146% Wavemaster
Discussion in 'Project Logs' started by Dezjay, 5 May 2005.
Where should the 1/2"wavemaster be ??
Poll closed 16 May 2005.
  1. TOop
    67 vote(s)
    54.9%
  2. Bottum
    55 vote(s)
    45.1%
  1. phuzz
    phuzz This is a title
    28 May 2004
    You're going to put leather seats in it?!? ;)
  2. Stuntman
    Stuntman Minimodder
    22 Oct 2004
    Idea... How about you totaly flip the direction that the tombstone is going at the top? have it facing downwards, mounted from something on the top of the case... Understand what I mean?
  3. Dezjay
    Dezjay What's a Dremel?
    10 May 2004
    allmost :)
  4. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    is it me or does that window look like the Windows logo :worried:
    anyway great mod dude :rock:
  5. Firehed
    15 Feb 2004
    Kinda flipped around the x-axis and without the individual sections. Wouldn't have noticed if you hadn't said that though.
    It's a different shape though, not just a standard squarish or circular window like a lot are.
  6. drliamski
    drliamski What's a Dremel?
    9 May 2005
    How about this though? Flip the top
    How about this though? Flip the top so its a mirror image of the bottom
    symetrical if you cut a horizontal line throught the midpoint of the 1.5 coolermaster cases
  7. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    its need to go under but u shouldnt have 2 coolmaster polls at the front.
    and where the base of the biggest case is, u need to sand ti back to be a flush line......ie looks like a ful tower but with only one base (the wc unit)
  8. Dezjay
    10 May 2004
    Havent done much this weekend becasue of a lanparty...
    My dad came back with the first frontplate for the airplex 240 rad...
    Also did a bit of cleaning of my desk and reorganised the whole desk
    Now i hope that nvidia will be support dual monitors in a sli config
  9. Firehed
    15 Feb 2004
    As of now... nvidia only allows dual monitors if SLI is disabled at a driver level. You'd have to switch it on and off (with reboots between) to go between performance and dual mons.
    Maybe that will change, but that's how it is at the moment.
  10. fieroloki
    fieroloki What's a Dremel?
    3 Jan 2004
    As of now yes, In SLi only 1 monitor, but ASUS is coming out with a new solution that you can switch between Sli and non-Sli with in the OS with no re-boot. But still only 1 monitor in SLi.
  11. Guest-6374
    Guest-6374 Guest
    Who is that? She looks hot.
    Also, nice work on the case so far.
  12. Firehed
    15 Feb 2004
    The digital bridge thing? It's not the PCIE lanes that's the problem (which is all the card/bridge changes and the bios makes a note of), it's the drivers. You don't need to change anything physically or in the bios to disable multi-gpu rendering
  13. JungleGorilla
    JungleGorilla What's a Dremel?
    21 Apr 2004
    lol... keep it in your pants mate, this is lookin' really good so far, The mini WM is a great idea.
    Keep it up :thumb:
  14. Dezjay
    10 May 2004
    lol i noyiced yesterday :) well thats my girlfriend.. but sheé in indonesia for 3 moths... :( but i'll wil go there on 17 july and stay 1 month :)
  15. Dezjay
    10 May 2004
    Some nice stuff in
    Update 13 Mei 2005
    Hi got some nice stuff comming in today I really need to name http://www.freezinghardware.com For helping me finding the good parts and repleying on all my emails the same day ;)
    K The new stuff
    Some Plug & Cool fittings
    A valve that will be used 2 drain the system
    The Aquacomputer 6800 coolers... verry nice stuff.. I'm thinking of getting the topcovers chromed but im not sure it it wil affect the water or other the water the chroming.
    It has standard blue leds so..
    Few led's
    End like all the new stuff this one has to be dissambled :)
    After a bit of soldering
    And a bit more
    And ofcourse some cablemanagement
    This is the chipset block i'm thinking of drilling 2 small holes in it 2 fit 2 3mm leds but i'm note sure if it will be cool... or if i end up with a messed up chipsetblock
  16. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    Mooi gedaan, de vervanging van die leds en het sleeven.
    Ik heb zelf nog twee twinplex ati VGA blokjes liggen en zoals ik het bekijk is er behoorlijk veel ruimte achter een outlet. De outlet waarvan het wateroverbruggingspunt (woei) het kortst is. Beetje heel sloom boren en goed koelen. Kraken etc gebeurt meestal dankzij de hitte en de snelheid van de boor. Ik weet niet of er ook zo'n ruimte is bij het chipset plexi. Anders mount je gewoon een twinplex VGA plexi plaatje erop?
    Oke, plaatje ter verduidelijking. Quick shop..
    pic says it all. Thanking some tweaker site voor hijacking pic.
    Nice AC-stuff and modding. Keep the stream going. And finish the project before you're off to Indonesia! :naughty:
    Sorry for the Dutch. You Guys should learn it :cooldude: .
  17. Firehed
    15 Feb 2004
    Acutally I'd just think the logo would be the only really lit-up part with an LED but that's just a guess. I'm thinking I may have to use a nearby fan header and wire an LED to that for my setup :D the trick of course being not killing the block...
  18. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    please translate. i don't F****** understand it :grr: :grr: :grr: .
    translation langenberg
  19. Dezjay
    10 May 2004
    Update 14 May 2005
    With the stuff also were 12cm alu led fans..
    Little testrun.. but.. blue led :sigh:
    So take it apart ;)
    Each corner has a 3mm led that needs to bereplaced
    First led replaced..little test :)
    First one done
    All 4 done :)
  20. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    Very nice, keep it up, can't wait for more!
    -Rob
