Scratch Build – In Progress BaDassumption - Photo Shoot...
Discussion in 'Project Logs' started by dutchcedar, 8 May 2006.
  1. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    Big thanks for all the links to 90 degree fittings... :thumb: still haven't found the "perfect" solution, but we're OK for now...
    Dome Blower Reduz... part 1...
    After making these supports for the dome blower, the way the blower was looking was kinda lacking... it was too skinny... but the brackets work nice. They were cut from sprint car block off plates found on eBay way back in the beginning. They attach to the trailing edge of the video cards with #6 screws and nylon washers...
    Not wanting to be stuck because of using scraps that were marginal in size, I used a 1-1/4" thick x 4" wide aluminum flatbar for the blower housing in front and a a 3/4" thick x 4" wide flatbar for the evacuation duct in back...
    They were squared up on the mill... :D
    The top of the blower housing and the bottom of the evacuation duct were machined to the shapes like this...
    The left side of the rear duct was machined, and sanded to shape, including a hose guide for the line running into the video card cooling blocks... in the blower housing, a recess was machined for the fan base, holes tapped for mounting screws and a hole cut for the fan wires...
    The red circle on the right is where the tubing will enter the backplate coming from the radiator, while the other circle is where the tubing will exit the case going to the radiator... and yeah, I'm confused too... :D
    On the other side of the rear duct, I machined a small ledge, so the manifold can be attached securely using only a single screw...
    This is where we're at so far...
    From above... its coming together quite nicely.
    Up next will be shaping the blower housing, making a cover plate for it, a clear amber cover between the two and a design machined into the top of these parts... :hip:
  2. mattthegamer463
    26 Nov 2004
    Wow, that blower is madness...
    How much do you think it weighs, considering that whole chunk is machined out of a single block of aluminum? Incredible craftsmanship though, and excellent design.
  3. dutchcedar
    24 Oct 2004
    ^^^ I don't know... the pile of chips is pretty big. :D A good guess is that about 80 - 90% of it wil be machined away before its done... so 6 -12 ounces.
  4. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    darn you! darn you! as soon as i saw you had an update, i had to put down my homework and check it out!
    seriousy, though, that is some good milling. are you going to keep that gap over the water blocks, or are you going to bridge it somehow?
  5. dutchcedar
    24 Oct 2004
    ^^^ :hehe:
    Yeah, it'll be "bridged" with a see-through plastic cover (don't wanna see the video cards but want to see the cooling blocks 'n stuff). I'm waitin' on some cutters to put slots in both of these aluminum pieces, so that the cover can be flush with everything, but not require any screws or fasteners. Hope that makes sense... :hip:
  6. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    looks terrific. 'nuff said. :thumb:
  7. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    yep, makes perfect sense.
    one thing I would suggest is to put some more support to the blower duct and fan housing rather than just the vid cards incase it gets turned on its side for whatever reason. Would be a shame to damage the vid cards due to an accident of that nature.
  8. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Looks very nice but make sure to show off the fact that you have THREE video cards.
  9. dutchcedar
    24 Oct 2004
    To "clear" things up a bit... :hip:
    I tried some milling on the bridge between these aluminum pieces... it worked out great... wasn't sure how plastic would fare under a carbide cutter, but it was like slicing butter. :D
    I'll mill some slots in the aluminum pieces to take the pared down ends of this acrylic cover (hope that makes sense)... and there will be a small clearance between the plastic and the waterblocks...
    Anyways, this ought to give ya an idea what I'm up to...
  10. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    nooooooooooooooo dont put orange acrlic.
  11. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    hmmm ... I am begining to dislike this jealousy i have towards you! :grr:
    Looking VERY well done mate :clap: :rock:
  12. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Holy crap. I wish I had some tools like yours. And I know how much money that flatbar costs. I'm guessing $60-80 for that duct alone. Nice work
  13. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    VERy sexy dutch!! I love it..
  14. Evenge
    Evenge Minimodder
    16 Sep 2006
    Sexy indeed!
  15. Evenge
    Evenge Minimodder
    16 Sep 2006
    Edit: Double post... Sorry
  16. ComputerKing
    8 Sep 2006
    OMGGGGG
    MAN . Come on !!!! you somke every one
    man this very damm sexy with some lights it will rock !!! :rock:
    Go on ...
  17. ottzen
    ottzen What's a Dremel?
    28 Nov 2006
    Damn, boy!
    Now that is some sexy machining. And I have to say, that I love the orange Acrylic blended with the shiny metal. Perfect work!
    (If I were you I'd propably be sitting with it every night going "My precioussssss!" ;))
  18. mattthegamer463
    26 Nov 2004
    I must agree, something like a light gray plexi would look much better than the orange. The choice is yours though, Ill be amazed either way.
  19. Bluephoenix
    3 Dec 2006
    Since the dome is already orange, the orange-orange mix would turn the second plexi almost opaque. the best idea would be to use clear plexi, and the orange dome will provide the orange tint.
  20. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Amazing mod. I just dont understand the purpose on this blower-outlet combo, as it seems to only cool the fittings of the waterblocks. Or is it supposed to exhaust hot air from the dome?
