Scratch Build – In Progress Project: HourBeforeDawn, 10 of August
Discussion in 'Project Logs' started by HourBeforeDawn, 27 Oct 2006.
  1. sailorboy
    sailorboy What's a Dremel?
    10 Jan 2006
    WoW... This is really greatlooking! just read the whole thread. Im looking forward to se that phase cooler going in. Keep up the good work!
  2. customh
    customh conflagration.
    22 Oct 2005
    put that baby in!!
  3. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    thanks for your comments, I have to dig around for a old PSU to use for testing this thing so as I find one I will fire it up and take some more pics.
  4. Ultimate Gamer
    Ultimate Gamer What's a Dremel?
    3 Nov 2006
    how cold does that vapor chill get like -30F
  5. HourBeforeDawn
    26 Oct 2006
    it gets down to -29c which is -20.2f
  6. nightmare03
    nightmare03 What's a Dremel?
    5 Jun 2006
    Loving the mod, been subscribed for a while!
  7. HourBeforeDawn
    26 Oct 2006
    also after looking at the unit I think I will have to take it to a specialist in working with copper and refrigerator units because if I want this to work I have to have the arm come up not down and well its a copper tube under that neoprene foam well at least I think the copper tube runs through the whole foam tube so I will look into that more tomorrow and well if it does I could try bending it myself but if I crack the copper there goes the coolant gas so I rather leave that to someone with better experience, so I will have to hunt for someone in that field.
    So if any of you have experience with using this type of phase cooler and could give me some info on it would be great such as is it a copper tube running from the copper block all the way back to the compressor tank? and any other help[ full info would be great.
  8. HourBeforeDawn
    26 Oct 2006
    Well I stripped away the insulation foam and reveled an easy to bend copper tube, so I will be able to easily form it to the shape I need to get it to work with my system without any problems all the tools I need for this is in the shop ^^
  9. Ultimate Gamer
    3 Nov 2006
    how does it get so cold what does it have in it?
  10. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    its a fridge. almost same mechanism. as for details, it has something to do with refrigerant gas.
    read this thread:
    http://forums.bit-tech.net/showthread.php?t=121645
  11. HourBeforeDawn
    26 Oct 2006
    Okay well I started the process of moving the cooler over to the other case but first some pics of the two cases next to each other.
    Alright now some pics of the cooler in its new home, the cooler block still needs to be formed to the right location once I get the mobo in place.
    I still have some work to do such as final placement of the cooler and bolting it down and wrapping up the wiring and the like.
  12. Ultimate Gamer
    3 Nov 2006
    you need to clean up the vapochill it looks real dirty :)
    looks nice :)
    i have a dog that size :p
    lol heres a pic
    isant she cute She helps me mod :)
  13. HourBeforeDawn
    26 Oct 2006
    yes very cute dog, I had a dog just like her but we had to put her down due to old age, but as I mentioned this is just a fitting right now, I havent done the final placement of the unit just checking it all out right now.
  14. Ultimate Gamer
    3 Nov 2006
    o ok ya she is very young 1 year in like June so still a couple of months or so got here about 8 weeks ago or somthing she helps me out alot intill she starts eating up some of my projects lol
  15. customh
    22 Oct 2005
    Sweet work, like the dogs too. Keep it up (the work) :)
  16. tolis86
    tolis86 What's a Dremel?
    3 Nov 2006
    nice mod man!...keep up!!! i loooooooooove those dogs!!! so so cute! adorable!
  17. HourBeforeDawn
    26 Oct 2006
    Alright here are a few more pics with the 5.25 bay installed, its a nice fit with plenty of room to spare ^^
    Okay here is the question, how should I arrange the side panels now that I have this phase cooler it kind of changes some things up so I will let you be the judge.
    I was originally going to go with this full window for the mobo side of the case like so
    or seeing how that heatsink needs a fan to keep it cool, I could move that top panel to the side and the full window to the top and this way I can have a fan to cool that heatsink.
    so let me know if you think I should go with A) Full Side Window Panel or B) Hlf Window with Fans Panel.
  18. Ultimate Gamer
    3 Nov 2006
    i like the second one :)
  19. customh
    22 Oct 2005
    Second. Have you fired up the phase cooler? Is it loud? Otherwise, how are you going to shield the fuglyness of the compressor and things from the public eye?
  20. HourBeforeDawn
    26 Oct 2006
    well from what Im getting from a lot of people in all the different forums is that I should make some kind of cover that will hide but at the same time show off the phase cooler so alright Im going to do just that... I think, I will make up some possible renders and concept drawing and see what we can do with this cooler that will keep it working how it should but clean it up, So that will take some time designing as I have a lot of measurements to do first. ^^
    Also for those havent commented on the side panels keep doing so by all means I like the input.
    @customh no I have not fired up the cooler at this time, I will be doing that sometime this week.
