Case Mod - In Progress Test bench mod by Ace_finland [completed]
Discussion in 'Project Logs' started by Ace_finland, 10 Oct 2012.
  1. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks! yeah, its quite stubborn, have bled it 3 times already :)
    Thanks!
    Thanks!
  2. Ace_finland
    Ace_finland Member
    11 Aug 2012
    So here we go. As I'm looking through the pictures taken yesterday i realize i should have taken a lot more. Anyways, here are most of them without posting very similar looking ones. Enjoy!
    Without leds on. Sadly a few fingerprints on it but better with them there than photoshopped away :)
    Gpu loop
    Leds on
    Still have a few things to do with the computer but this will be it for the coolermaster mod competition. Wanna try to make my ram look like the gpu support with the same red glow :) Not sure if its gonna work but gonna give it a go, also have some other ideas. But will have a weeks or two break now, need to sort out the rest of my life that has been left aside while building this :)
    Sponsored by:
  3. Razarach
    Razarach Member
    28 Jan 2009
    wow, this is beautiful. ;)
  4. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks!
  5. KrunchR
    KrunchR New Member
    22 Apr 2008
    Nice work!
  6. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thank you!
  7. Sissilisko
    Sissilisko New Member
    26 Apr 2012
    Looking great.
  8. Meelobee
    Meelobee New Member
    5 Nov 2003
    That's one good looking bench you made Ace :)
    As I said in a DM, it could use some cable separators on the 24pin and GPU wiring. Other than that I totally love it! Very nice! :thumb:
  9. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Such an awesome test bench.
    Devastated I wasn't aware of this project earlier, but glad I finally found it!
    Love the GPU support - it matches the angles of the radiator boxes and also fits quite well with those Dominators. Well played!
    I look forward to seeing more awesome builds from you in the future.
  10. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks!
    yeah, i'm def gonna do something to it but was in a rush to finish it for the cooler master mod competition :)
  11. Ace_finland
    Ace_finland Member
    11 Aug 2012
    hey guys,
    Did a compilation photo of the mod for the competition so thought i would post it here aswell.
    Sponsored by:
  12. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Very nice bench, totally different from anything I've ever seen :)
  13. j3akalua
    j3akalua Banned
    9 Dec 2012
  14. Ace_finland
    Ace_finland Member
    11 Aug 2012
  15. Ra6
    Ra6 New Member
    4 Nov 2012
    That's it! I love those reservoirs outside the case! Could you take some pictures only with the led's light please? >.<
  16. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks! I will, but not right away, still need to modify it a bit more :)
  17. myrizzle
    myrizzle Member
    23 Nov 2011
    Totally awesome :thumb:
  18. Ace_finland
    Ace_finland Member
    11 Aug 2012
    thanks!
  19. Ace_finland
    Ace_finland Member
    11 Aug 2012
    Thanks for all who voted for me in the Cooler Master mod competition! Got myself a 3rd prize :)
    After a very busy Christmas I've made a prototype of the ram, did not go well at all but at least i've gotten started.
    This is the design. It's basically the same design as the Dominator platinum ram but with a sandwich construction consisting of two aluminum sides with acrylic in the middle.
    The aluminum part
    One of the aluminum parts pressed together with the acrylic. Got decent tolerances on the parts so i just pressed them together with a vice, no glue needed :)
    Made a red light bar so the ram would match the case better. Still want a white acrylic top with it only being red when its on :)
    Installed without a lightbar
    It looks the same with a lightbar. Think there is not enough light for the light to reflect all the way to the middle of the ram. I will experiment a bit more but if i can't figure it out i will leave it with just a red lightbar
    With the red lightbar and the original part it looks like this. It's not too bad but a bit of the white light shines through due to the fact that the leds are further apart than the width of the lightbar. The red bar is the same width as the original one. Also gonna polish the entry surface of the acrylig to let as much light through as possible
    Sponsored by:
  20. Meelobee
    Meelobee New Member
    5 Nov 2003
    you could try to sand the bottom of the plexi to distribute the light a bit more. Looks good! :)
