Scratch Build – In Progress RTX scratchlog: done, but not final update
Discussion in 'Project Logs' started by Teyber, 28 Jun 2007.
  1. Teyber
    Teyber ******
    18 Mar 2007
    ahh thank for reminding me... cable stealthing totally forgot lol!
    I need your help guys please! i don't wan't to ruin my new switch!
    For the LED, it doesn't show witch end is + and which end is -, so could i hurt it if i put the positive in the negative and the negative in the positive or will it just not work?
    Shot with COOLPIX P4 at 2007-07-18
    hard to show in a pic but... before i try itout please advice guys?
    http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=118&products_id=4446
    its similar to that one
  2. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Is that a negative I see? I would say that at this point you have the wires reversed. The power swith doesn't matter as it is only an NO switch.
  3. Teyber
    Teyber ******
    18 Mar 2007
    thanks.
    I got it worked otu though, i tested it, it works, and i sleeved it :)
  4. Teyber
    Teyber ******
    18 Mar 2007
    some of dat rtx p0rn
    completely looks chromed, wow this is a unbelievable finish!
    First time ever using heatshrink or sleeving something :) the switch works yay! i hope i didn't hurt the switch while i had a lighter kinda near it working the heatshrink, i bet its fine...
    Still workin on paint. I layed down 5 coats today and while doing another coat of clear the stupid can "spit" out a lot of it and ruined some of the paint... omfg im going insane
    Im goign to repaint it and try to finish those 3 panels by the end of today, tomoro its time to move on!
  5. Teyber
    Teyber ******
    18 Mar 2007
    Alright, i got so much done today... after repainting the panels 3 times(seriously, hours to waste) i got it satisfactory! woot
    Still dust and finger prints all over it lol, in the end ill turtle-wax it. and i still need to remake the one window for the panel with no window showing, as it cracked
    i think thats the same pic but just to see
    And this panel is my favorite ill be posting a lot more pics of it, but im running short on time. Look at the mesh, its so awsome! the camera makes it look like blurry plexi but its mesh
    and **** sexy mesh at that
  6. Teyber
    Teyber ******
    18 Mar 2007
    Shot with COOLPIX P4 at 2007-07-19
    OMFG WHAT HAPPENED TO THE MOBO TRAY
    jkjk i hate my dremel, it cant cut crap so what i did was i drilled a ton of holes! then of course...
    ahhh wow thats pretty good huh! the first pic you can see where i had started filing, and after a LOT of filing i ended up with this :) don't worry if its straight or not, i problably didn't even need to file it cuz its under the mobo but hey, i don't want to cut any corners here! BTW for you confused people, the holes are to help hide wires
    one more thing,
    The mesh on the side panel. A fan will go on here and then that will go over the hard drives
    man i got a lot done today!!!
    wired/sleeved power button
    cut out and sanded RTX
    completely mirrored RTX
    cut holes in the mobo tray
    painted the 3 panels 3 times(had to redo, ugh)
    lots and lots of sanding for the paint
    man im tired! hopefully a productive day tomoro too!
  7. Teyber
    Teyber ******
    18 Mar 2007
    Shot at 2007-07-18
    just to clarify the mobo holes
  8. Teyber
    Teyber ******
    18 Mar 2007
    HERES WHAT I HAVE TO SAY TO THAT
    ooo$$$$$$$$$$$oo
    o$$$$$$$$$$$$$$$$$$$ooo
    o$$$$$$$$$$$$$$$$$"$$$$$$$oo
    o$$$$$$$$$$$$$$$$$$$ o $$$$$$$$$$$$$$oooo
    o$$$$"""$$$$$$$$$$$$$oooo$$$$$$$$$$$$$"""
    oo$"" "$$$$$$$$$$$$$$$$$$$$$$$$"
    o$$ $$$$$$$$$$$$$$$$$$$$$$"
    o$$$$ $$$$$$$$$$$$$$$$$"
    o$$$$$$oooooooo " $"
    o$$$$$$$$$$$$$ o
    o$$$$$$$$$$$$$ o
    o$$$$$$$$$$$$$$ "o
    o$$$$$$$$$$$$$$$ "o
    o$$$$$$$$$$$$$$$$ $
    o$$$$$$$$$$$$$$$$" "
    o$$$$$$$$$$$$$$$$$ $
    $$$$$$$$$$$$$$$$$ $o
    $$$$$$$$$$$$$$$$$$o $$
    $$$$$$$$$$$$$$$$$$$$o $$
    $$$$$$$$$$$$$$$$$$$$$$o "$
    $$$$$$$$$$$$$$$$$$$$$$$$o $
    $$$$$$$$$$$$$$$$$$$$$$$$$$$$$o $$
    $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$o $$
    $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ o$
    $$$$$$$$$$$$$$$$$$$$$ o$$
    "$$$$$$$$$$$$$" o$
    $$$$$$$o $"
    o$$$$$$$$ $$
    o$$$$$$$$$ $"
    "$$$$$$$$$ o$""
    "$$$$$$$$ ooooo$$oo
    ""$$$$$o oooo$$$$$$$$$$$$$$ooo
    "$$$$$$o
    A PENGUIN
  9. Teyber
    Teyber ******
    18 Mar 2007
    that did not work out well at all
  10. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    .... angry there any? if i was you i would invest in a good file and try to straighten out those lines. if necessary re-tape the lines and use a Tsquare for perfect 90 deg. lines. trust me when your all and done with the case and you see crooked lines you will kick yourself in the pants for your laziness.
  11. tribaloverkill
    tribaloverkill Who needs sleep,... bah.
    1 Jan 2005
    I'm with this guy. Dude,.... you need to slow down. You're not using cutting wheels with your dremel are you? Dont use the other drill like bits. They down cut aluminum for S@#$. use cut off wheels. And tape too! Think STRAIGHT lines! Think 90 degree angles! Slow and spend more of your time drawing out straight lines. I think we can all agree that before you go ahead and start cutting up all your stuff that you should post pics of your work all taped up,... with all off your lines drawn out to perfection so we can see. We want to see your straight lines first BEFORE you cut! ok?
  12. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    I was going to say the same thing. Some of those cuts look like you were drinking when you made them.....J/K. But seriously, a square isn't much money at all and you will be much happier with the end results. Also, it looks like the panels are 'dented' where some of the screw holes are. A couple of wood blocks and a hammer could straighten that out.
    Take your time, you'll notice some of the really good projects here take months to complete.
  13. tribaloverkill
    1 Jan 2005
    Or years;)
  14. Teyber
    Teyber ******
    18 Mar 2007
    yeah i know lots of my lines have been crooked, guys keep in mind im really new to power tools! this project was my first time using a drill(i didn't even have a drill, now i have a press and a hand drill :D) and my el cheapo jigsaw keeps swearving off to the left, which can be a big problem ehhehe.
    About my dremel, i have the diamond cut off wheel. Its just that i had to use my dremel for lots of stuff it wasnot ment for :( and the motor is starting to die. It was about 25/30$ anyways, so moneys not the issue.
    I don't think the mobo tray is that bad considering how i cut it!
  15. tribaloverkill
    1 Jan 2005
    Dude if you jig saw is running off to the side,... stop cutting! Meaning stop pushing. Correct your angle and then cut a little. You dont have to make one complete run. Cut a little bit at a time. Practice sketching out lines line to cut. That should be your first priority! You get me soldier? For someone that has never used power tools before,.... I got to give it to you,.......... you haven't cut any anything off, body parts that is:))
  16. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Looking good :D
  17. Teyber
    Teyber ******
    18 Mar 2007
    are you guys talkin about crooked lines on the panels or on the mobo tray?
  18. Teyber
    Teyber ******
    18 Mar 2007
  19. Teyber
    Teyber ******
    18 Mar 2007
    still have that top corner to straighten out but thats better i think
  20. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Looking better. Be sure to use some c-molding around those so you don't cut your cables. When using a dremel, let the tool do the work and make your cuts in the opposite way the cutter is rotating to avoid jumping.
