Scratch Build – In Progress Project Neophyte .: UPDATE 25 !!!!!! : 21.03.10 :.
Discussion in 'Project Logs' started by Dark~3nergy, 25 Mar 2008.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I feel for ya... Check my custom waterblock thread, I had it happen too.
  2. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    Dark~3nergy really nice render the work that you have done is amazing :thumb: and i think the broke parts will not stop you ;) keep it up
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Bit of a downer for you and us, but keep it up, your case is awesome.
  4. The boy 4rm oz
    10 Apr 2008
    Damn man that really sucks. I am guessing the tap is stainless steel so it will be a real pain to drill out.
  5. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    thanks !
    The boy 4rm oz, it's written SSH on it, I think it stands for stainless steel so yeah, it won't be easy....
  6. FrooP
    FrooP can I eat this?
    24 Oct 2007
    its HSS which means "hochleistungs schnitt stahl" which means High solid cutting steel, or something like that, so youll better try to get it out somehow else, because the drill bit will slip into the way softer copper for sure
  7. Dark~3nergy
    14 Jan 2007
    thanks for the advise :(
    I'll see what I can do
  8. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Haha, loving the German! Pretty helpfull for my schoolwork.
    I wouldn't worry too much about speaking it there to be honest; they're very good english speakers, although they'll adore you if you try.
    EDIT: Loving the mod as well, obviously.
  9. saxman
    saxman What's a Dremel?
    21 Feb 2005
    HSS is a High Speed Steel. It is a kind of tool steel that can be used in a high speed machining application. But you have to be very careful. HSS is also very brittle because it is so hard. The hardness is so it can cut through materials like plain carbon and softer stainless steels all in one tool. Use plenty of oil and be very patient. Make sure your tap is not being pushed to the side wile you turn and try not to take more than a half a turn without clearing the chips. just remember to take it slow.
    Keep up the good work Neophyte looks amazing. I will follow this one. I like pulling the DVD out of the case like that.
  10. Dark~3nergy
    14 Jan 2007
    thanks for the advise, saxman !
    anyway, my dad helped me to remove the broken tap, but the hole were it was sitting was to big so I had to use M4 screws instead of M3 screws and that was realy great.
    I don't think it would have been as good with m3 screws on it.
    so here's some progress pics :
    corrosion :grr:
    I'll probably have more time to work tomorrow, I still need to mill it to the right size.
    BTW. does anybody know where I can get O-rings(or similar) that have a diameter of ~85mm and that are at least 3mm thick ?
    cya
  11. jhanlon303
    7 Sep 2006
    I've been meaning to ask the same question. Where does one find non round O rings to fit rectangular shapes?
  12. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    You just use normal O-rings of the required diameter and they can be used in rectangular places.
  13. jhanlon303
    7 Sep 2006
    Thanks! I'm a H20 noob. Cheapskate does the hard work for us. I just think stuff up. :duh:
  14. The boy 4rm oz
    10 Apr 2008
    That block looks fantastic mate. I didn't realize you were using it to cool the Raptor. Oh well, another first lol.
  15. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Nice D3..
  16. Attila
    Attila still thinking....
    22 Feb 2008
    What he said ^^, I know zip about water cooling but it looks great,
    just like the rest of the project. I've been watching this from the
    start and am looking forward to seeing the finished work.
  17. modsquad
    27 Feb 2004
    ONB-- your CygnusX1 is very-cool.. No disrespect to D3 intended, just needed to tella-ya..
  18. Dark~3nergy
    14 Jan 2007
    thanks you all ! :D
  19. Dark~3nergy
    14 Jan 2007
    just finished the plexi part :)
    koolance nozzles :p
    I still need to tap the hole for the nozzles, shorten the screws and to get that damn o-ring.
  20. The boy 4rm oz
    10 Apr 2008
    Very nice work. I can't wait to see her up and running.
