Case Mod - Complete ⭐ Project ALIENBASE - Alienware Aurora R4 Case ATX mod
Discussion in 'Project Logs' started by 4LIEN, 10 May 2020.
  1. Flop Ysh
    Flop Ysh What's a Dremel?
    17 Aug 2020
    @4LIEN Thank you very much
    With such a higher density of led, only one row of led should be enough then
    have a good day
    ps: it seems that PCs only uses WS2812B (on MB or controllers like the Corsair one), or at best WS2813 since they use the same libraries and Voltage. I've found some at 144led/m with SMD 5050, on my local amazon : that should be quite bright :cooldude:!
    4LIEN likes this.
  2. 4LIEN
    4LIEN Modder
    4 Jan 2020
    I'm back guys with a very little update, nothing special, in these days I am devoting myself to many small details...so here are some of these details!
    This will be the CPU waterblock from Barrow
    As you can see the metal decoration are gold plated, very cool but not for my project
    So i removed them all
    And painted with aluminium finish
    Another little work was done on the USB 2.0 and AUDIO connectors, i've removed all the PIN, soldered black wires and fitted black connector.
    Toru likes this.
  3. 4LIEN
    4LIEN Modder
    4 Jan 2020
    So guys today its time for an interesting update! :rock:
    To assemble all the parts I made, i need to proceed in a precise assembly order, so one of the first parts is the front radiator with the tank.
    So I got to work preparing the tank for assembly ... but first i need to mod it!
    This is the original tank reservoir look, with the super classic and already seen 1000 times, T-virus
    But for this mod i want something different to put inside the tank!
    So i found this case, i think its from 2000/2005, probably someone of you guys remember this!
    I've removed from it one of the front plexi bar with air bubble; and from the t-virus i've removed the G1/4 support
    Cutted the bar and maked new hole for 5 mm LED, and then polished
    To polish the hole, I've used the dremel with synthetic cotton and abrasive paste!
    Glued all the parts and installed an o-ring
    Then i designed and realized with laser these hex forms
    And installed on the plexi bar!
    Anddd this is the final new look!
    Basically I wanted to create a kind of "energy cell" or reactor, in short, something cool that seems to generate energy!
    The effect with the LED ON and the liquid inside I can assure you that it leaves you speechless, but for now I will not show you anything, you will see it as a surprise in the end! :grin:
  4. Flop Ysh
    17 Aug 2020
    NEEEEEED
  5. kim
    kim hardware addict
    10 Jan 2016
    I am already speechless without the light effect :jawdrop:... your build is absolutely epic, and every update is stunning :wallbash:
    4LIEN likes this.
  6. Vault-Tec
    30 Aug 2015
    OCM.
    Obsessive compulsive modding.
    Sick dude !
    4LIEN likes this.
  7. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks kim! I really appreciate your comments! :winking:
    LOL, i think i'm officially affected from this pathology! :hehe: :dremel:
    Vault-Tec likes this.
  8. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    OMG! i owned one of those cases!!!
    Amazing the ideas you come up with , This is mixing old skool modding skills and ideas with modern ideas and techniques and i'm loving it !!!:thumb::thumb:
    4LIEN likes this.
  9. 4LIEN
    4LIEN Modder
    4 Jan 2020
    The time is going really fast, almost a month has passed since the last update! :duh:
    So now it's time for BIG updates!:clap:
    I finally managed to install the first panels and covers on the case!
    Now i have to do a lot of wires management!
    20201001_173952.jpg 20201001_095305.jpg 20201001_095656.jpg 20201001_174219.jpg
    Sleeved custom extension are ready, maked in collaboration with HardWire
    And also i've installed another radiator, the XSPC TX120 (20mm thickness) that goes on the back of the case, you can see it in the first picture.
    These special look fans, made by ALSEYE, will be installed on it, and the other two fans on the upper radiator, that i will show i the next step.
    From the first time I saw them, I immediately thought they would be perfect for my mod, i really love the drone look! :grin:
  10. Defyant Mods
    14 Sep 2004
    That full shot of the side :thumb: this is going to look amazing ! The fans are the perfect choice for this mod :rock:
    4LIEN and DB Custom Towers like this.
  11. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Meanwhile in these days it's arrived the new hardware! :rock:
    I remember all that these parts are NOT sponsored.
    Finally i opted for i5 instead i7, because this is the best choice for what i have to do: gaming!
    Fall in love with this RAM! It's good putting Predator RAM inside Alienware computer?!? :eyebrow: We'll see! :lol:
    This mainboard it's absolutely awesome, desing and build quality in a perfect mix, i can't resist to the aluminium heatsink!
    Just a little note about the red capacitors on the bottom left in the audio zone, i will probably make a black plate to cover them!
  12. Defyant Mods
    14 Sep 2004
    That's some really really nice hardware ! and respect for going without a sponsor :rock: Predator V Alien !!! You could make a movie out of that :naughty:
    4LIEN likes this.
  13. kim
    kim hardware addict
    10 Jan 2016
    I agree :grin: ... otherwise, a wonderful MB for yourproject :thumb:
    4LIEN likes this.
  14. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks guys! Every detail need attention to make the difference!
    Defyant Mods likes this.
  15. 4LIEN
    4LIEN Modder
    4 Jan 2020
    I'm working hard to get all parts assembled, so here are more updates!
    Assembled the Alien Portal to the main wires cover
    Finally installed the main board and the extension! It was hard to get all the wires in position under the main cover, it take me a lot of time and some extra modifications.
    Also the top radiator is in position
    With all the fans installed
    Bonus items: i found a rare set of PCI cover with hex holes, very perfect for my MOD! And of course a set of green screws!
    And also i found a bargain on Amazon for this NVMe SSD, i will use it only for GAMES! So they will load faster!
  16. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    I can't see the image alone?:cooldude:
  17. kim
    kim hardware addict
    10 Jan 2016
    same here, no pics are visible, and links are dead:worried:
  18. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Fixed pictures! They was probably lost last night in the bit-tech server migration! :duh:
    kim likes this.
  19. Toru
    Toru Minimodder
    14 Dec 2013
    very nice hardware and nice cover!:clap:
    4LIEN likes this.
  20. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    This is coming together fast:), nice use of the LCD inners gives a cool effect, and I cant wait to see that res filled and lit.
    4LIEN likes this.
