Case Mod - In Progress SR-2 STACKER - 'Completed'
Discussion in 'Project Logs' started by coolmiester, 21 Aug 2010.
  1. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    LMAO, i just looked at the packaging and it says for use on metal .5 to 1.5mm thickness...........oops :duh:
    Seemed to work OK with a little WD40 sprayed on every now and again :thumb:
  2. bulldogjeff
    2 Mar 2010
    Oh dear, so it wasn't 5-15mm then..lol
  3. coolmiester
    31 Dec 2002
    hahahaha, yeah i must get some new specs :D
  4. coolmiester
    31 Dec 2002
    Well after humming and harring about which pump/reservoirs i was going to use, the final decision came down to what would actually fit.
    Due to the placement of the bottom two 240 radiators i'm going to lose at least one drive bay, probably two and given i'm going to be running three loops it came down to a couple of RP-450X2's.
    I got to say my initial impression of these is nice but those logo's just had to go so set about making them fit in with the rest of the mod.
    I had to ditch the original bezels and black M3 hex bolts and replace them with slightly shorter countersink ones so once the plexi had been countersunk, the heads would be flush to allow my new hand cut bezels to mount directly to the plexi.
    The last couple of mock-up shots show how they fit in with a wide screen TFT just below - obviously they will be powder coated and painted in the not to distant future :hip:
  5. infekted.one
    infekted.one What's a Dremel?
    7 Nov 2006
    Awesome build just awesome!
    One Question: I got an 810 Stacker here how did you go about encouraging them to breed?
  6. Yaka
    Yaka Multimodder
    26 Jun 2005
    looking very nice mate
  7. Kojak
    Kojak Who loves ya baby
    3 May 2010
    Looks great mate, oozes quality, well done!! :thumb:
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking amazing man
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Nice, very nice.
  10. KidMod-Southpaw
    28 Sep 2010
    Why not remove the feet on the mini stacker? It'll look more flush with each other.
  11. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Man that's a very professional finish there, and also awesome work on the motherboard tray.
  12. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    So... Much... Win... :jawdrop:
    Don't know where to start, so I'll just drewl! :lol:
  13. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
  14. NavidsonRecord
    NavidsonRecord Where the bloody hell are ya'?
    5 Jan 2010
    I see someone took my advice with WD-40 and jigsawing alu :)
    ... or maybe you too discovered the beauty that is WD?
  15. The boy 4rm oz
    10 Apr 2008
    They are very nice reservoirs, the new face plate makes them look even better.
  16. Skorchio
    Skorchio What's a Dremel?
    16 Oct 2009
    Seriously nice mate! Them res are amazing! When I win some big money I want a full koolance built loop :)
  17. Editor22
    3 Jan 2009
    Don't forget tapping too :D WD makes for awesome tapping lube especially with the little tube insert :D and a small bit on a clean rag can give edges of plexi a little zing to :p oh man how i love that stuff :rock:
  18. bulldogjeff
    2 Mar 2010
    This thing is looking seriously impressive mate. Big well done.:thumb:
  19. coolmiester
    31 Dec 2002
    Cheers all, greatly appreciated thanks :thumb:
    Got the side panels cut down to size for the rad box and then went about fitting four flush mount vents using the mesh out of Bitspower rad grills and used the actual grill as the template to hand cut the four openings pretty much as i did a while back on a Corsair 800D mod which gives that kinnda simple but effective kind of look and should look good with the red LED fans behind.
    Just got to do the other side now and then two in each side of the main case but i think i'll concentrate on getting the rad box finished before moving onto the main chassis :)
  20. DeadP1xels
    30 Nov 2009
