Scratch Build – In Progress The Razor's Edge
Discussion in 'Project Logs' started by Iraklis Gkolios, 2 Dec 2014.
  1. Iraklis Gkolios
    Iraklis Gkolios Minimodder
    21 Aug 2013
    Good morning Bit tech community.
    I have decided to take a major turn in the build. As i said in the past the plan was to have the case powder coated. I have done some research and found a shop with some decent prices where i can give my case for paint.
    But today after careful though i decided that i will paint the case myself. I have a pretty good experience with spray paints and i am not afraid that the result wont be good. The reason i do this is because i want to check every phase of the paint and i dont want to end up only with one color.
    The color scheme of the build will be white red and black
    Cheers
    Iraklis
  2. Cheapskate
    13 May 2007
    Love the base. :thumb:
    I don't think you would have been able to do powder coat with all the smoothing putty. Paint is your best option.
  3. Iraklis Gkolios
    21 Aug 2013
    You cant imagine how troubled i was with the base. At least i came out with a design that is acceptable. :thumb:
    Now back to work.
    I am starting to mount all the pieces on the case to check if everything fits and make some adjustments.
    In this photo you can see how the stand attaches to the case. It needs some cleaning and smoothing but you can get the idea. The stand i use now is if i place the case on the floor, later if i decide to place the case on a desk i am gonna make a lighter stand.
    Cheers
    Iraklis
  4. hero1
    hero1 Minimodder
    18 Oct 2013
    Oh hot damn. This is awesome.
  5. Iraklis Gkolios
    21 Aug 2013
    Thanks man !:thumb:
    Now back to work.
    I decided to paint one of the radiators white, this is the first time a paint a radiator and i can tell that the result came out pretty good.
    Cheers
    Iraklis
  6. Iraklis Gkolios
    21 Aug 2013
    Hello everyone.
    I decide to clear coat the radiator after i let the paint to cure for around 2 weeks on stable temperature.
    I decided to use satin clear coat and i think the result came out pretty good!
    Now its turn to paint the other radiator
    Cheers
    Iraklis
  7. Iraklis Gkolios
    21 Aug 2013
    I painted the second radiator on the usual colors
    Cheers
    Iraklis
  8. IonKnight
    IonKnight What's a Dremel?
    17 Jun 2011
    Looking really nice just wondering before you gave up on the aluminium did you try those aluminium welding sticks that just use a blowtorch to make the weld ? Think it's just a mixture of aluminium and solder and worked well using it 10 years ago, but didn't try sanding it down. Just curious because I'm wondering if its still a usable idea as looking to use it in my case project.
  9. Iraklis Gkolios
    21 Aug 2013
    I know that method buy i dont trust it since i think that is used to fill gaps on aluminum and not for soldering 2 sheet of pieces.
  10. Iraklis Gkolios
    21 Aug 2013
    i managed to spray 1 layer of primer on the base piece of the case after a busy weekend..
    Cheers
    Iraklis
  11. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    You do nice paint work sir! Those rads look great!
  12. Iraklis Gkolios
    21 Aug 2013
    Thank you man.
    I have been away for some days because i gave the case to the plexi shop to make me a windows cover.
    I believe that some time around next week ill get the case back and start working again
    Cheers
    Iraklis
  13. Cheapskate
    13 May 2007
    Spring is here, and paint fumes are in the air.:D It's looking good.
  14. Iraklis Gkolios
    21 Aug 2013
    The time is close indeed, although the weather here is a bit crazy and changes mood every couple of hours, i am pretty sure that ill be able to paint on the following days.
    Today i got back the case from the plexi shop. They did a fantastic job and i am really happy with the result.
    Cheers
    Iraklis
  15. arduum
    arduum Minimodder
    10 Mar 2015
  16. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    this is coming along nicely
  17. Spectre
    Spectre What's a Dremel?
    17 Mar 2016
    Why didn't you do the plexi yourself? Or even go with acrylic? It would have been more fun for you.
  18. Iraklis Gkolios
    21 Aug 2013
    After many modifications i managed to mount the plexi on the case. There are some minor adjustments i need to do on the following days, but i think that the result came out pretty good.
    I managed to take some photos before i leave my work to show my progress.
    Cheers
    Iraklis
  19. Cheapskate
    13 May 2007
    They did a good job.
    @Spectre- There's a learning curve on plexi cutting/bending. He didn't have the budget to waste sheets getting it perfect I imagine.
  20. Iraklis Gkolios
    21 Aug 2013
    Thats exactly the reason i let the plexi shop to make it. I have never worked before with plexi and i lack the equipment to do so. Even the guys from the shop found it tricky to make the window and they wasted some sheets.
    Cheers
    Iraklis
