Other Smartphone users!
Discussion in 'General' started by Shadowed_fury, 9 Jul 2010.
  1. alastor
    alastor Minimodder
    6 Sep 2004
    FoxToPhone/SendToPhone is very awesome, been using it since I got FroYo. Should note that it is for 2.2 only at the moment.
  2. knuck
    knuck Hate your face
    25 Jan 2002
    I don't see the point to be honest
  3. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Fairly awesome idea, but not been able to get it to work yet.
    I'd kill for a firefox-android bookmark sync though :D
  4. Herbicide
    Herbicide Lurktacular
    27 May 2004
    Just checked for (and am now downloading) the update for 2.2 on my Desire.
    *mutters something uncomplimentary about other people's downloads*
    OK, download's finished and installing now.
    Booting...
  5. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Jealous.
    Motorola recently announced the Milestone would get 2.2, but only in Q4 :(
  6. knuck
    25 Jan 2002
    also waiting for 2.2
  7. Herbicide
    27 May 2004
    Took a while to get lock pattern and swype working again (disable and re-enable works better than swearing at it while trying to repeatedly tun it on, and I've uninstalled and am now reinstalling Swype).
  8. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Anyone waiting for the Desire HD, Desire Z and/or WM7? Only a couple of days to go now :D
  9. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    Patiently - Desire HD
  10. dragontail
    9 Jun 2005
    Me too. Only thing that concerns me is the potential battery life. I mean 1230mAh, come on!
  11. VipersGratitude
    4 Mar 2008
    The only time I move is from one desk to another...not too concerned about battery life myself.
    Did you see this?
  12. Gareth24
    Gareth24 Folding = vdubs
    16 Jun 2009
    Waiting for my iphone 3g to arrive from M7ck after using a nokia 5530 for about a year.
  13. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Droid 2 - Very pleased with it. Plan on rooting it soon.
    I got the extended battery for it, it literally will run all day on pretty heavy use, and I am sure once rooted will run longer cause it wont be running all the bloat crap on it. Doubt I will do any sort of upgrade until the 18 month upgrade option rolls around. :)
  14. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Well I finally got (and have used for a bit) my 16 GB iPhone 4
    Updated from 4.02 to 4.1
    installed a few apps (Facebook, iBooks (only to confirm that I really do need an iPad), F1 app).
    Usages? Anything from phoning to texting, to wathing laptimes while wathcing F1... and FB.
    Battery life: About 1 and a half days if I use it fairly heavily.
    Otherwise around 2 days.
    It goes WAY up if I disable 3G networks though...
  15. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    Guess I'm a bit sad then as i'm still using the o2 XDA IIi running windows mobile 2003
    link
    but to be fair I like it :)
    -----runs away and hides in shame----
  16. alastor
    alastor Minimodder
    6 Sep 2004
  17. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Well, my poor HD2's screen has been utterly obliterated, smashed beyond all comprehension.. still works, it's just a pita! So, if O2 don't replace/fix I'll either be an iPhone user (*gulp*) or a Nokia N78 user..
    :sigh:
  18. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    It's not their fault you broke it, even if you had insurance on it xD
    iPhone it is? :p
    I want a HTC, but current budget doesn't allow me
  19. mars-bar-man
    17 Apr 2009
    Not actually my fault either :p I was a club ad got pushed into a hand rail, then got a text, and then my heart sank :(
    What's the chances of actually getting it replaced? If it fails I'll head over to the CEX store and have a look at an iPhone or teh HTC Hero..
  20. alastor
    alastor Minimodder
    6 Sep 2004
    You could wait a week or so and get a WP7 HTC.
