project: i-spider |stacker mod | 11-4: up and running (again)
Discussion in 'Project Logs' started by _ferry_, 19 Aug 2004.
  1. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    update
    Short update (and almost 200'th photos :) )
    It wasn't going like i wanted to do, some parts were damaged, and 2 tools died. But this is the result:
    A short test of how i'm gonna finish the grill, offcourse the rear plate and sides will be painted black.
    a fit-test.
    these plates will be mounted on both sides of the reservoir, the plexiglass will be equipped with some led's to let it glow.
    The way it should be, i need to order my second eheim 1048 soon.
    the junction between the plexi tube and sides need some finishing up. But i want it to be hardened first. But it seems to be leak proof :)
    That's it for now, next update will be about an week, when i'm back from hollyday. Yes, i gonna mod there. When i return, i should have the watercooling and rear side finished. And maybe much more done.
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Hey nice job ;)
  3. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    from pump to reservoir?
    isnt it better from reservoir to pump?
  4. _ferry_
    22 Apr 2004
    Don't know for shure. But i think the capacity is enough, a dual rad + eheim 1048 to cool down the CPU, and a singe rad+ 1048 for the videocard.
    1 good thing about is is the slight vacuuum you have, less change of leaking.
  5. Rufus-Seal
    Rufus-Seal Guest
    I think you did an awesome job, I can't wait to see the finishing result.
    But what's the meaning of this:
    And an another question; wich led/ccfl's colors are gonna lighted on in your case?
  6. _ferry_
    22 Apr 2004
    I'm talking abut the aluminium strip witch i folded to give you an idea how i gonna make the sides for it. (that's why the alu strip isn't as long as the grill is, it's just a left-over.)
    To compare:
    The light is white and bue, i think blue ccfl's and white led's (got plenty of them) I don't want to light up the whole case by plugging in some big CCFL's. But by many small sourches. like the reservoir, beyond shields, grills, and so on. (that means also a lot of cables and switching ;) )
  7. frodo
    frodo What's a Dremel?
    1 Nov 2003
    hi mate, the idea is you go from reservoir to pump, to prevent the pump being starved of water, meaning less cavitation, and quicker air release
    this mod looks great, keep it up
  8. _ferry_
    22 Apr 2004
    update part 1
    I've got an large update, 37 pics. I hope you enjoy :)
    Thuesday 5juli:
    This was my temp. workspace, i took a lot with me, many tools, plexiglass, components, some hardware and the PC offcourse.
    First a small problem to solve, the cables from the casefan couldn't get hide beyond a piece of the frame or something like that. So i decided to make a double wall.
    A short try to moount the cable's on this way, a piece of steel wire to get them on the mesh.
    The reservoir, quite less space between. So i think i will cut off 5mm from the bottom.
    I broke the strip witch is between the 2 cases, the plexi ain't that strong :( (i knew that before, but i forgot :( )
    Wensday 6 juli
    [img=613,480]http://www.tweakers.net/ext/f/62254/full.jpg[/img]
    The holes are used for the WC tubes.
    Well, if it's broken you should fix it. I've made new strips made of 8mm a.c. ryan's UV plexi. The same as i used for the pieces on the sidepanel.
    While the strips were drying, i took care of this. It's made to guide the WC tubes and some brake cable.
    Mounted some led's into the plexiglass.
    Here will be the WC tubes guided trough
    The strip is made of 2 pieces. because the plexi was 50cm, and the case more.
    The way to polish small holes ;)
  9. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    your images dont show correctly. They show as text only.
  10. _ferry_
    22 Apr 2004
    update part 2
    Thursday 7 juli
    Sorry, bad hairday :p
    Guiding of the tubes.
    It's time to finish off the rear panel
    Ready to paint it.
    Friday 8 juli
    Done nothing :p
    Saturday 9 juli
    These are the strips for the grill, i only need to polish them and mount them offcourse.
    Look, no more visible cable's :)
    Connecting it.
    These speak for themselve i hope so :)
    Connecting the tubes after the picture was made i switched 2 tubes so the S-bend in the tube is less than on the picture showed
    Now i showed also where i used the mesh for, witch i made before... to hide the radiators and FAN's
    I little difficult to explain how the WC is connected, especcially in english, so here's a drawning:
    1: Pomp 1 sucks trought the left circuit, i slight underpressure prevents leaking
    2: Much heat produced by the CPU
    3: A little cooldown by the small radiator
    4: See point 1
    5: More heating up by the VGA
    6: Complete cooldown
  11. Firehed
    15 Feb 2004
    looks very nice, but as someone mentioned, you can't have the pump push water into the reservoir. the reservoir NEEDS to be just before the pump's inlet unless the reservoir is completely full (which rather defeats the purpose). Just wanted to pass on a quick warning! But again, great work, looks very well-done and just plain good ideas.
  12. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    This is coming along nicly ;)
    I really like it :)
  13. Sub-Zero
    Sub-Zero What's a Dremel?
    6 Feb 2005
    that way I also spent my holidays :D
    damn, I have to do some work on my stacker again, maybe in 1 week or 2. I´m just thinking for new ideas and searching for a sponsor :hip:
    Great work my friend :thumb:
  14. _ferry_
    22 Apr 2004
    Thanks You and others :)
    By chemical overdose i did it the same way:
    When you fill the reservoir, the water will go through the pump and fill the tubes as long as you switch it off.
    Anyway, a WC setup won't be refilled every day. So if it take some time to fill it i don't care.
  15. mrhanky
    mrhanky What's a Dremel?
    12 Sep 2004
    nice work
    lots of hard working... but it sure shows off at the end
  16. _ferry_
    22 Apr 2004
    update
    I-spider has given a sign of life ;)
    First i bought some parts i needed, and after that i assembled the 2 prints, on top you see the print witch switches the 2 PSU's and 2 pumps. I also able to switch on the 2 pumps and the 2'nd PSU with a switch on the back. So the system doesn't have to run to enable the lights and cooling.
    Very nice that a print has the same width as an HDD, so this bracket will be used.
    Mounted in the case.
    And there is light :D
    I've forgotten to make some pics of the cables and other stuff. I will do that next time, i want to improve the power cable's anyway to prevent a short circuit.
  17. arkadur
    arkadur What's a Dremel?
    3 May 2005
    damm
    one of the best projects i ever seen!
    amazing man - keep up the graet work!
    got any plans for the next project;)
  18. D B
    D B What's a Dremel?
    11 Apr 2004
    I love the work that you do ... Outstanding
    Great idea to have the small rad to cool the water coming from the CPU , going to the graphics card ( I always wondered about having 2 seperate systems for cooling CPU & VGA) and as you said, that reservior idea will work (just don't try to fill it with the pumps running , lol)
    DB
  19. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    Awesome work on that ATX cable and that rear vent. Looking forward to more updates.
  20. _ferry_
    22 Apr 2004
    update
    Today i finished the part witch guides the tubes, i've already made it, but today i mounted the leds in it and polished the top of it.
    The parts i need
    Ready for testing
    It works :)
    Here i mounted it quicly into the case, i love it 8)
    And an overview with all the lights on.
    Now it's time to finish the reservoir. Because that one is needed to finis the watercooling and it also contains led's witch should be connected.
