Scratch Build – In Progress The Razor's Edge
Discussion in 'Project Logs' started by Iraklis Gkolios, 2 Dec 2014.
  1. Cheapskate
    13 May 2007
    Somewhere in Greece, there's a house with a power supply mortared into the wall.:lol:
    You have plenty of time to work out details. It's not easy to paint in Winter. I still like the idea of this on a single pedestal.
    Where will you run the PSU cables? It looks like they might have to cross the I/O area.
  2. Iraklis Gkolios
    Iraklis Gkolios Minimodder
    21 Aug 2013
    Hello everyone and happy new year.
    I came back from my trip in Budapest, i had a great time in Hungary but now i am back to Greece and i decided that its time to start working with the case again.
    Here is the view i had from the hotel
    Today i started welding the bottom piece of the case but my welding machine broke down :(. I hope that its nothing serious and it will be easily fixed
    Cheers
    Iraklis
  3. Cheapskate
    13 May 2007
    Not a fun way to start the year.:( -Hope you get it fixed.
  4. Iraklis Gkolios
    21 Aug 2013
    Yes indeed, but after a successful service my welding machine is operating better than before.
    Today i welded the bottom piece and now the case is almost ready from the outside :)
    Cheers
    Iraklis
  5. Iraklis Gkolios
    21 Aug 2013
    More welding and filling and sanding today.
    I also test mounted my dummy PSU, as you can see on the photo there is enough space to access the I/O of the motherboard.
    Cheers
    Iraklis
  6. Iraklis Gkolios
    21 Aug 2013
    Today it was a very busy day. I managed to weld the door hinges and attach on the top the magnet that holds the door closed.
    I also made my order on aquatuning
    Cheers
    Iraklis
  7. Iraklis Gkolios
    21 Aug 2013
    Hello everyone.
    While i am waiting my order from aquatuning i did some work with the case. There is a lot of sanding and trimming to be done, but today i drilled the hole for the power plug.
    I think the overall result is pretty good.
    Cheers
    Iraklis
  8. arduum
    arduum Minimodder
    10 Mar 2015
    Iraklis Gkolios
    will be angled the power cord?
  9. Iraklis Gkolios
    21 Aug 2013
    If you ask what type of power cord i am going to use because you think that the straight one wont fit. I am planning to add case feet on the future so both angled and straight power cord fit correctly.
    Cheers
    Iraklis
  10. Iraklis Gkolios
    21 Aug 2013
    After drilling the hole for the power plug on the back of the case, now its time to drill a hole for the power switch.
    Cheers
    Iraklis
  11. Cheapskate
    13 May 2007
    Oh no! You arcked on your psu. :lol:
    Coming along nicely.
  12. Vognen
    Vognen Minimodder
    2 Oct 2013
    Please speed this up. You're too slow, and I want faster updates :naughty:
  13. Iraklis Gkolios
    21 Aug 2013
    Tell that to my full of cuts fingers and to my empty wallet :dremel::dremel:
  14. Iraklis Gkolios
    21 Aug 2013
    I have been preparing the case for some days to paint. I have been busy priming and sanding for many days to achieve a decent result before the paint-primer phase.
    As you can see i have managed to make the welds invisible and remove and scratches from the surface.
    I have also prepared one of my radiators for paint.
    As you can see there are some scratches on the radiator after the primer but with some sanding before the paint i dont believe that they are going to be still visible.
    Cheers
    Iraklis
  15. coalminer071
    coalminer071 What's a Dremel?
    10 Sep 2015
    do you have a system spec list already?
  16. Iraklis Gkolios
    21 Aug 2013
    I still havent decided the hardware, since i dont have a tight timeframe when i am gonna complete the case, but i believe it will be the best hardware available that time.
    Now back to work.
    I got my mail from aquatuning.de today
    Cheers
    Iraklis
  17. coalminer071
    10 Sep 2015
    Tried sending you a private message but came up with an error.
  18. Iraklis Gkolios
    21 Aug 2013
    i think its because you are new to this forum, contact me through my email address.
  19. coalminer071
    10 Sep 2015
    I cannot reach your email address.. Maybe you can email mine, left a link in your visitor msg.
  20. Iraklis Gkolios
    21 Aug 2013
    Major update today.
    I have testing various designs for the case stand. The best good looking idea i came up is this. The bottom piece is made of a solid iron piece that adds stability to the whole case and the two other pieces is where the case is going to sit.
    Cheers
    Iraklis
