Scratch Build – Complete ⭐ WING X99 - A CNC-milled Scratch Build! (Benchmarks,temps and wallpapers posted)
Discussion in 'Project Logs' started by Andreas | Brodholm, 19 Aug 2016.
  1. Andreas | Brodholm
    Andreas | Brodholm Minimodder
    12 Jan 2013
    :D
    Btw, does anyone know how I change the prefixes from:
    To
    Looked around but did not find anything?
  2. Cheapskate
    13 May 2007
    Go to the first post. It should say "Thread tools" to the right of the thread title. You can change it there.
  3. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    I can also do it if for some reason it's not showing up.Just double checked the settings and it should 100% be there for you.
  4. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    doh, I keep meaning to make a tutorial for this. Let me just get through this next beer and I will do it :)
  5. davido_labido
    11 Oct 2013
  6. Andreas | Brodholm
    12 Jan 2013
    Wiiiiiiieee! It works! :D
  7. davido_labido
    11 Oct 2013
    haha, I have just made a nice gif for people too :) so even our friends who are not so good at English can understand :D
    Andreas | Brodholm likes this.
  8. Andreas | Brodholm
    12 Jan 2013
    Hello again! I just did some benchmarks, temperature, fan speeds and power usage tests. I also selected a more reasonable number of pictures to fix up for wallpapers and re-did some of the edit on them to fix/adjust the color balance/hue/contrast and exposure! And I also removed the big water mark on each picture since it was a bit disturbing. The "album" should now have much more of a flow to it and have a red thread, so you can easily navigate through the pictures. That was some of the critique and I can agree on that and have made adjustments for it!
    Some people have made request for me to make some wallpaper versions so here is a Google drive 4K PNG Wallpaper Link. I also included some updates to the "Battlestation" and some updates on some small things like how the fan filter looks after 6 months :D
    Cheapskate, neSSa and MLyons like this.
  9. Andreas | Brodholm
    12 Jan 2013
    Computer performance and temps after 5 months of constant daily use (+6h each day). All in all, the system runs perfectly with a low noise level with the fans doing around 7-800 RPM when in idle and with it ramping up to about 850 RPM when doing gaming, rendering and other heavy tasks. While I could run the system on higher fan speeds to gain a few degrees it seems hardly worth it. But It is good to know that I could If I wanted to. The Corsair Commander have been quite good and really easy to use and setup, both with hardware and software. Being able to set your own curves for the fans is a really nice feature that I value a lot. It is a nice unit all in all the only thing I wish it had was on board memory so in case the computer hangs or the software crashes it would still be able to control the fans. But that is about the only bad thing I can say about. And the Link software has come a long way for those who haven't used it for a while.
    3Dmax Timespy with Gsync Off and got the following score. CPU @ 4.0 GHz and GPUs at stock settings.
    Time to do some benchmarking now (about 5 months later). Everything have been running smooth and I have been using the computer about 8 hours a day or so. This is the result in Cinebench Running CPU test with CPU @ 4.0 GHz @ 1.20 v. Fans at Adaptive speed (goes to ~850 RPM)
    Temps during the 3Dmax test and power consumption. We can see that with 2xD5 Pumps, 7x140mm ML Fans, Strix 1080 in SLI strix, 2x800gb PCIe SSDs from Intel and a 10-core 6950X uses about 571 Watts from the wall. Notice that the fan on the Corsair AX1200i is still at 0 RPM. Pushing the air through the radiator to the PSU is enough cooling for it to always be passive. I have never seen the fan spin on the PSU even under these types of loads for longer periods. Quite impressive I must say!
    This is the computer at IDLE while having the fans (4xCorsair ML140 push and 3x in pull) all on a dynamic curve that I have set up. With the fans going from 500 to 1800 RPM. We can see core temps around 35-39 C with the water @ 34 C and Air in @ 27 C. Drawing from the wall socket about 240 Watts.
    This is the computer at IDLE while having the fans (4xCorsair ML140 push and 3x in pull) all on maximum RPM. We can see core temps around 32-34 C with the water @ 32 C and Air in @ 27 C. Drawing from the wall socket about 250 Watts.
    Doing Ray Tracing in Autodesk Inventor using 100% of the CPU. Ran for 873 seconds with the fans at dynamic speed that settled around 850 RPM. With the CPU temps being around 58C and a power consumption about 360 Watts at the wall.
    Doing Ray Tracing in Autodesk Inventor using 100% of the CPU. Ran for 757 seconds with the fans at max speed (1800 RPM). With the CPU temps being around 53C and a power consumption about 360 Watts at the wall.
    Running Playerunkown's Battleground @ 120-140 FPS (2K res, Ultra on AA, Textures and View Distance, rest on low or very low). You can see here how much PUBG utilizes SLI... One card is basically not used at all.
