as usual your skills impress. Everytime you watercool a rig, the routing just drives me crazy! Great job!
Looking great Paul Is the top mini-840 physically mounted to the lower case with bolts or the like, or are you just going to be using gravity and the tubing? Also, I'm still not sure on those fittings without jubilee-clips or the funny ratchet hose clamps, do they really provide a secure enough fitting?
Looks awesome Paul! Lots of Phobya stuff, Those fans are killers! looks verry neat ! I am going to Cbit also, ( from eindhoven )
Cheers all for taking the time to post.........kinda makes it all worth while Today was a good day - got the top hand made bezel fitted to the top chassis with the power / reset and LEDs all mounted and grill installed. Best part of the day though was hose routing both the motherboard / RAM loop and the CPU loop - both turned out really well considering the amount of hose involved so only the GPU loop to do which is pretty straight forward but still waiting on cards to turn up but apart from that, i seem to be making good progress
Some sick work here! Even just the layout of the loop is awesome, makes me want to buy bitspower fittings and hang them in my room.
wow that is one sweet looking mod I love the water loops theyve turned out really neat and tidy cant wait to see this completed
This is such a sweet build. I really like the color scheme. That top panel looks outstanding. Very well done as always.
Thanks everyone for taking the time out to post. I got to give my friends at EVGA a massive shout for getting me some graphics cards out at such short notice They are the EVGA GeForce GTX 480 Hydro Copper Cheesecake which fill up the SR-2 board real nice. I'm just not sure if the Coolermaster 1200 PSU will be able to handle all four cards and as the chassis needs to be starting it journey to CeBit this weekend i simply won't have time to test so not sure what to do for the best. I think the best thing to do is install them all and sort it out when it gets back home as it won’t be running anything on the booth, just sitting there looking pretty. Looks very nice though
