Project ATI X800 SSR Pickup: Update (Have completed assembly and testing)
Discussion in 'Project Logs' started by Robster, 13 May 2004.
  1. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    Think of the future, lan parties held near ponds and such.
    Mine is better than yours because it floats. :thumb:
  2. Robster
    Robster What's a Dremel?
    11 Dec 2003
    Oh yah about the paint it will be getting a new paint job just not to sure what yet as i havn't fully comited to a vid card yet and it will be based on that would really like the ATI though would be the whole gargoyle theme so would give it that bad ass look with the reds and blacks and silver murals.
    We will see will need to decide this next week for sure as it will take a couple weeks just to get that done.
  3. Robster
    11 Dec 2003
    Power supply done
    Well time for anouther update i managed to get the powersupply mounted the only bad part about this is if anything goes wrong with this it will be a big pain to replace but oh well.
    Here is a shot of my not so great mounting but hey considering i am doing this with no shop what so ever just the tools at hand and spare stuff.
    But over all it worked out not to bad now time to extend and wrap all the powerlines so that we can power everything.
    Here is anouther shot ran all the wires in the cab figure this would be the best as there is not much room under the floor for anything.
    Also while i was at it i got looking at the sides of the motherboard tray and realized that you can see through the wheel wells so figured need side skirts to hide everything under the motherboard as this is where the electronics for the remote part will be as well as the harddrive.
    Here it is fitted all on the main chassis this is coming together pretty nicely i think this one is going to turn out pretty nice.
    Here is a little closer shot of the fit on the motherboard tray and the main body.
    Next we will start putting the parts back that will make this still a remote control unit and see how it fits and if it will still drive.
  4. Robster
    11 Dec 2003
    Remote control back in
    Well now to put all the remote controll stuff back on and see if it still drives.
    Here is the main circut board for the rc part as well as put the axles and motor back in.
    Oh yah almost forgot the one thing i had to do was relocate the battery tray as it was in the bed of the truck and now that space is taken up by the mohterboard so remounted it underneath.
    I am going to leave it like this as no one will see it once all the parts are on but this way i can still use the rc part as i need.
    Here is a full shot of the chassis with the front sterring in this should work.
    Well this was a quick update not to many pics but i will update somemore as i go along oh yah tested it and so far so good all the elctronics are working once i get some of the othere stuff bolted on i will put up a little vid of it driving.
  5. toidiochysp
    toidiochysp What's a Dremel?
    30 Apr 2004
    looking good so far. are you going to race it against the hummer?
  6. Robster
    11 Dec 2003
    Hey why not will drive both into the lan so maybe but it won't be any quick race a little to much in parts to wreck it
    But would give a whole new meaning to Computer Crash.
    :D
  7. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    idk the scale of the ssr but u should buy some of those rc racing wheels it would be a nice touch :idea:
  8. Robster
    11 Dec 2003
    That would be an idea as will have to look into it i found that there were some wheels out there with spinners on them now that would be cool but will have to see if they fit
  9. FILTHY1337
    4 Jan 2004
    oooo make spinners get some 60mm fan grilss(maybe) and make a ball baering at the hub just like on fullsize wheels cant be to hard :dremel: :dremel:
  10. RR5
    7 Dec 2003
    All that you need to do now, is add the supercharger :D
  11. Robster
    11 Dec 2003
    Would need to be 30mm fan grills and a little hard to find those and got looking around and the rims for a RC are 22mm rims so would probly look a little small on the truck but hey will keep looking around and see what i can come up with.
    Now just need that fancy cnc machine and hell could make my own.
    Dreams Dreams Dreams :sigh:
  12. Robster
    11 Dec 2003
    It is supercharged just in a different way will be putting a 3.2gig P4 in should be enough juice then add a top line vid card overclock it a bit and there is your supercharged comp
  13. RR5
    7 Dec 2003
    0 to benchmark done in less than 3 seconds. :lol:
  14. Robster
    11 Dec 2003
    Dash work
    Well i have a delay on parts looks like i will not have them till early next week but no fear still lots to do on this so here is a quick update on the work done on the dash.
    Earlier i decided to mount the CDrom in the dash now i got looking and i had a few switches around that would fit in the dash also.
    So out comes the drill and now the comp start button and reset button as well as power led and harddrive led are now all in the dash.
    Sorry got carried away and forgot to take pics as i went so here is the finished product.
    Here is a shot of the back side.
    Well while i was in here i thought about the gauges and how they seemed to be lacking something so thought why not light them up seeing as with the roof off now you will see it better so here is the build on that.
    At least this time i remembered to take pictures.
    First we need to drill some holes as everything inside this has to go.
    Time to open them up a little this should work with any luck
    This was made from a front panel off a old case forgot to take a before shot but it was a drive bay cover i am sure lots of you know the ones i mean.
    Ok now to put some 3mm leds in to this tried to drill them so that you will not see them directly.
    Well time to test them and :clap: they work now to mount them see how it looks.
    Well all is good this looks sweet worked out great.
    Oh yah i am using red leds because of the color scheme as well as it was the only 3mm ones i had. :sigh:
    Note to self buy more leds. Never seem to have enough around here.
  15. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    ha. I got to admit. very tidy. And alot of work...... Good work;)
  16. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    Excellent mod! Man, you have a lot of free time!!!! :clap:
  17. Robster
    11 Dec 2003
    Paint idea
    Well got working with photoshop and finally came up with a paint scheme for this truck kind of going out on a lim with this one as i am not real sure i can get my hands on one of these vid cards.
    But this just came out to nice to not show.
    Here is a link if you want to get the wallpaper of this i made one that is 1024x768
    SSR Comp Wallpaper
    well here you go time to try it out
  18. RR5
    7 Dec 2003
    Good luck finding someone to paint that for you.
    It would be awesome to see in person if someone could pull that off, but I'd have to settle seeing it online.
  19. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    printing out a decal possibly?
    very slick :thumb:
  20. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    good luck on the laminate, there hard as hell to apply, but i must say, zap might be getting a run for his money on his ati case. I WANT THAT AND ITS PICS!!!!!! :waah:
