Case Mod - In Progress Project: NLM. FINISHED 11.08.07
Discussion in 'Project Logs' started by jegerjon, 6 Feb 2007.
  1. eegg
    eegg What's a Dremel?
    29 Aug 2006
    looks realy cool with the red and leds keep on the good work :dremel:
  2. V3ase
    V3ase What's a Dremel?
    25 Jan 2007
    I cant stand to se when its over , how it all smal will be ??
  3. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    wow an insane amount of pics...
    but your milling skills look pretty good!
    keep it up dude
  4. trig
    trig god's little mistake
    10 Aug 2006
    awesome
  5. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Thank you guys!
    I can't wait to start on the case, I want to show you my ideas!
  6. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Looks nice and clean. What paint did you use for the black?
  7. jegerjon
    10 Jan 2007
    Update 8 – Fridge part 5 @ Wedensday the 7th March 2007.
    For word.
    This is the last update about the Fridge!
    There isn’t much to say, but as you’ll find out, I’ve now finished this part.
    I ordered some stuff from performance-pcs i hope it’ll arrive tomorrow.
    Lets gogo
    The funny part
    I don’t know why it’s always the details I’m photographing, but here I’ve sanded the handle.
    The isolation has been glued on, I’ll fix the edges later.
    Now there’s some silicon between the 2 parts.
    After a couble of day.
    Lol, I’ve to fix this.
    That was easy :)
    Perfect.
    I’ve put on some bondo @
    Done with the dremel.
    And the last holes’ patched.
    A lot of sanding and some paint later:
    Nice nice. But after I’ve changed the plans (which means that I’ve to mod a little mATX case) I was worried if I even could get it fit.
    It’ll be placed here, but because of those bastads I have to “try-fit” it closer to the psu.
    Now I’ve planted it.
    Omg I was lucky, it fit very good!
    See you soon, I’m going to make my own waterblocks ;)
  8. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Excelent work :)
    p.s: please post some photos of yours homemade waterblocks ;)
  9. V3ase
    25 Jan 2007
    Dont get it ;/
    How it gonna to look like ??
    have you any paintings ??
  10. jegerjon
    10 Jan 2007
    thx
    V3ase @ you just got to stay with me and watch my work.
    Heres a block I'm planing to mill tomorrow.
    I'm going to mill 5mm down, and then follow the drawing with a 3mm drill. I put the fittings on the orange plexi wich I'll put over. You'll see tomorrow. Stay cool.
  11. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Looking nice dude! The orange plexi should look a treat.
  12. jegerjon
    10 Jan 2007
    Update 9– Parts @ Thursday the 8th March 2007.
    For word.
    Today I received my package from perfomance-pcs! :D Lets take a look.
    The funny part
    Here’s my bulgin, it should light orange when I plug the power.
    I can’t wait to get power on this to ;)
    And the cabels.
    Connectors.
    Dont know what to call them, but you plug them on the end of the cable, so they are ready for molex, ehe. Now I have 240, you always need them ^^
    Some orange sleeving, thought I ordered way more, but lets see.
    Som orange neon paint ;)
  13. jegerjon
    10 Jan 2007
    Update 10 – Hardware & Custom cpu block @ Friday the 9th March 2007.
    For word.
    W00hooo I got a cool cpu block done! When I get my new pumpI’ll leak-test it.
    The funny part
    2*1gb ram (don’t know the brand)
    Motherboard (with amd 3700+)
    Ati x600 pro
    80 gb Maxtor hdd, I want to mod it.
    Lets take a look at my block:
    I bet it’s cool! – can you guys se the ”NLM” i typed in i? ;)
    And puted on, looks very good.
  14. guysy1110
    guysy1110 What's a Dremel?
    15 Feb 2007
    nice stuff. i have the same 80 gig hard drive and its not working, so i want to see how you mod yours :D
    The ram you have i think the brand is Micron, i have the same logo on mine and its from micron.
  15. Jipa
    5 Feb 2004
    Cool block. Is that plastic UV-reactive? Btw I found my peltier-unit (w/ athlon 64 heatsink) and witout fan the heatsink got very hot in short time even at 12 Volts (specified 16V) at 2 A. We shall see...
  16. hellas91
    18 Feb 2006
    The block looks fabolous! :p
    Very nice work with it ;)
  17. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    nice block, would look much nicer if it was green acrylic, just to match the mobo. lol!
  18. jegerjon
    10 Jan 2007
    Oh, just wait i have plans. I'm going to make blocks for the nb, ram, peltier (on the fridge) and the gfx, after this I'll hide the mobo with some of ac ryans black panel (with holes) Bet it would look sweet.
  19. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Lol thats the same HDD from my old HP. I'm loving that CPU block its pretty damn cool.
  20. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    you, sir, have given me a very good idea for a waterblock, and no its not like that!
    you do very work with the mill, it looks awesome. it will probably perform pretty well too.
