Other DIY thread
Discussion in 'General' started by CrapBag, 21 Apr 2021.
  1. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Looks sensible to me?
  2. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    :jawdrop:
  3. ModSquid
    16 Apr 2011
  4. Ajbod
    Ajbod Minimodder
    12 Dec 2016
    I started my working life in Butchery/Slaughtering, the standard there was to send newbies, to another Butchers for the long weight, or a long stand. One lad knew the score and went home for the rest of the day, they couldn't do a thing about it.
  5. The_Crapman
    5 Dec 2011
    When I worked in the kitchen we sent someone to the walk-in freezer for a leg of salmon. He was gone for an age, came back blue as anything clutching a couple of packs of smoked salmon saying he couldn't find a leg but would these do. No one currently working there had ever seen salmon on the menu. Still no idea how. :hehe:
  6. ModSquid
    16 Apr 2011
    Now you've said that, we housesat once and told the lady (our friend) that the sausage rolls we found in her freezer were a bit tough and she said she'd never bought sausage rolls at all in her life due to allergies...
  7. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    Those were the local rabbi's tips, Oy vey!
    ElThomsono likes this.
  8. ModSquid
    16 Apr 2011
    Ha! Think he might have been enthusiastic about his art then - he's not supposed to take all that off, is he??
    But that does explain the calamari.
  9. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    My nickname for my boss is foreskin. He disappears when it gets hard.
    adidan, IanW, ModSquid and 2 others like this.
  10. ElThomsono
    18 Mar 2005
    Ok I'll give you a like as I've never heard that one before.
  11. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Hey lads, just came across this video whilst researching food safety of wood finishes, thought it might be of interest. I remember Ian and others discussing this subject back when he first started making cutting boards, I'm now revisiting it because I'm making planter boxes for growing vegetables:
    adidan likes this.
  12. Cheapskate
    13 May 2007
    I can verify all of them taste terrible. Certain latex paints are not bad, though. Removing the lead has taken a lot of the sweetness out.
    -I've tortured myself lately by repairing two bathroom doors. They have been badly beaten since the late '70s. Unfortunately, my donor door for veneer was from another house and apparently a lower grade material.
    -Also unfortunately, My refinishing came out a lot better than the original finish. :worried: It takes 10 days to sand and finish a single small door. I think I'll stop here.
    Edit: Forgive the junk. This is the laundry room.
  13. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    While I must admit the end result is quite impressive, I can also say sod that for a laugh.
    Had similar thoughts after repairing cracks in a sink with enamel repair and then hours of sanding and polishing with various grades. In retrospect would've just sprung for a new sink. Never again!
    Cheapskate likes this.
  14. Cheapskate
    13 May 2007
    My options for replacement are Chinese crap that's 99% mdf with a wafer thin layer of veneer, or nothing.
    Byron C likes this.
  15. Idioteque
    21 Aug 2004
    Have you considered these? Better than nothing, but not quite! :hehe:
    adidan and Cheapskate like this.
  16. Cheapskate
    13 May 2007
    The longer you look, the worse it gets. -Aside from the toilet area being photoshopped in.
    Idioteque and adidan like this.
  17. GeorgeStorm
    16 Dec 2008
    Wanting to attach 3 ikea larbro mirrors to my garage wall but want them fairly easily to remove as intend on taking them with me when we next move. Was thinking of making a wooden frame out of some battening, 9/12mm ply, and then attach the mirrors to that, so have a hopefully flat 'single' mirror unit, and then thought the simplest might just be a batten on the wall, this resting on top with a couple of L brackets at the top to hold it in place as the batten would take the weight (25kg or so I'd guess).
    Walls are concrete I think, fairly flat with a bit of texture to them.
    Am I overthinking it?
  18. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    I'd just use the mounting clips that come with the mirrors. Drill 4x holes per mirror, job done. They come with 4 clips you mount straight into the wall. Two for the bottom that hold the weight, then two others meant to go on the sides towards the top for stability that slide in and out. They're easy enough to reposition if you want to remove gaps between each mirror. And to take the mirror down you just slide the top clips, then lift the mirror off.
    Krikkit likes this.
  19. Krikkit
    21 Jan 2003
    Definitely - nice, easy mounting solution, easy to remove them for cleaning or something as well.
  20. GeorgeStorm
    16 Dec 2008
    Yeah the aim was to have them all together for a single mirror look, and I had just seen comments from people saying if the wall isn't 100% smooth/flat they had distorted look to them, but can try it first at least I guess.
