Case Mod - In Progress SR-2 STACKER - 'Completed'
Discussion in 'Project Logs' started by coolmiester, 21 Aug 2010.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    I've seen a few cases chopped up like this but this one looks so perfectly done, you've gotten me thinking about case chopping instead of scratch building with seeing how if done right can look this good lol :D.
    The fan controller bezel looks pure excellence, very nice fit :thumb:.
  2. w3bbo
    w3bbo What's a Dremel?
    20 Sep 2010
    Love the look of the bezel.
  3. bulldogjeff
    2 Mar 2010
    That panel is seriously nice.:thumb:
  4. DarkFear
    DarkFear What's a Dremel?
    14 Oct 2003
    People these days just don't read :rolleyes: :p
    Will the top "case" be bolted down? I don't want to think what would happen if someone knocked the top bit off the main case :eeek:
  5. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    No it will be detachable for transport etc using Koolance quick disconnects to make life easy - its weighing in at 7.86kg without water or fitting so doubt it will be easy to knock off but i am going to have some notches in the 840 below for the feet to lock into just to be on the safe side :)
    Cheers for the feedback chaps, you rock :rock:
  6. MrNitro
    MrNitro Performance Enthusiast =)
    26 Jun 2010
    These quick disconnects are very nice, looks like the ones used in hydraulics systems on heavy machines, only scaled down.
    The bevel looks great too =)
  7. The boy 4rm oz
    10 Apr 2008
    Great work on the new face plate for those fan controllers. Are you going to be using the controllers just for fans or will you be connecting the pumps up to it as well?
    I also really like the bay reservoirs, they look so cool.
    With the face plate, did you use a router to bevel the edge or did you do that by hand?
  8. coolmiester
    31 Dec 2002
    Thanks for the feedback :thumb:
    Couldn't resist doing a bit of a mock up held together with bubble gum and string :D
    Razer2007 likes this.
  9. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Love the clean look of the fan controller panel. awesome work mate!
  10. Yaka
    Yaka Modder
    26 Jun 2005
    is it just me that thinks those exposed fans look the nuts like that? wish i could leave em nekid like that when i will eventually watercool my case. tho i wont as i have kids in the house:/
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Not just you :D, but for wandering fingers, maybe a minimalist grill :thumb:.
  12. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    the fan controler bezel looks great, but I think the whole front of the radiator box looks a little strange. the fan controlers are too far down. Is it possible to shrink the name plate above the fan controlers and move them up?
  13. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Hey Paul,
    I'm glad to see you back again with what I'm sure will top your previous work.
    Your fan bezel looks fantastic, and I cant wait to see how this continues to shape up. Loving the rad box, I've been thinking a lot about something similar for my next mod.
    Awesome as always.
  14. frozensnail
    frozensnail What's a Dremel?
    20 Apr 2007
    Tip Top mod so far, can only get better
  15. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    this.
    Fan controllers should be int he vertical center of the top box, with the same brushed black aluminium below it as above.
    Don't get me wrong, this is shaping up to be another fantastic mod. Just looks odd to have the silvery metal off center. Maybe if that were black it wouldn't look so strange but I am not sure...
  16. coolmiester
    31 Dec 2002
    Post #96 :thumb:
  17. murtoz
    9 Apr 2008
    DOH! :duh:
    Sorry, I'll try to learn how to :read:
  18. coolmiester
    31 Dec 2002
    My apologies for the delay on this and should get back on track after Multiplay LAN at the weekend ;)
    Massive thanks to Vincent at Bitspower who shares the same birthday as me :thumb:
    Got the extended motherboard tray all made up and added the rails for it to slide in and out but took photos with wrong WB and they came out crap so i'll have to take more pictures once it stops raining.
    Also the front bezel SR-2 logo which i did have the correct setting on the camera and added some scrap red plexi behind but the plan is to fill up the logo with red Crystal Resin so its flush and light it from behind.
  19. DarkFear
    14 Oct 2003
    That's a considerable amount of win right there... :eeek:
  20. Razer2007
    18 Jul 2010
    A lot of fittings man. And the logo looks cool. what will be in the block?
