant color, it works well with the black overlaying the acrylic.
  14. kelmannen
    kelmannen New Member
    5 Feb 2011
    high class on this one! :thumb:
  15. Neilc
    Neilc Active Member
    5 Apr 2011
    really enjoying seeing this build coming on - its definitely inspiring me to do my own scratch build.
  16. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Very very niiice.
  17. Nutman
    21 Oct 2008
    Really like this and yellow fluid is sooo cool to look at - however, it looks like it could use just a TAD more red dye to match the acrylic 100%, or is it just the camera playing tricks on me?
  18. HourBeforeDawn
    26 Oct 2006
    ya the plumbing is fantastic
  19. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    A feast for the eyes!
  20. Kasius
    Kasius Bringing the dremolition
    16 May 2003
    So, so profoundly awesome! :dremel:
