SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    http://forums.bit-tech.net/announcement.php?f=4
  2. ishiii
    ishiii What's a Dremel?
    18 Nov 2003
    I am not sure that this is the place to be asking for pirated software.
    ahhhhhhhhhhhhh To HELL with that, I am sure this isnt the place
  3. fuzzygoblin
    fuzzygoblin What's a Dremel?
    19 Oct 2003
    ok sorry guys i wasnt aware forget i said anything and mods care to delete it for me?
    sorry
  4. Lithium
    Lithium super spunk
    26 Jul 2002
  5. SnaRf
    SnaRf What's a Dremel?
    22 Nov 2002
    I have a 120mm radiator done if anyone's interested.
    The rad is based on the black ice AFAIK...
    I will need someone to host for me though :(
  6. Lithium
    Lithium super spunk
    26 Jul 2002
    send it to
    lithium[at]rapidplay[dot]com and I will host it for you mate.
  7. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    I have an updated version of my PC7.
    It just has holes in the front bezel.
    And the Bit-Tech rear fan grill.
    Who would like to host it for me?
  8. nokie2
    nokie2 What's a Dremel?
    23 Apr 2004
    just saw this and ill try to get their attention to this problem... im portuguese too and spend some time reading the posts on that forum... due credit will be given :thumb:
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    nokie2 - excellent, obrigado, much appreciated :D
  10. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    two quick questions, why hasnt anyone made LED's or electrical components, and second, how do you make cureves/pull corners to different angles like in the video tutorial?
  11. sickskater6911
    sickskater6911 What's a Dremel?
    9 Oct 2003
    i try and try and try to use sketch up it jsut doesnt work well for me
    im sure noone will want to do it but i BEWG SOMEONE!!
    to make a sketch up of my upcoming case
    http://forums.bit-tech.net/showthread.php?t=58737
    using a cheiftec dragon mid tower
    PM me or IM if u wanna help me out
  12. ArmyAnt
    6 May 2004
    i just need a tutorial for making bowl like curves.
  13. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    hmm. Bit tech rear grille. Holes up front. Scroll back a few pages. The PC7 lite. You did the original. I did that one.
  14. ArmyAnt
    6 May 2004
    yeah, i saw that, but how did you make it?
  15. Tulatin
    16 Oct 2003
    For the case, i took OstickO's, and rebuilt the bezel, and cleaned up the interior. For the grille, i took MDK (i believe)'s design, put it on a square of material that was 8x8 cm (in sketchup), then made it translucent and traced. easy as pie.
  16. SnaRf
    22 Nov 2002
    120mm Rad
    As promised, here it is.
    Thanx to Lithium for the original hosting :)
    edit: Seems to have moved to Jazzle's site...(Remove the old links)
    120mm Rad.skp
  17. Stickeh
    20 Jul 2003
    Yes Tulatin, you did make that one, and i appreciate it very much, im sure we talked about this ages ago, just so the case could be made to look much better, that i would use your improved front bezel :)
    Hope you understand ? We'll get your name credited there as well on the front page. OStickO and Tulatin's PC7?
    Fair? :)
  18. Tulatin
    16 Oct 2003
    yep. By the way, i also cleaned up the internal cages on my revision. Nice work to begin with though!
  19. Lithium
    Lithium super spunk
    26 Jul 2002
    Sorted now matie :thumb:
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
    any reply yet?
    I have changed the names of some more files, they better not steal them again or there's no more Mr Nice Guy...
