Graphics The 1080TI GPU Thread
Discussion in 'Hardware' started by rainbowbridge, 1 Mar 2017.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Is it that good?:)
  2. sandys
    sandys Multimodder
    26 Mar 2006
    surely it can't be much different to your TXPs?
  3. Pete J
    Pete J Employed scum
    28 Sep 2009
    They're better.
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
  5. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Did you replace 2 Pascal-based Titan X's with 2 Ti's, then?
    That's gotta be just about the most expensive sidegrade possible haha -Surely putting the 2 Titans on water would have given you a bigger performance gain for less than the price of one Ti (and bigger e-peen bragging rights, to boot!).
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
  7. Pete J
    28 Sep 2009
    Nah, kept the XPs, selling the Maxwells.
  8. N17 dizzi
    23 Mar 2011
    Another reviewer showing reference 1080 Ti throttling. You can increase the max temp to get higher boost clocks, and hear the fan hit overdrive at the same time.
    Thermal information from 5:30 on the video, with recommendation to wait until April and get an AIO 1080 Ti just after that.
  9. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
  10. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Nice, I'll have a read. I'm running my 1080 ti at 3440 x 1440 and so far I'm impressed.
  11. [ZiiP] NaloaC
    9 May 2008
    Good to know that someone else here other than just myself and AdRock are running that resolution :)
    How does it impress you so far? Does this properly have the grunt to run that res?
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
    Should be just about enough (provided you don't have one of the three 100hz monitors available).
    An oc'd 980ti can handle a 3440x1440 60hz screen in properly designed games like Doom or Shadow Warrior 2 just fine at good settings, so an oc'd 1080ti should be enough to handle it even in poorly optimized games like Hitman, Dishonored 2 and such.
  13. GravitySmacked
    2 Mar 2009
    So far no complaints at all, it's certainly a lot better than my old 980 ti and that was no slouch. I been playing GR Wildlands, BF1 and The Division and they fly on this card.
  14. phinix
    28 Apr 2006
    What fps do you get in your resolution in The Division?
  15. GravitySmacked
    2 Mar 2009
    Hmmm, off the top of my head it was around 60 but I'd have to go back and double check for sure. It was certainly very smooth.
  16. phinix
    28 Apr 2006
    Cool, in 4K I'm getting 50-60fps with all settings on highest.
  17. GravitySmacked
    2 Mar 2009
    I've just fired it up to check. Indoors between 80-100 fps (to be expected as not much happening) and outdoors between 60-90 fps depending on if I'm standing still or running about and where I am. I've got G-Sync enabled and it all feels nice and smooth. That's with all settings cranked up.
  18. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    The first rule of thirtyfourfortyfourteenforty club is we don't talk about thirtyfourfortyfourteenforty club.
    The second rule of thirtyfourfortyfourteenforty club is adrock's name has no capitalisation.
    That sounds promising. My/our screens are only 60Hz, but the idea of not having to faff about with any settings to make sure i don't dip below that is appealing. I'm currently on the 4GB 980 i bought with the monitor so i've had textures turned down in things.
    So the question remains; to buy the FE then attach a G10/hybrid/whatever cooler, or to wait?
  19. The_Crapman
    5 Dec 2011
    Get an FE then smother it in full cover coppery goodness. :thumb:
  20. phinix
    28 Apr 2006
    Cool. I have a shitty mobo, will get new one next week and will re-do fps, will see how it will change:D
