Scratch Build – In Progress Project: HourBeforeDawn, 10 of August
Discussion in 'Project Logs' started by HourBeforeDawn, 27 Oct 2006.
  1. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    dam today is ur lucky day
  2. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Okay folks here is a pic of the sound dampening foam that I got in yesterday
    This is the first piece of SD Foam that I laid into the case, as you can see this case is pretty massive
    And now the whole bottom of the case has been layed with SD Foam, I will have to wait until I get a few items in for this case before I can lay the rest of the sound dampening foam so this will be completed a little later down the road. ^^
    Here is a pic of the rear of the case with the foam in place and done, ya I know you can see lines but no worries this case will be jam packed with stuff you wont be able to see the lines/space between each foam piece ^^
    Also I plan to use Sonex Mini Willtec professional acoustic absorption foam from mnpctech.com for all the side panels, this foam is just for areas where I need it to be as flat as possible as things will lay or be bolted down in that area.
    Also the scraps of that thin foam I have left will be cut into small pads that will then be placed on all the parts that slide and then screw down to the case to add as a soft buffer to further reduce vibration and possible noise.
  3. HourBeforeDawn
    26 Oct 2006
    Im going to do the last coat of paint on the case when Im done test fitting everything, that way if I scratch it during test fit it wont be a big deal and I wouldnt have wasted time then.
  4. Ultimate Gamer
    Ultimate Gamer What's a Dremel?
    3 Nov 2006
    looking great i cant wait to see the finished product get working fool :dremel:
    lol jk i like this smilie :dremel:
    i also like my dremel lol
    looks cool
  5. HourBeforeDawn
    26 Oct 2006
    ya the end of this month is going to kickass, I get my secret item that I will revile to everyone once its in my possession which may require extensive modding to the case to get it to fit/work ^^ and I get a free coupon for a copy of Windows Vista Business, I know its not ultimate but free is free and the only thing missing is the Media Center stuff which I wouldnt be using anyways. I will also be getting my crappy laptop back from dell and get my dell credit cards paid off and the account closed WOOT ^^ as well as other things already mentioned in earlier post :)
    So you wont see much updates happening until the end of the month as I will be busy with work and family and be poor for that time period lol
  6. robodude666
    robodude666 What's a Dremel?
    25 Nov 2006
    Ohh, I just read the whole project log over and I realized my name was mentioned :clap: yay! Im famous now =P
    Awesome job mate and hope the secret item fits well ;) Everyone else has to wait to find out what it is :O! HAHA xD Ohhh im evil.
    Rock on mate :rock: And good luck with the girl ;)
  7. Evenge
    Evenge Minimodder
    16 Sep 2006
    This is getting better and better! :clap:
    Keep up the good work! :thumb:
  8. Ultimate Gamer
    3 Nov 2006
    ok very cool what are you planning one of those 1K watt psu's? lol they sell um
    looks good :D
  9. HourBeforeDawn
    26 Oct 2006
    nope but I do plan on buying one of those 1100watt PSU, I hope by the time I start getting the hardware that a 1200watt model comes out because thats what I really will need. ^^
    ya the power company is going to love me =p
  10. Ultimate Gamer
    3 Nov 2006
    lol ya they are well i have a hiper 580watt in this comp and for my new one i got another hiper 580watt so thats over 1150 watts then my brothers computer other brothers computer and my dads comp and my dads laptop lol were proabley just using over 2000 wats in computers camers cell phones laptops monitors ect ect ect lol tvs
  11. robodude666
    25 Nov 2006
    Question: How is the KWh (kilowatt hour) determined? Is it the number of kilowatts used per hour? So if you have 1000W supply and it runs for an hour you pay for 1 KWh? Thats pretty crazy. Thankfully im running on a 300w supply :p
  12. HourBeforeDawn
    26 Oct 2006
    there is a ratio and what not that the power company uses but I never took the time to figure it out, also depends on who you go through as a power provider because cost may very depending on peak hours and what not.
  13. Ultimate Gamer
    3 Nov 2006
    ya my peak hours is during the day
  14. pioneer1976
    pioneer1976 What's a Dremel?
    28 Apr 2006
    i must say this is looking outstanding, love the color choice. the red and black go so good together.
  15. HourBeforeDawn
    26 Oct 2006
    Well according to UPS, I should be getting my secret item that I will tell everyone about tomorrow, so expects lots of pics ^^
  16. HourBeforeDawn
    26 Oct 2006
    Alright well I got my package today and well here it is, the item that I won off of eBay for $230.00us including S&H a USED Asetek Vaporchill Phase Cooler.
    The case is in rough shape but the cooler is in great condition and thats all that matters to me as I will gut it out of the case and install it into my HBD Case.
    Well here are some pics;
    The case (the case for the most part will be tossed):
    The Phase Cooler:
    Tomorrow I will be testing the system to make sure it functions correctly and if it does I will then remove the unit and install it into the case, looks like I wont have to modify the case much to get this cooler to work. ^^
  17. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Lucky bitch! :D
    Congratulations on such a nice buy. Always wanted one of those but they're way too expensive for me.
  18. Trash_Master
    Trash_Master Fire in the hole!!
    28 Oct 2006
    that looks totaly sweet :D i cant wait to see it in action :D like the black and red mix :)
  19. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    That's one hell of a weird case; I've never seen a Power Supply mounted up-right. Nice find with the phase cooling, too. ;)
  20. Ultimate Gamer
    3 Nov 2006
    ya they do have cases like that but are preatty rare nice find :)
