Hi guys once I sell my motorbike im building myself a new rig....What cpu cost around the same as a 2700k (give or take a few £££) but is a better cpu, even if it means buying another motherboard thanks guys
the ivy bridge i7 3770K, but you could still use your current mobo and just update the bios. However, I'd wait for Haswell as that would be a biger performance jump.
You would probably have to wait for Haswell to get a decent bit of a performance bump, compared to going from Sandy to Ivy.
3820 SB-E but you would have to get an LGA2011 board. It's a cheaper chip than the 2700K/3770K but still overclocks. Of course you should wait for Haswell. I'm not sure how far behind IB-E will be.
Apparently IB-E is coming in September with a 8 core SB-E chip as well, with apparently the new Nvidia cards coming either this month or next month. Although it's all rumours from the net so take it with a pinch of salt as I don't think either Intel or Nvidia have confirmed the dates yet.
nothing atm is a good upgrade over the 2700k unless if you move up to a 6-core, even haswell likely won't be a huge upgrade. the 2700k is a beast
agree had about 10 3770k come through my door but not opened one up as my 2700k is more than upto the task
What volts have you got going through that monster overclock and what temps do you get? And is that your overclock for daily use?
