Scratch Build – In Progress Woody by zwiks
Discussion in 'Project Logs' started by zwiks, 5 Jan 2008.
  1. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    heh. thanks .. sorry for the use of big fonts. hhehe yeah im am very exited.. cuz its my first casemod.. by the way i use a a little red thing to make the edges - heres a picture of a simmulare:
    and thanks Snafu-X- for the nice idea.. it was very good. !! :D
    as regard to the edge on the window hole... it was the idea to make a smooth edge.. but i have to do it in my woodwork classes.. cuz i dont have the tool at home for making it nice..
    mvagusta .. its a good idea to buy some mesh.. but i dont know where.. but i will find some..
    .. and just thanks for youre comments .. i like it sooo much... damn its good.. THANKS ... :D
  2. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    :D
    Glad we could bring you so much joy! The casemod looks good thus far, so keep it coming!
  3. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Yeaah.. i will .. .but i will be gone for 2weeks from today.. (skiing holiday :D :D jubii) SEE YAA :D:lol::lol:
  4. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Dim black I'm guessing means flat black. you have a few options here. First of all I would finish sanding the entire case, bondo, spot putty, sanding whatever. Then when you are ready, prime it with a SANDABLE Flat black primer. Ask at any paint shop and they'll show you the right product. Then after you've done a few coats and sanded with 500 grit inbetween you'll know what flat black looks like. You probably won't like it. If you want a flatter black than gloss but don't like the flat black you should go with satin. You'll want to get a Hot rod Black kit from an autobody supply store. This is the ONLY satin black paint you should ever use. It is the most durable, has the nicest finish, and isn't too expensive ($70) Of course you'll need a gun. but if you can't get a gun I believe it is available in a can.
  5. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Thank you for youre comment.. nice idea.. i should consitter it :D sounds nice :p
  6. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    NEW IMAGES,,
    Yeeaaah. new images again :p
    This look like ***BEEEP*** .. i know, but i'm not done with it.. remember that :p :D:D :
    This is some stuff i recived a week ago :p .. but i need to order some more of those.. it aint glowing a nought yet . :D:D :
    This is also some stuff i recived a week ago... and I also have to order 1 more of those .. :D:D:wallbash:
  7. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    instead of painting it you should add a redwood tone color stain then gloss it, but thats jus me
  8. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    yeahh good idea.. but i dont like the "wood-color" eheh but thanks for the comment.
    :D:D:D:D:D:D:D:D:D
  9. perkins teh modder
    8 Dec 2007
    oh thats 2 bad, i kinda wanted to see it with wood color:waah:
  10. Snafu-X-
    Snafu-X- What's a Dremel?
    27 May 2005
    I agree, stick with a wood color. There are a lot of beautiful dark stains out there you can use. Maybe a dark walnut with a satin finish...that would look sweet. There are even some nice black stains you could use.
  11. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    yeah. i get youre point.. but i dont know what i should put on the wood.. wich varnish, pain.. i actually dont know :p hehe
    someone who do ??
  12. clocker
    clocker Shovel Ready
    21 Dec 2003
    You would only stain the project if it was real wood...since this is MDF I think you're committed to paint.
  13. perkins teh modder
    8 Dec 2007
    this is true, but if i made a wood mod i would at least try it, if i didnt like the stain color i would use a mouse sander and then start over with paint as zwiks wants to do
  14. Stuey
    20 Jan 2005
    It's honestly not worth trying. MDF is intended to be left bare, sealed, painted, laminated, or veneered.
  15. Snafu-X-
    27 May 2005
    I didn't realize it was mdf when I suggested a stain, though the pics should have made it obvious to me. Staning it will look like crap, painting is really the only way to go. Regardless, it looks fantastic thus far.
  16. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    thanks.. for all the surgestions .. but i think im just puttying the cracks and then give it some primer.. and paint it flat black.. and im doing it around 2 hours .. hehe so no time for a new idea.. hehe but i'm sure its gonna be coooooooooool :D :rock::rock:
  17. Stuey
    20 Jan 2005
    You might not need to prime the mdf - sometimes they come paint-ready.
  18. clocker
    21 Dec 2003
    Actually, I think it'll need to be primed AND sealed before paint.
    Depending on the surface desired she'll need lots of sanding before finish color as well.
    Not that it matters- and you seem to rushing headlong anyway, so this will be too late- but I'd definitely vote AGAINST flat black.
    Too dull and very prone to showing dust and the like.
  19. SlappKnutts
    SlappKnutts What's a Dremel?
    28 Jan 2007
    Actually I think he's done a heck of a job, especially for being 15!
    And you rounded those corners off with a rasp?!?! Wow, that must have taken some time!
    I would agree on using a glossy paint. flat black usually doesn't look that great on a case!
  20. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Thank you for youre lovely comments :D.. i calculated that i have used around 50 hours on the pc .. to night im painting it flat black and im soon posting some pictures of it.. and if it looks bad I've just give it a glossy black and make it look like a mac-book-paint ..just in black :D see ya :D
    ps. I give the case some putty . then sand it with a 400 .. and then paint it :D
