146% Wavemaster
Discussion in 'Project Logs' started by Dezjay, 5 May 2005.
Where should the 1/2"wavemaster be ??
Poll closed 16 May 2005.
  1. TOop
    67 vote(s)
    54.9%
  2. Bottum
    55 vote(s)
    45.1%
  1. phuzz
    phuzz This is a title
    28 May 2004
    time for a poll then...
    edit, duh, I'm blind :(
  2. AL3X
    AL3X What's a Dremel?
    29 Aug 2003
    I think you should find another door and replace the bottom with that one, and then put the W/C box at the bottom.
    If you understand what I mean :)
  3. 0ri0n
    0ri0n What's a Dremel?
    12 Jan 2005
    That's just sick, in a good way. :D
    My vote is teh Topz.
  4. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Top is more functional
    Bottom looks better.
    I voted top but I think it looks allot better on the bottom so change one vote to bottom.
    Good work btw, looks promising. I think I see a new trend. Get two identical cases and cut one and add it to the other. Works for me.
  5. Autobot
    Autobot What's a Dremel?
    2 Apr 2004
    What if you took the thick top section of the chopped up CM case that holds the door and place that on top of the modded case, and then flip the gravestone upside down? With the added unit on top I think that would look awesome and add some much needed symetry. :)
  6. Dezjay
    Dezjay What's a Dremel?
    10 May 2004
    Well i think i'll go 4 the bottumm...
    here the picture what was the inspiration for the case... the outside will be bordeaux red with chrome.. inside will be a suprise
  7. Dezjay
    10 May 2004
    made some photoshops to rplace the second tombstone with a part of the other door...
    the problem is that the door is verry thick.. i think i'll need a plasma cutter or something
  8. mobius9
    mobius9 Minimodder
    4 May 2004
    why is one door a lot shorter than the other?
    I'd think it would look better than your current setup if they were the same size.
  9. Dezjay
    10 May 2004
    euhm.. because the underbox is shorter.. i'll think i cut the door and then fit the tombstone back so that the power button is gone.
  10. fieroloki
    fieroloki What's a Dremel?
    3 Jan 2004
    Im thinking the 1/2 box on the bottom...Except the small panel that has the cooler mastr logo flip it over so the flat ends are together....Ill try and do a pic to show what im talking about.. :)
    edit: I suck at paint :(
  11. grumblemarc
    grumblemarc What's a Dremel?
    12 Dec 2004
    Y,know the pics for your Shuttle mod thread are totally screwed up now. I hope you're using a better naming convention than simply "1.jpg, 2.jpg, 3.jpg, etc..".
  12. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    I say have the smaller box on the bottom, but cut the top tombstone off (and the piece that supports it (base of case)). Then mod the removed tombstone onto the lowwer one so you are left with one large one.
  13. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    the photoshop edition looks great
  14. DomA
    DomA What's a Dremel?
    7 Oct 2003
    as per all the others, stick it on the bottom but only have the one tombstone, if any......
  15. radek
    radek What's a Dremel?
    7 May 2005
    This looks much better! Keep that tombstone too.
    I would rather see some sort of a graphic in the middle - that would be an excellent focal point, while the top and the bottom tombstones could complement your design with something matching. Besides, why would you want to keep the radiator cooking underneath of your computer instead of letting it breathe on top. Enough? I think so.
  16. webbyman
    webbyman Hax.
    7 Oct 2004
    anyone though about it being at the top upside down? :worried:
  17. Dezjay
    10 May 2004
    well since it is going 2 house 2 rads on both sides and a big heavvy reservoir i;ll stick with the bottom..
    it has more pro's than cons
    1: The case wont be top heavy
    2: I think it looks better
    I'll try to plasma cut the original door to fit the plate where the second tomb stone is. so the second pwoerbutton will leave... i can see than what i like most with or with out the tombstone...
    Because i'm going to a lanparty this night i had 2 had a window :) so i cut one today at work.... its become a sort of wave thing.. AND NO IT DOESN'T LOOK LIKE THE WINDOWS FLAG ;)
    PS i dont wear pink pants.. its the reflaction of the case :D
  18. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Great looking window. Its original and shows off alot in the case. I also think that the wc box will be much better at the bottom also. gl at the lan
  19. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    u should hook up the other power button for i dunno lights or somethin
  20. Dezjay
    10 May 2004
    when i cut the extra door in the right shape the middle powerbutton will begone.. look at the photoshop pic for a sample
