project: i-spider |stacker mod | 11-4: up and running (again)
Discussion in 'Project Logs' started by _ferry_, 19 Aug 2004.
  1. Franklin
    Franklin Minimodder
    24 Oct 2004
    Gefeliciteerd Ferry. Also congratulations for your price winning mod.
  2. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    Thank you very much! :D
    I will try to post an small update ASAP, i did some modding to the sidepanels and PSU, not finished, but yust to give you an impression.
  3. _ferry_
    22 Apr 2004
    update
    As i promised an update.
    I'm currently working on the sidepanels, PSU and some plexiglass parts:
    Mounted the right side.
    I've glued some m3 bolts on the back, so they ar'nt visible at the sides.
    A little misstake was that i didn't tought about the height of the case itself, so i had to remove some parts of the frame where the bolts are mounted.
    New stuff has arrived, thanks for a.c. ryan
    - A.C. Ryan UV blue 8mm plexi
    - A.C. Ryan clear 5mm plexi
    - A.C. Ryan meshX, as 1 of the first in NL
    Taping it of and ready to get cut.
    After cutting/sanding
    After some olishing the are shining like premod.
    Don't forget these, thy had te get finished, and the holes ar'nt 100% on a straight line, but note that in worst case that would be 0,1mm difference.
    These speak for themselves.
  4. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Wow Sweet! Nice plexy blocks, they transmit light very well too.
  5. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    Lookin' good that stuff :D (heb overigens al geruime tijd de MeshX in de winkel :baby: ) That MeshX is really awesome stuff!!
    Very nice work on the acrylic pieces :thumb: Ohw... btw happy birthday :D
  6. McJac
    McJac What's a Dremel?
    14 Jun 2005
    Lookin' good. :rock: :clap:
    That MeshX sliver and black is :jawdrop: very good.
  7. angelorus2000
    angelorus2000 What's a Dremel?
    14 Nov 2003
    i like the acrylic stuff and the industrial look
    mod on :rock: :rock:
  8. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    omg... this is getting too hot!! Excellent work _ferry_
  9. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    This should definately be a front page contender, willing to bet it ends up there too after its a lil more complete.
  10. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    to sexii
  11. _ferry_
    22 Apr 2004
    I hope so :p
    But there is so much work left, when i finished the sidepanels, rear side and radiators, i can start with the inside, electronics and watercooling. And after all ther must be that robot-like spider on the right side. Also planning to buy a tft witch should fit the theme.
  12. djfrexx
    djfrexx What's a Dremel?
    27 Dec 2004
    good idea
  13. waitandbleed
    waitandbleed What's a Dremel?
    4 Feb 2005
    Thats a really big case! Looks good so far! Good Idea on the side panels!
  14. Sub-Zero
    Sub-Zero What's a Dremel?
    6 Feb 2005
    I´ve to think about some new ideas to keep up with your work. nice, very nice!
  15. _ferry_
    22 Apr 2004
    update
    Past day's the weather was perfect, so i've been modding in the sunlight.
    The finished ATX cable, i hope i placed them back in the right way :p
    Finally i used the meshX panel from a.c. Ryan. I've forgotten to show where it's used for. A suprise for the next time ;)
    The carton board replaced by aluminium. Offcourse it will be sprayed black, but i had to drill some holes in it before doing that.
    I made this today, it hasn't transparency, it's just reflection of my fingers beyond it.
    It was yust a experiment, so i polished it afterwards, bad idea, you can't polish the corners. Well, i just gonna use it, if it look bad, i will make a new one. I guess this would look much better than seeing the radiator and both PSU's. There will be a black sheet of alu on top of it, to hide the eges of the grill.
    This one is 11cm in height, the other one will be 35cm. And it's realy time expansive, it keeps me busy while i'm on holyday ;)
  16. mrhanky
    mrhanky What's a Dremel?
    12 Sep 2004
    nice work, maybe you can shorten it a little bit in
  17. Zero82z
    Zero82z What's a Dremel?
    5 Mar 2004
    Very cool stuff. I'm looking forward to how this mod turns out.
  18. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    This is one very nice piece of work you have there. Nice idea by the way.
  19. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Truley nice stalkers!
    If you get tired of that watercooling you can always exchange that for a compresosr in the top appartment ;)
    Very nice mod!
  20. _ferry_
    22 Apr 2004
    Yes, enough space for it, but not enough money i guess :(
    I hope to serv a new update tomorrow... The reservoir :)
