Case Mod - In Progress Corsair 600T Graphite Case Mod Project
Discussion in 'Project Logs' started by mnpctech, 2 Sep 2010.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Thats good to hear, thanks for tuning in Jason :D
    Here are some screen shots of the left custom side panel drawing in progress... The vents above the window are 1/4" wide. Smaller opening to right will be access doorway to HD bays.
  2. mnpctech
    21 Apr 2003
    Still dabbling with the panel design, but committed to window location on the 600T's panel.
  3. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    That is going to be one beefy side panel :rock:. I like it! I liked the duct over the hdd cage in the concept drawing. Are you planning on keeping that design or moving to an "open" window?
  4. mnpctech
    21 Apr 2003
    Glad you like it Scott. It will be an Access door to the HD cages. The striped portion is the handle
  5. The boy 4rm oz
    10 Apr 2008
    An access door? So you won't have to remove the side panel to swap out HDDs Bill?
  6. stonedsurd
    11 Mar 2009
    That's a great idea.
    :D
  7. phinix
    phinix RIP Waynio...
    28 Apr 2006
    This is going to be great, I will be watching it...
  8. StonieX
    StonieX What's a Dremel?
    23 Dec 2003
    Every day I stand up in the morning and hope to see more of this project! Keep on going, I love it! ;)
  9. Zesti
    Zesti Aluminium + file
    9 Feb 2010
    Very interesting project - I will definitely follow this.
    I was also wondering if there´s enough space under the top mesh for one more 120mm blowhole? I´m thinking about modding this case to hold 360 rad in the roof..
  10. Cheapskate
    13 May 2007
    QFT, And best accidental double meaning ever posted.:D
    2 things:
    -I'd like to see you make a cover for the unused and visible wiring grommets.
    -More armor panels! Tank it up! A couple on top mounted with those rubber washers/spacers you like might be cool.:D
  11. mnpctech
    21 Apr 2003
    @boy, Yes. I thought it would cool.
    @stonedsurd, glad you it.
    @phinix. Thanks for tuning phinix!
    @StonieX, thanks, sorry I haven't had more updates
    @cheaps, How about billet plugs for unused watercooling in/outlet holes?
    @Zesti, you will have to modify the exterior plastic, so the entire 360 rad has ventilation
    You can see the top panel exposed @ 3:00 into video review
  12. Cheapskate
    13 May 2007
    That would work, but seeing that pic in the video makes me realize the grommets are all behind the mobo. -It would be overki.... nevermind.:D
  13. mnpctech
    21 Apr 2003
    and Corsair plans to install a system, so best left "as is" :D
  14. Colossous
    Colossous Minimodder
    28 May 2007
    Liking the plans Bill - should be another good one.
  15. Moriarty
    Moriarty Evil Genius
    15 Apr 2008
    I love a bit of grime so those concept pics have got my interest, it looks a smashing case to start with too.
    A door in front of the HD bays, ingenious.
  16. Moriarty
    15 Apr 2008
    As my computer decided to double post might as well use this message to say I'm with Cheaps, can't beat a PC with some ablative armour panels.
    Maybe it's trying to tell me I shouldn't be on bit-tech at work:blah:
  17. DeadP1xels
    30 Nov 2009
    You're such a Mod whore Bill :p
    Could'nt even leave this poor case a Mod virgin for a little while could you!
    Everything you touch is "I wonder if i could put another cooling fan in this"
    I kid.. Awesome work there :)
  18. mnpctech
    21 Apr 2003
    @Colossous, thanks Rich! btw: I love the paint job on your Celtic case :rock:
    @Moriarty, haha! I do plan to indulge in more countersunk fasteners in the panel
    @DeadP1xels, It's an addiction thats good for you :D
  19. Cheapskate
    13 May 2007
    Yeah, ablative armor! -only I didn't want to use that word because it implies the parts fall off.:hehe: It also brings to mind 'chocolate bar panels' seen on Russian tanks. That wasn't the look I was hoping to see here.
    Countersunk is the sh*t. You know what I like.:D
  20. mnpctech
    21 Apr 2003
    lol, I'll have to image search for those tanks. Countersunk holes for 10/32 socket head screws, in the channel around the border and attaching window.