    I upgraded my setup with some more stuff. I won a Corsair T1 RACE with WING X99. And after having used it for about 3 months I thought I would give my thoughts on it since there is not that much info out there I feel. All in all I am very pleased with it. And one of the best things with it is how nice the "roller blade" type wheels are. It is like gliding on a cloud compared to hard plastic wheels and much softer on your floor and it does not get stuck on cables and stuff. The material feels soft and has a very high quality. Also, the armrests were surprisingly comfortable. It has this "carbon" texture to it that is tightly wrapped or molded over a springy foam that feels really nice. The ability to change the width, height, "out and inwards" and back and forth position of the armrests is something I did not think I would do much, but I have ended up doing a l lot. The only thing I wished was that it was just a tiny bit wider over the back of the chair. For me it is just right but could have been a bit bigger. If I were to compare it to my previous chair (DXracer formula) this is much nicer in quality over all. The T1 RACER has a material that feels nicer, it has softer padding in the base. It is basically a higher quality chair over all. It is also quite a bit easier to assemble alone compared to the formula chair. The biggest thing for me was that the formula chair was WAY too narrow in the base so my thighs hurt while sitting in it for longer than 30 minutes. I actually had to swap back to my IKEA chair. But as always when it comes to chairs it comes down to personal preference. I would suggest trying out chairs before buying. But I can highly recommend the T1 RACE chair if you are looking for a high-quality chair. For reference I am 182 cm tall and weigh about 80-85kg and that is about 6 feet and 185 lbs.
    This is the texture I was talking about earlier. It looks really hard, but it is actually really nice! And it does not collect dust/skin particles. I was a bit worried about that the first time I felt it. But this is how it looks after almost 3 months of usage!
    I also swapped out my Corsair LUX K70 with MX browns to a Corsair K90 RGB Platinum with Speed switches that has a lower actuation point. Compared to the K70 if you don't compare switches the K90 has nicer media switches and a really nice wrist rest that you can swap for a rough and a smooth surface. All in all, a really nice upgrade and if you like macro keys it has 6 extra to the left that can be quite useful. My thoughts on the speed switches is that you sacrifice a bit of typing comfort compared to my overall favorite brown switches. But I ended up using the speed anyway, it still has a nice feel when typing but it feels much more fast and rapid when gaming. I went back to try brown after a few days of using the speed, but it felt sluggish in games compared to the speed ones. I definitely think it is worth it if you play a lot of games, especially FPS. On the subject of RGB I really like the ability to have specially assigned colors each key and that you can have layout profiles tied to different applications. I am not really a RGB person per say but the biggest thing is that you have options. In desktop I still use a solid red color and when I play games I have specially assigned key colors in my most played games. I would say that is basically always worth to get RGB versions compared to solid color ones.
    I also swapped to the Corsair Harpoon mouse since the K65 mouse did not really fit my grip. It’s a really cheap and simple mouse that does its job well!
    This is how the dust filter looked after 6 months of use! Should probably clean that more often :D
    Also the GPU bubble is gone! But as I did some refilling and cleaning out some dust on the cars this bubble came out from one of the blocks and got stuck there... But It will be gone in a few days or so, but still annoying when you are taking a picture :D That is all I have to update on the WING X99 Project. So far everything has been working perfectly and I am happy with how it looks and how it performs! I am sorry that I did not get this update up earlier and I have been promising people performance benchmarks and temps for a long time! Sorry about the delay!
    Cheers
    Edit: Sorry for the dual post. Could not post the whole update in one post?!
    Cheapskate and MLyons like this.
  10. Cheapskate
    13 May 2007
    Congratulations on winning MOTY... Wait. It's still December.
  11. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
    I didn't see anything more perfect. Well unless slaughter in surgical office only this way can look. Sterilely, all tools on the places and everything is covered with fresh blood. Perfectly. Great work.
  12. Andreas | Brodholm
    12 Jan 2013
    Idk man, lots and lots of amazing builds! I think it all will come down to personal preference and it is anyone's game at this point!
    Thanks man :)
  13. TheMadDutchDude
    23 Aug 2013
    Woooow. That's just on another level!
  14. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
  15. kim
    kim hardware addict
    10 Jan 2016
    IMO, Wing x99 is definitely the mod of the decade, even if many other mods have been fantastic too, but I haven't been amazed this way since the Cygus by Attila...
  16. Andreas | Brodholm
    12 Jan 2013
    Thanks mate :D
    Ohh wow! Thanks man! Sorry I missed this earlier!
    Honored that you think that! Attilas mods are insane so I take it as a huge compliment! Cheers!
  17. kim
    kim hardware addict
    10 Jan 2016
    I mean it, and it turns out I'm not the only one thinking it...who else but you get Nils out of his hibernation (joke :grin:) to add Xwing 99 on MDPC's home page ? Isn't it the graal for all modders to have his mod exposed there? even in 2018... it's a great thing...and you deserve it.:clap:
    I understand how much efforts you made to make it, but I hope you will find time to build something else one of these days...
  18. mnpctech
    21 Apr 2003
    no worries, looking forward to your next project!
  19. HuguesP
    HuguesP What's a Dremel?
    18 May 2018
    Up for everyone inspiration! Definatly the build of the decade
  20. Cheapskate
    13 May 2007
    Well, If we are gonna necrobump, we might as well beg for a new project. :D
