DarkWater SpaceShip - First Prize winner!!
Discussion in 'Project Logs' started by Kumo, 10 May 2005.
  1. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    One more step.
    The other side shield and details. Still left some work with kitbashing.
    Inside there is mesh like in the other side.
    While doing that i drilled my finger a little... :wallbash: Its fu*ki*n* @#! painful, but don't worry, was 1mm drill and tomorrow will finish this side :thumb: .
    More to come.
  2. DickH
    DickH What's a Dremel?
    6 Jun 2004
    how deep was the hole?
  3. Kumo
    18 Oct 2004
    I don't know... And i think i dont want to know XD Not much. thanks
  4. Kumo
    18 Oct 2004
    Good and bad news...
    I`ve finished the other side. The white spots are epoxy to cover imperfections and screws.
    Also i`ve started the top decoration.
    First steps in the top. The main shape is to cover the fillport tube. I think i`ll end the decoration work and began the paint work this weekwnd.
    Well, the bad new. Very bad new to me.
    This afternoon i`ve powered on the pc and realized the temps was high. But at five o`clock here the ambiemt temp is almost at maximum. The problem was in the VFD, pump reading N/A. My mpc350 seems to be die. I don`t know why and how it happens.
    I`ve tried with other molex, it makes (i feel) a "click" and get warm within minutes, but don`t move water. I`ve used this pump sice about 3 1/2 months in discontinued use. So i cant belive that. Also, i`ve tried to blow the tubes for check am obstruction in the pump, but the air pass to the exit... I don`t know...
    So, that my problem. What do you think? I should order a new DD 12DCC pump (Not another from swiftech) that is a expensive solution (75euro + shipping) or back to air cooling (AGP included with zalman vf700 for example, if i can fit it in).
    To make the problem bigger i have a LAN in 15 days... Some days is better don`t wake up, until the next day.
  5. DickH
    6 Jun 2004
    My pump did that too, I took it and banged it a round (gently) and it started working. I don't know what the deal is, but I hope it doesnt do that when its all assembled, because I dont have access to the pump once everything is together in my shuttle. You could go with the air cooling, or if you dont what that pump anymore, try that C-Systems pump
  6. Kumo
    18 Oct 2004
    Yesterday, late, i dismantled the system to extract the pump. Then i open the pump and cleaned it. Maybe some oxidation has blocked it because after that the pump come back to run.
    Today i'll do a deep clean and check the mix proportions of distilled water and anti-freeze. Or search other aditive.
  7. Kumo
    18 Oct 2004
    Some pics of the top decoration, finished yesterday late night. The next step is the paint.
    What do you think? Today i`ll begin with the paint job and maybe add some details more.
    I`ll pic some pic more this evening.
  8. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Najs!!! Inspired by Crimson Sky or something?
  9. Kumo
    18 Oct 2004
    Crimson Sky is a master, like Mashie, they are two of my inspirations fonts like the rest of you. I belive, any modder can think (and make) great ideas. Anyway i've painted miniatures and models since child, although i wish my skill will be high as Crimson Sky.
    But, do you like it? When painted it will look better. :)
  10. Kumo
    18 Oct 2004
    The paintjob has started!
    With the same colour in all surfaces, the hull looks better
    Black primed.
    Some putty and sanding work.
    The base coats with Mat Dark Grey (Duplicolor Spray). I left some darker spots to improve the "space ship" look. Tomorrow will be the day with the small brushes and miniature paints, for the details.
    After all it will be aceptabily good looking. :p
    More soon.
  11. DickH
    6 Jun 2004
    I was expecting it to be white or grey. That looks good though, kind of tankish
  12. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    Looks awesome man. I love the paint look. Maybe you should take some plaster and sling it on there to make it look dirty looking Then paint the plaster tan brown so it looks like mud splatters.
  13. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    Very, very cool.
    I was sort of skeptical when I saw the unpainted pictures, but the uniform coat of paint really makes it come together... (...duh...I've done a bit of model building, I should know these things...)
    Having the front more spaceship-like - a more pointed nose or something - would have been cool, but it would also have been a lot more work!
  14. Kumo
    18 Oct 2004
    Thanks for the comments, dudes.
  15. Krikkit
    21 Jan 2003
    That's some fine work - the shaping on the hull with the fine details are rather excellent.
    Plus we all love WC'd shuttles. :p
  16. LOTTARO
    LOTTARO What's a Dremel?
    1 Jul 2005
    wow! looks like The NOSTROMO! :D
    Great work!
  17. cysus
    cysus What's a Dremel?
    14 Apr 2004
    That looks amazing, the modeling is great and the paint's had a great start. This is an impressive mod.
    Kumo, do you do alot modeling (ie. model airplanes, warhammer 40k, etc)?
  18. Kumo
    18 Oct 2004
    Kritkit@Thanks
    Cysus@Starwars models overall, warhammer 40K (Blood Angels mainly), plane models (i love WWII planes) some car model and a lot of miniatures of diverse types, are my paint curriculum :) but my skill has a weak point, my patience (and maybe my room's space XD )
    Lottaro@If its the Nostromo, maybe i must talk with BootUpBudha to get a mini black-box XD
    I'm just paintig details. I hope, this night can post the first pics.
  19. FanatiK
    25 May 2004
    another thing that would look cool is to put two antenneas on them just like bradley tanks have but instead of pointing them straight up have them slop back at a 45 degree angle. That would look great and it would break it out of that squarish look it has.
    Like this.
    http://www.3-d-models.com/3d-model_files/br1.jpg
  20. Kumo
    18 Oct 2004
    I have plane to put some short antennas more, but since it isn't a tank (the twin las cannon was a real option for some days) that big antennas don't match with the thme, i think. But i'll study that... never knows (maybe a new wi-fi system? :D :D )
